Hello people who are reading this post! I'm sorry if this may be a duplicate but my code doesn't seem to run. I am using Mac book pro 13-inch 2019 with Mac OS Monterey 12.3.1. I am also running this code on the esp8266 and I'm currently trying to make friendship lamps following this tutorial: https://www.instructables.com/CoronaLamps-Simple-Friendship-Lamps-Anyone-Can-Mak/ I downloaded the code on the website and have modified it. It uploads perfectly fine without any errors except that it simply won't run anymore..
Things I've tried to do:
- remove all the special symbols
- make a simple version
- restart application
- restart computer
- reset the esp8266
- eat ice cream
- fix the syntax
but it still wouldn't solve the problem. (and I barely know how to code..)
Here is the original code:
//import the libraries
#include "config.h"
//define the Neopixel pin, this will be different then the pin we soldered the Neopixels to, as they are marked differently
#define PIN 5
//initialize the information for the Neopixels and Adafruit IO
Adafruit_NeoPixel strip = Adafruit_NeoPixel(12, PIN, NEO_GRB + NEO_KHZ800);
AdafruitIO_Feed *lamp = io.feed("lamp");
//how long we want the lamps to stay on when activated (600,000 ms = 10 minutes)
const long interval = 600000;
//setup the timers and status for the lamp
unsigned long previousMillis = 0;
int tap = 0;
//set one of the lamps to 1, the other to 2
int lampVal = 2;
//the value that should activate the lamp. Don't mess with this, the code will figure out what this should be in the setup
int recVal = 0;
//Start the serial monitor for debugging and status
//figure out what recieved value should turn on the lamp (lampVal of other lamp)
if (lampVal == 1) recVal = 2;
if (lampVal == 2) recVal = 1;
//Activate the Neopixels
strip.begin();
strip.setBrightness(255);
strip.show(); // Initialize all pixels to 'off'
//setup the touch sensor as a interrupt and input
pinMode(12, INPUT);
attachInterrupt(digitalPinToInterrupt(12), touch, CHANGE);
//start connecting to Adafruit IO
Serial.print("Connecting to Adafruit IO");
io.connect();
//get the status of the value in Adafruit IO
lamp->onMessage(handleMessage);
//connect to Adafruit IO and play the "spin" Neopixel animation to show it's connecting until and connection is established
while(io.status() < AIO_CONNECTED) {
Serial.print(".");
spin();
//when a connection to Adafruit IO is made write the status in the Serial monitor and flash the Neopixels white
Serial.println(io.statusText());
flash();
//get the status of our value in Adafruit IO
lamp->get();
previousMillis = millis();
//keeps the ESP8266 connected to Adafruit IO
io.run();
//set the starting timer value
//tap = 1 means that we have established that the other lamp was tapped
if (tap == 1) {
//check to see if the timer if over 10 minutes. If it is, turn off the Neopixels and reset the tap status
if (currentMillis - previousMillis >= interval) {
off();
tap = 0;
//if the timer isn't over 10 minutes, continue playing the rainbow animation at a slow speed
rainbow(200);
//the interrupt program that runs when the touch sensor is activated
ICACHE_RAM_ATTR void touch() {
//while the touch sensor is activated, save the lampVal (either 1 or 2) to the Adafruit IO feed and turn the Neopixels to purple
while (digitalRead(12) == 1) {
lamp->save(lampVal);
for(int i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, 102, 0, 204);
strip.show();
//once the touch sensor isn't activated, send a 0 back to the Adafruit IO feed.
} if (digitalRead(12) == 0) {
lamp->save(0);
strip.setPixelColor(i, 0, 0, 0);
strip.show();
//code that tells the ESP8266 what to do when it recieves new data from the Adafruit IO feed
void handleMessage(AdafruitIO_Data *data) {
Serial.print("received <- ");
//convert the recieved data to an INT
int reading = data->toInt();
//if the recieved value is equal to the recVal, and the lamp status is currently off, change the status to on and recent the timer
if(reading == recVal && tap == 0) {
Serial.println("TAP");
tap = 1;
//if we recieve a value but the lamp is already on nothing happens
Serial.println("LOW");
//simple code to turn all of the Neopixels off
void off() {
strip.show();
//The code that creates the gradual color change animation in the Neopixels (thank you to Adafruit for this!!)
