code is working with pin 13 only
**Hi friends this code is working with pin 13 only if I change output pin to 12 or 11 not working led lighting continuously, pls help me out..... Thnx. **
#define key1 2
#define key2 3
#define key3 4
#define key4 5
#define key5 6
#define key6 7
#define key7 8
const int ledPin = 13;
pinMode(key1, INPUT_PULLUP);
pinMode(key2, INPUT_PULLUP);
pinMode(key3, INPUT_PULLUP);
pinMode(key4, INPUT_PULLUP);
pinMode(key5, INPUT_PULLUP);
pinMode(key6, INPUT_PULLUP);
pinMode(key7, INPUT_PULLUP);
pinMode(ledPin, OUTPUT);
int key1S = digitalRead(key1);
int key2S = digitalRead(key2);
int key3S = digitalRead(key3);
int key4S = digitalRead(key4);
int key5S = digitalRead(key5);
int key6S = digitalRead(key6);
int key7S = digitalRead(key7);
if(!key1S)
digitalWrite(ledPin, HIGH);
digitalWrite(LED_BUILTIN, LOW);
if(!key2S)
if(!key3S)
if(!key4S)
delay(1500);
delay(1500);
if(!key5S)
delay(1500);
delay(1500);
if(!key6S)
delay(1500);
if(!key7S)
delay(1500);
delay(100);
You only ever write ledPin HIGH
Please remember to use code tags when posting code
explain what does the line
do?
do?
best regards Stefan
Replace all the instances of LED_BUILTIN with ledPin and then you can use any pin.
LED_BUILTIN Is a constant that is fixed by the type of Arduino you have and can not be changed.
Thnx Grumpy_Mike ... After replacing all the instances of LED_BUILTIN with ledPin ....It's working fine...Thank alot for helping me.
ranjan131:
Do you understand what the problem was ?
