Code help
HI
I am having problems with my project. I want my arduino to take input from a keyboard (ps2) and display it on my nokia 5110 lcd. I could get them both to work 100% alone. However, when i put their code together i get an error. This is the the error; “no matching function for call to ‘PS2Keyboard::Begin(constint&, constint&)’”
this is my code put together
#define PIN_SCE   7
#define PIN_RESET 6
#define PIN_DC    5
#define PIN_SDIN  4
#define PIN_SCLK  3
int ledlight = 13
#define LCD_C     LOW
#define LCD_D     HIGH
#define LCD_X     84
#define LCD_Y     48
#include <PS2Keyboard.h>
const int DataPin = 8;
const int IRQpin =  2;
PS2Keyboard keyboard;
static const byte ASCII[][5] =
 {0x00, 0x00, 0x00, 0x00, 0x00} // 20
,{0x00, 0x00, 0x5f, 0x00, 0x00} // 21 !
,{0x00, 0x07, 0x00, 0x07, 0x00} // 22 "
,{0x14, 0x7f, 0x14, 0x7f, 0x14} // 23 #
,{0x24, 0x2a, 0x7f, 0x2a, 0x12} // 24 $
,{0x23, 0x13, 0x08, 0x64, 0x62} // 25 %
,{0x36, 0x49, 0x55, 0x22, 0x50} // 26 &
,{0x00, 0x05, 0x03, 0x00, 0x00} // 27 '
,{0x00, 0x1c, 0x22, 0x41, 0x00} // 28 (
,{0x00, 0x41, 0x22, 0x1c, 0x00} // 29 )
,{0x14, 0x08, 0x3e, 0x08, 0x14} // 2a *
,{0x08, 0x08, 0x3e, 0x08, 0x08} // 2b +
,{0x00, 0x50, 0x30, 0x00, 0x00} // 2c ,
,{0x08, 0x08, 0x08, 0x08, 0x08} // 2d -
,{0x00, 0x60, 0x60, 0x00, 0x00} // 2e .
,{0x20, 0x10, 0x08, 0x04, 0x02} // 2f /
,{0x3e, 0x51, 0x49, 0x45, 0x3e} // 30 0
,{0x00, 0x42, 0x7f, 0x40, 0x00} // 31 1
,{0x42, 0x61, 0x51, 0x49, 0x46} // 32 2
,{0x21, 0x41, 0x45, 0x4b, 0x31} // 33 3
,{0x18, 0x14, 0x12, 0x7f, 0x10} // 34 4
,{0x27, 0x45, 0x45, 0x45, 0x39} // 35 5
,{0x3c, 0x4a, 0x49, 0x49, 0x30} // 36 6
,{0x01, 0x71, 0x09, 0x05, 0x03} // 37 7
,{0x36, 0x49, 0x49, 0x49, 0x36} // 38 8
,{0x06, 0x49, 0x49, 0x29, 0x1e} // 39 9
,{0x00, 0x36, 0x36, 0x00, 0x00} // 3a :
,{0x00, 0x56, 0x36, 0x00, 0x00} // 3b ;
,{0x08, 0x14, 0x22, 0x41, 0x00} // 3c <
,{0x14, 0x14, 0x14, 0x14, 0x14} // 3d =
,{0x00, 0x41, 0x22, 0x14, 0x08} // 3e >
,{0x02, 0x01, 0x51, 0x09, 0x06} // 3f ?
