code is not working properly ....plzzz help me
:confused: :confused: i have made bluetooth control arduino car by using arduino uno + L2938 motor shield and it was working fine ...then i came up with the idea of using ultrasonic sensor with lcd to find distance ....when i merged both programmes i end up only running lcd with distance displaying ......but my car is not working ..plsss help ......here is the code----
//Distance sensor
#define trigPin 12
#define echoPin 8
//Flashing LED on Arduino board
#define LEDPin 13
#include <Wire.h>
#include <LCD.h>
#include <AFMotor.h> //Adafruit Motor Shield Library. First you must download and install AFMotor library
#include <Servo.h> //Servo library. This is standard library. (Sketch -> Include Library -> Servo)
String voice;
#define I2C_ADDR 0x27 // Define I2C Address where the PCF8574A is
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
int n = 1;
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
AF_DCMotor motor1 (1, MOTOR12_8KHZ); //create motor #1 using M1 output on Motor Drive Shield, set to 1kHz PWM frequency
AF_DCMotor motor2 (2, MOTOR12_8KHZ); //create motor #2 using M2 output on Motor Drive Shield, set to 1kHz PWM frequency
AF_DCMotor motor3(3, MOTOR12_8KHZ); //create motor #1 using M1 output on Motor Drive Shield, set to 1kHz PWM frequency
AF_DCMotor motor4 (4, MOTOR12_8KHZ); //create motor #2 using M2 output on Motor Drive Shield, set to 1kHz PWM frequency
Servo myServo; //define servo name
void forward_car();
void back_car();
void right_car();
void stop_car ();
void left_car();
pinMode(trigPin, OUTPUT); //The transmit pin of the ultrasonic sensor
pinMode(echoPin, INPUT); //The receive pin of the ultrasonic sensor
pinMode(LEDPin, OUTPUT); //The LED of the Arduino
lcd.begin (20,4); //Size of LCD
// Switch on the backlight
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH);
lcd.home (); // go home
Serial.begin(9600); //start serial communication
myServo.attach(10); //define our servo pin (the motor shield servo1 input = digital pin 10)
myServo.write(90); //servo position is 90 degrees
void loop(){
while (Serial.available())
{ //Check if there is an available byte to read
delay(10); //Delay added to make thing stable
char c = Serial.read(); //Conduct a serial read
if (c == '#') {break;} //Exit the loop when the # is detected after the word
voice += c; //Shorthand for voice = voice + c
int duration, distance;
digitalWrite(trigPin, HIGH);
delayMicroseconds(100);
digitalWrite(trigPin, LOW);
duration = pulseIn(echoPin, HIGH);
distance =(duration/2) / 29.1;
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Distance from OB");
lcd.setCursor(0,1);
lcd.print(distance);
lcd.print("cm");
if (distance >=10)
lcd.setCursor(0,4);
lcd.print("Safe Zone :)");
digitalWrite(LEDPin,HIGH);
digitalWrite(LEDPin,LOW);
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" door ho ja !!!");
lcd.setCursor(0,1);
lcd.print(" STEP AWAY!!!");
lcd.setCursor(0,2);
lcd.setCursor(0,3);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
if (voice.length() > 0){
if(voice == "*go ahead")
forward_car();
else if(voice == "*go back"){
back_car();
else if(voice == "*turn right") {
right_car();
else if(voice == "*turn left") {
left_car();
//else if(voice == "*turn on light") {
//LED_on();
//else if(voice == "*turn off light") {
//LED_off();
else if(voice == "*stop") {
stop_car();
voice=""; //Reset the variable after initiating
void forward_car()
motor1.run(BACKWARD);
motor2.run(FORWARD);
motor3.run(FORWARD);
motor4.run(FORWARD);
delay(3000);
motor1.run(RELEASE);
motor2.run(RELEASE);
motor3.run(RELEASE);
motor4.run(RELEASE);
void back_car()
motor1.run(FORWARD);
motor2.run(BACKWARD);
motor3.run(BACKWARD);
motor4.run(BACKWARD);
delay(3000);
void right_car()
myServo.write(0);
myServo.write(90);
motor3.setSpeed(170);
motor4.setSpeed(170);
void left_car()
myServo.write(180);
myServo.write(90);
motor1.setSpeed(170);
motor2.setSpeed(170);
void stop_car ()
The entire code in the loop() function is wrapped on this
    //code is here
so none of it will run until something is available on the Serial interface. How is the program ever going to receive data from Serial ?
Hello Tejveer, welcome to the forum.
The sneaky folk that created this forum also created a post called 'how to use this forum - please read'. Just to be really awkward and devious they hid it in plain sight at the top of this and every forum. To make it difficult to spot they put it in bold. Please see if you can find it, read it then edit your question in line with the information in the post. Maybe then someone will help you.
You mention Bluetooth control but I see nothing there, only your comment and 'serial' possibly voice command module as you specify voice as your char?
Or is there a Bluetooth module and maybe mobile phone somewhere?
That comment is absolute nonsense. The delay does NOT make ANYTHING stable.
i still can not understand how to solve it
Tejveer:
What is "it" that you are trying to solve? Have you dealt with the issue pointed out in reply #1? If so, how?
