Hi All, My sketch monitors two buttons on pullups. When the both go low, D9 goes high. When one of the buttons goes high, I am trying to wait for three seconds the turn D9 low. The problem is its turning the output low right away. I can see it counting three seconds on the monitor, but thats after it’s already off. It’s not waiting thee three seconds. Thanks, Randy
#include <EEPROM.h> //Save even when powered off
#include <avr/sleep.h> // Might use sleep
unsigned long previousMillis = 0;// Store last time off was checked
const long interval = 3000; // Short button press check
const int switchonPin = 2; // Pin number of ON input
const int delayswitchPin = 3; // Pin number of delay on switch
const int ssronPin = 10; // Pin number of the SSR ON output pin
const int led1Pin = 7; // Status LED
int switchonState = 0; // Innitialize the switch state to 0
int delayswitchState = 0; // Innitialize the delay ON switch state to 0
int ssronState = LOW; // Innitialize the SSR state to 0
int led1State = LOW; // Innitialize LED to low state
pinMode(switchonPin, INPUT_PULLUP); // Plasma signal through contactor
pinMode(delayswitchPin, INPUT_PULLUP);// Rocker switch to select delay, or no delay
pinMode(ssronPin, OUTPUT); // Output to SSR +
pinMode(led1Pin, OUTPUT); // Display LED
Serial.begin(9600); // Set up for analog read in
void loop() { // Monitors signal switch and push button
switchonState = digitalRead(switchonPin); // Signal
delayswitchState = digitalRead(delayswitchPin);// Delay switch
if (switchonState == LOW) {// Signal ON
Serial.print("Signal is Active");
digitalWrite(ssronPin, HIGH); // Turn SSR ON
Serial.println("SSR is ON");
if (switchonState == HIGH && delayswitchState == HIGH) { // If signal is OFF and delay switch is OFF
quickOFF(); // Turn off SSR right away
else if (switchonState == HIGH && delayswitchState == LOW) {// If signal is off and delay switch is ON
delayOFF(); // Turn of SSR after delay
void quickOFF() { // Turns SSR OFF immediately
Serial.println("Quick OFF");
digitalWrite(ssronPin, LOW); // Turn SSR OFF
void delayOFF() { // Turns SSR OFF after delay
Serial.println("Waiting to turn OFF");
unsigned long currentMillis = millis(); // Time stamp this moment
if (currentMillis - previousMillis >= interval) { // Test for three seconds
previousMillis = currentMillis; // Rest timer
Serial.print("counting");
Serial.print("OFF");
When it runs delayOFF(), previousMillis is 0 from its initialisation. So unless it runs delayOFF() in the first 3000ms, current-previous will be > 3000 and the SSR goes off.
edit: you said it needs 2 pins low to turn on, looks like you only use 1. Also you talk of pin 9 but use 10?
To achieve your three second time out you will have to modify the conditional statement calling delayOff() by adding a control variable to start the delay timing and saving a startTime when first called. Then delayOff() uses the startTime for the interval measurement and resets the control variable when done.
//control variables for delayOff()
unsigned long startTime;
boolean timingStarted = false;
if(timingStarted == false)
timingStarted = true;
startTime = millis();
if (timingStarted == true && currentMillis - startTime >= interval) { // Test for three seconds
timingStarted = false;//reset timer
Ardy_guy, Sorry, while I was describing my problem I glance at my uno. Guess I should have had my glasses on.
cattledog, it works the first time through, but when switchState goes low again then high it goes right through to turn the ssroff without timing.
I found by mistake if I put the delayOFF right under startTime = millis(); and end with three brackets, I get "waiting to turn off every time, but it never finishes and stays stuck there. This one sure has me stumped.
I tried using currentMillis = startTime right after it turns the ssr LOW thinking maybey that would force it to reset each time through, but it didn't work.
Thanks again, Randy
As you wrote it
By mistake as I copied it without using "copy"
Me too. delayOff() should only have run one time given the boolean control variable.
delayOff() needs to be called every pass through loop for the timeout to work.
I have not really looked at the logic for getting back into this state. Can you use some serial print debugging statements around the switch states, let me know you see, and see if you can focus on if we are entering the conditional and the downstream logic is faulty, or if you don't reenter the conditional.
The if and else if statements watch two inputs. The delaySwitch just says to go through quickOFF or to go through delayOFF. The switchON tells it if when to actually turn off. Both of them are working.
With delaySwitch OFF(HIGH because of pullups), I get “quick off” in the monitor until the switchON state goes low again(because of pullups) and that’s exactly how I want it.
Like this:
With delaySwitch ON(LOW going through grounded switch), I get the three second delay on first time and “waiting to turn off” in the monitor. After that I get three seconds of scrolling “waiting to turn off”, then “counting”, then “off”, as I would expect it to stay in that loop until switchonState goes low again, but when I take switchon low(to turn on the ssr) after the first time I see it go all the way through the void delayOFF() without counting as it did the original way.
Like this:
(Just moving the delayOFF() to the other side of the bracket) The if and else if work as intended, and I get “Waiting to turn off” every time, but it never times out and writes the ssr pin LOW. So it is stopping right at the if timing statement, but it doesn’t go any further.
I haven’t had time to really try anything else as I’m at work. I sure hope that helps. Thanks so much for your help, Randy
I suggest you let your if statement set a new variable - delayActive =true and currentmillis=millis().
At the end of main loop you can call delayOFF if delayActive is true.
If timing in delayOFF turn off your led SSR or whatever you also set delayActive = false.
I moved the reset of the timing control to when the signal is on, and changed some of the print out for clarity. I think it does what you want now. The delay is active each time the signal stops and the delay switch is set.
if (timingStarted == false)
Serial.println("delayOFF timingStarted = true");
//Serial.println("Waiting to turn OFF");
// timingStarted = false;//reset timer
Serial.print("delayOFF timing finished");
Serial.println(" OFF");
Thanks cattledog, I never would have thought to move it there, thinking of it as part of the off routine. I will try it as soon as I get home. Thanks so much for the time you spent helping me. Randy