,{0x32, 0x49, 0x79, 0x41, 0x3e} // 40 @
,{0x7e, 0x11, 0x11, 0x11, 0x7e} // 41 A
,{0x7f, 0x49, 0x49, 0x49, 0x36} // 42 B
,{0x3e, 0x41, 0x41, 0x41, 0x22} // 43 C
,{0x7f, 0x41, 0x41, 0x22, 0x1c} // 44 D
,{0x7f, 0x49, 0x49, 0x49, 0x41} // 45 E
,{0x7f, 0x09, 0x09, 0x09, 0x01} // 46 F
,{0x3e, 0x41, 0x49, 0x49, 0x7a} // 47 G
,{0x7f, 0x08, 0x08, 0x08, 0x7f} // 48 H
,{0x00, 0x41, 0x7f, 0x41, 0x00} // 49 I
,{0x20, 0x40, 0x41, 0x3f, 0x01} // 4a J
,{0x7f, 0x08, 0x14, 0x22, 0x41} // 4b K
,{0x7f, 0x40, 0x40, 0x40, 0x40} // 4c L
,{0x7f, 0x02, 0x0c, 0x02, 0x7f} // 4d M
,{0x7f, 0x04, 0x08, 0x10, 0x7f} // 4e N
,{0x3e, 0x41, 0x41, 0x41, 0x3e} // 4f O
,{0x7f, 0x09, 0x09, 0x09, 0x06} // 50 P
,{0x3e, 0x41, 0x51, 0x21, 0x5e} // 51 Q
,{0x7f, 0x09, 0x19, 0x29, 0x46} // 52 R
,{0x46, 0x49, 0x49, 0x49, 0x31} // 53 S
,{0x01, 0x01, 0x7f, 0x01, 0x01} // 54 T
,{0x3f, 0x40, 0x40, 0x40, 0x3f} // 55 U
,{0x1f, 0x20, 0x40, 0x20, 0x1f} // 56 V
,{0x3f, 0x40, 0x38, 0x40, 0x3f} // 57 W
,{0x63, 0x14, 0x08, 0x14, 0x63} // 58 X
,{0x07, 0x08, 0x70, 0x08, 0x07} // 59 Y
,{0x61, 0x51, 0x49, 0x45, 0x43} // 5a Z
,{0x00, 0x7f, 0x41, 0x41, 0x00} // 5b [
,{0x02, 0x04, 0x08, 0x10, 0x20} // 5c ¥
,{0x00, 0x41, 0x41, 0x7f, 0x00} // 5d ]
,{0x04, 0x02, 0x01, 0x02, 0x04} // 5e ^
,{0x40, 0x40, 0x40, 0x40, 0x40} // 5f _
,{0x00, 0x01, 0x02, 0x04, 0x00} // 60 `
,{0x20, 0x54, 0x54, 0x54, 0x78} // 61 a
,{0x7f, 0x48, 0x44, 0x44, 0x38} // 62 b
,{0x38, 0x44, 0x44, 0x44, 0x20} // 63 c
,{0x38, 0x44, 0x44, 0x48, 0x7f} // 64 d
,{0x38, 0x54, 0x54, 0x54, 0x18} // 65 e
,{0x08, 0x7e, 0x09, 0x01, 0x02} // 66 f
,{0x0c, 0x52, 0x52, 0x52, 0x3e} // 67 g
,{0x7f, 0x08, 0x04, 0x04, 0x78} // 68 h
,{0x00, 0x44, 0x7d, 0x40, 0x00} // 69 i
,{0x20, 0x40, 0x44, 0x3d, 0x00} // 6a j
,{0x7f, 0x10, 0x28, 0x44, 0x00} // 6b k
,{0x00, 0x41, 0x7f, 0x40, 0x00} // 6c l
,{0x7c, 0x04, 0x18, 0x04, 0x78} // 6d m
,{0x7c, 0x08, 0x04, 0x04, 0x78} // 6e n
,{0x38, 0x44, 0x44, 0x44, 0x38} // 6f o
,{0x7c, 0x14, 0x14, 0x14, 0x08} // 70 p
,{0x08, 0x14, 0x14, 0x18, 0x7c} // 71 q
,{0x7c, 0x08, 0x04, 0x04, 0x08} // 72 r
,{0x48, 0x54, 0x54, 0x54, 0x20} // 73 s
,{0x04, 0x3f, 0x44, 0x40, 0x20} // 74 t
,{0x3c, 0x40, 0x40, 0x20, 0x7c} // 75 u
,{0x1c, 0x20, 0x40, 0x20, 0x1c} // 76 v
,{0x3c, 0x40, 0x30, 0x40, 0x3c} // 77 w
,{0x44, 0x28, 0x10, 0x28, 0x44} // 78 x
,{0x0c, 0x50, 0x50, 0x50, 0x3c} // 79 y
,{0x44, 0x64, 0x54, 0x4c, 0x44} // 7a z
,{0x00, 0x08, 0x36, 0x41, 0x00} // 7b {
,{0x00, 0x00, 0x7f, 0x00, 0x00} // 7c |
,{0x00, 0x41, 0x36, 0x08, 0x00} // 7d }
,{0x10, 0x08, 0x08, 0x10, 0x08} // 7e ?
,{0x78, 0x46, 0x41, 0x46, 0x78} // 7f ?
void LcdCharacter(char character)
  LcdWrite(LCD_D, 0x00);
  for (int index = 0; index < 5; index++)
    LcdWrite(LCD_D, ASCII[character - 0x20][index]);
void LcdClear(void)
  for (int index = 0; index < LCD_X * LCD_Y / 8; index++)
void LcdInitialise(void)
  pinMode(PIN_SCE, OUTPUT);
  pinMode(PIN_RESET, OUTPUT);
  pinMode(PIN_DC, OUTPUT);
  pinMode(PIN_SDIN, OUTPUT);
  pinMode(PIN_SCLK, OUTPUT);
  digitalWrite(PIN_RESET, LOW);
  digitalWrite(PIN_RESET, HIGH);
  LcdWrite(LCD_C, 0x21 );  // LCD Extended Commands.
  LcdWrite(LCD_C, 0xB1 );  // Set LCD Vop (Contrast).
  LcdWrite(LCD_C, 0x04 );  // Set Temp coefficent. //0x04
  LcdWrite(LCD_C, 0x14 );  // LCD bias mode 1:48. //0x13
  LcdWrite(LCD_C, 0x0C );  // LCD in normal mode.
  LcdWrite(LCD_C, 0x20 );
void LcdString(char *characters)
  while (*characters)
    LcdCharacter(*characters++);
void LcdWrite(byte dc, byte data)
  digitalWrite(PIN_DC, dc);
  digitalWrite(PIN_SCE, LOW);
  shiftOut(PIN_SDIN, PIN_SCLK, MSBFIRST, data);
  digitalWrite(PIN_SCE, HIGH);
void setup(void)
{ delay(1000);
   keyboard.begin(DataPin, IRQpin);
  LcdInitialise();
  LcdClear();
  LcdString("Hello World!");
void loop(void)
{  if (keyboard.available()) {
    // read the next key
    char c = keyboard.read();
    // check for some of the special keys
    if (c == PS2_ENTER) {
      LcdStringLcdStringln();
    } else if (c == PS2_TAB) {
      LcdString("[Tab]");
    } else if (c == PS2_ESC) {
      LcdString("[ESC]");
    } else if (c == PS2_PAGEDOWN) {
      LcdString("[PgDn]");
    } else if (c == PS2_PAGEUP) {
      LcdString("[PgUp]");
    } else if (c == PS2_LEFTARROW) {
      LcdString("[Left]");
    } else if (c == PS2_RIGHTARROW) {
      LcdString("[Right]");
    } else if (c == PS2_UPARROW) {
      LcdString("[Up]");
    } else if (c == PS2_DOWNARROW) {
      LcdString("[Down]");
    } else if (c == PS2_DELETE) {
      LcdString("[Del]");
      // otherwise, just print all normal characters
      LcdString(c);
void setup(void)
{ delay(1000);
http://www.arduino.cc/playground/Main/PS2Keyboard
Looks like keyboard.begin takes a single parameter not two.
Thanks, That does not fix the problem though
After removing the second parameter you are still getting the error "no matching function for call to 'PS2Keyboard::Begin(constint&, constint&)'"?
yeah, well sort of instead of saying "no matching function for call to 'PS2Keyboard::Begin(constint&, constint&)'" it says "no matching function for call to 'PS2Keyboard::Begin(constint&)'"........... Second constant is removed
I will continue helping you but only if you post ALL OF THE ERRORS instead of just one that catches your eye.
ok if you are asking for all the errors that show up under the main one here they are In file included from Lcd_screen_keyboard.cpp:21: C:\Documents and Settings\Albert\Desktop\arduino-1.0.1\libraries\PS2Keyboard/PS2Keyboard.h:168: error: expected ',' or ';' before 'typedef' C:\Documents and Settings\Albert\Desktop\arduino-1.0.1\libraries\PS2Keyboard/PS2Keyboard.h:173: error: expected constructor, destructor, or type conversion before ';' token C:\Documents and Settings\Albert\Desktop\arduino-1.0.1\libraries\PS2Keyboard/PS2Keyboard.h:176: error: 'PS2Keymap_t' does not name a type C:\Documents and Settings\Albert\Desktop\arduino-1.0.1\libraries\PS2Keyboard/PS2Keyboard.h:177: error: 'PS2Keymap_t' does not name a type C:\Documents and Settings\Albert\Desktop\arduino-1.0.1\libraries\PS2Keyboard/PS2Keyboard.h:197: error: expected ',' or '...' before '&' token C:\Documents and Settings\Albert\Desktop\arduino-1.0.1\libraries\PS2Keyboard/PS2Keyboard.h:197: error: ISO C++ forbids declaration of 'PS2Keymap_t' with no type Lcd_screenkeyboard.cpp: In function 'void setup()': Lcd_screenkeyboard:172: error: no matching function for call to 'PS2Keyboard::begin(const int&, const int&)' C:\Documents and Settings\Albert\Desktop\arduino-1.0.1\libraries\PS2Keyboard/PS2Keyboard.h:197: note: candidates are: static void PS2Keyboard::begin(uint8_t, uint8_t, int) Lcd_screenkeyboard.cpp: In function 'void loop()': Lcd_screenkeyboard:186: error: 'LcdStringln' was not declared in this scope Lcd_screenkeyboard:208: error: invalid conversion from 'char' to 'char*' Lcd_screen__keyboard:208: error: initializing argument 1 of 'void LcdString(char*)'
#define PIN_SCE 7
#define PIN_RESET 6
#define PIN_DC 5
#define PIN_SDIN 4
#define PIN_SCLK 3
int ledlight = 13 <<<<<< Semicolon is missing
#define LCD_C LOW
#define LCD_D HIGH
Your life will be a lot easier when you learn to download libraries to the correct place. The arduino-1.0.1\libraries folder is ONLY for libraries delivered with the IDE.
On any system that understood from the get-go security, that libraries folder would be read-only.
Mr. Coding Badly, nice catch i added the semicolon but now i have a different error, the new error is "to few arguments to function 'void LcdStrin(char characters)'" the rest of the errors are Lcd_screen_keyboard.cpp: In function 'void loop()': Lcd_screen_keyboard:154: error: too few arguments to function 'void LcdString(char)' Lcd_screen_keyboard:186: error: at this point in file Lcd_screenkeyboard:208: error: invalid conversion from 'char' to 'char*' Lcd_screen__keyboard:208: error: initializing argument 1 of 'void LcdString(char*)' Mr. PaulS, where should i place my libraries than? I always thought you put them there, so far it has not caused me anyproblems
What will happen when version 1.0.2 is released. Absolutely none of your code will work, until you download all the libraries again. Will you remember where you got them?
In the folder where you store your sketches, there should be a folder called libraries. If not, create one. Then, move all the libraries you have downloaded there.
That way, they will still be available after you install 1.0.2.
      LcdString(c);
The LcdString function takes a string (a NULL terminated array of chars, not a single char. Either create a 2 element array, and put c in the first element and NULL in the second, or call LcdCharacter() instead.
how would i create a 2 element array ? Could you please ellaborate, i am still a noob in coding .
char two_character_string[2];
// Nul terminate functions looking for c strings absolutely require this- // Otherwise it will spin through memory until it does find a '\0' two_character_string[1] = '\0';
// store my character, c two_character_string[0] = c;
LCDString(two_character_string);
ok, thanks keith, when i put that in get another error,
Lcd_screen___keyboard:20: error: expected constructor, destructor, or type conversion before ‘=’ token
Lcd_screen___keyboard:23: error: expected constructor, destructor, or type conversion before ‘=’ token
Lcd_screen___keyboard.cpp: In function ‘void loop()’:
Lcd_screen___keyboard:203: error: ‘LCDString’ was not declared in this scope
Update Full code
#define PIN_SCE   7
#define PIN_RESET 6
#define PIN_DC    5
#define PIN_SDIN  4
#define PIN_SCLK  3
#define LCD_C     LOW
#define LCD_D     HIGH
#define LCD_X     84
#define LCD_Y     48
// Otherwise it will spin through memory until it *does* find a '\0'
void gotoXY(int x, int y) {
  LcdWrite(0, 0x80 | x);  // Column.
  LcdWrite(0, 0x40 | y);  // Row.  ?
void LCDClear(void) {
  for (int index = 0 ; index < (LCD_X * LCD_Y ) ; index++)
  gotoXY(0, 0); //After we clear the display, return to the home position
void  LcdCharacter(char *characters)
  while (*characters)
void setup(void)
  LcdInitialise();
LCDClear();
   LcdCharacter("Ready!");
void loop(void)
       LcdCharacter("[Tab]");
    }  else {
//You cant do this outside a function!
It should be this:
char two_character_string[2] = "c";
or this:
char two_character_string[2] = {'c',0};
or this:
char two_character_string[2] = {'c','\0'};
Tom, I think the OP wants to store the value of the char variable c into the first element of two_character_string, not the letter 'c'.
two_character_string[1] = 0;    // this can be put in setup()
tuxduino: Tom, I think the OP wants to store the value of the char variable c into the first element of two_character_string, not the letter 'c'.
Ahh right, in which case you just need to remove the ' '
char two_character_string[2] = {c,0};
It should be this:
Most definitely not. The [2] index is all wrong for an array that has two elements.
I'm sorry, in what way is the [2] wrong? It is a declaration of an array with two elements, which is initialised with two characters, 'c' and 0 (or in my last post is initialised with the value stored in the variable c and a 0).
I read your previous post too quickly. It was correct. I was wrong. My apologies.