void rainbow(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256; j++) {
for(i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel((i+j) & 255));
strip.show();
delay(wait);
//complicated geometry or something to figure out the color values (I don't know how this stuff works, thank goodness for adafruit)
uint32_t Wheel(byte WheelPos) {
WheelPos = 255 - WheelPos;
if(WheelPos < 85) {
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
WheelPos -= 170;
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
//code to flash the Neopixels when a stable connection to Adafruit IO is made
void flash() {
strip.setPixelColor(i, 255, 255, 255);
strip.show();
delay(200);
strip.show();
delay(200);
strip.show();
delay(200);
strip.show();
delay(200);
//the code to create the blue spinning animation when connecting to Adafruit IO
void spin() {
strip.setPixelColor(i, 0, 0, 255);
strip.show();
delay(20);
strip.show();
delay(20);
Here's my code:
// โฐโโค โ PART 1: Setting The Defaults
// โ importing the libraries
#include <WiFiManager.h>
#include "config.h"
//โโโงโโโโโโโโโโโโโโโโโโโโโโโโโโโโโงโโ
// โ Defining the pins
#define nLed 12 // โค Number of leds
#define led 5 // โค The neopixels
#define sensor 12 // โค The touch sensor
// โ Lamp ID
int lampVal = 1; // โค Change it
// โ Activation & color values
int recVals[] = {1, 2, 3, 4, 5};
int colorVals[3];
int glowVals[3];
int moreVals[3];
// โ Creating a neopixel object
Adafruit_NeoPixel strip = Adafruit_NeoPixel(nLed, led, NEO_GRB + NEO_KHZ800);
// โ Initialize Adafruit
// โ Set the activation time
const long interval = 600000; // โค 600,000 ms = 10 min
// โ Setup timers & status
int tap = 0;
// โโโโโโโ ๏ฝฅ ๏ฝก๏พโ: *.โฝ .* :โ๏พ. โโโโโโโ
// โฐโโค โ PART 2: The Setup Code
// โ Start the serial monitor
// โ Figure out the activation values
if (lampVal != 6) {
for (int i = 0; i < 5; i = i + 1) {
if (recVals[i] == lampVal) {
recVals[i] = 6;
// โ Figure out the color values
findColor(lampVal);
colorVals[0] = moreVals[0];
colorVals[1] = moreVals[1];
colorVals[2] = moreVals[2];
// โ Activate the Neopixels
strip.begin();
strip.show(); // โค Initialize all pixels to off
// โ Setup touch sensor
pinMode(sensor, INPUT);
attachInterrupt(digitalPinToInterrupt(sensor), touch, CHANGE);
// โ Start connecting to Adafruit IO
Serial.print("โฐ Connecting to Adafruit IO โค");
io.connect();
// โ Get status of value in Adafruit IO
// โ Connect to Adafruit IO
Serial.print(" โ");
spin();
// โ Get status when connected to Adafruit IO
Serial.print(" โ");
Serial.println("โโโ โโ
โโ
โ โโ");
Serial.println("โฐ Status โค ");
Serial.print(io.statusText());
flash();
// โ Get status of our value in Adafruit IO
lamp->get();
// โ Update timer
// โฐโโค โ PART 3: The Main Code
// โ Keep connected to Adafruit
io.run();
// โ Set the starting timer value
// โ Code when value has been handled
if (tap != 0) { // โค If another lamp is tapped
if (currentMillis - previousMillis >= interval) { // โค If the timer's over 10 minutes
off();
tap = 0; // โค Reset the tap
} else { // โค If the timer isn't over 10 minutes
glowVals[0] = moreVals[0];
glowVals[1] = moreVals[1];
glowVals[2] = moreVals[2];
for(int i = 0; i < 3; i = i + 1) {
strip.setPixelColor(i, glowVals[0], glowVals[1], glowVals[2]);
// โฐโโค โ PART 4: When the touch sensor is activated
// โ while the touch sensor is activated
while (digitalRead(12) == 0) {
for(int i = 0; i < strip.numPixels() ; i = i + 1) {
if ( (i % 2) == 0 ) {
strip.setPixelColor(i, colorVals[0], colorVals[1], colorVals[2]);
strip.show();
// โ Once the touch sensor isn't activated
if (digitalRead(12) == 1) {
lamp->save(0);
off();
// โฐโโค โ PART 5: When New Data has Been Recieved
// โ Notify
โโ
โ โโ");
Serial.println("โฐ Notification โค New data recieved");
// โ Convert the data to int
// โ Check what lamp has been tapped
if(reading == recVals[i] && tap == 0) {
โโ
โ โโ");
Serial.println("โฐ Notification โค Lamp ");
Serial.print(i);
Serial.print(" has been tapped");
tap = 1;
โโ
โ โโ");
Serial.print(i);
Serial.print(" has been tapped but the lights are already on");
// โฐโโค โ PART 6: Lights Off!
void off() {
// โ Code to turn off lights
for(int i=0; i<strip.numPixels(); i = i + 1) {
strip.show();
// โฐโโค โ PART 7: What Color?
void findColor(int stuffedAnimals) {
// โ Code to figure out the color values
if (stuffedAnimals == 1) {
moreVals[0] = 253;
moreVals[1] = 1;
moreVals[2] = 0;
if (stuffedAnimals == 2) {
moreVals[0] = 247;
moreVals[1] = 105;
moreVals[2] = 25;
if (stuffedAnimals == 3) {
moreVals[0] = 238;
moreVals[1] = 222;
moreVals[2] = 4;
if (stuffedAnimals == 4) {
moreVals[0] = 160;
moreVals[1] = 214;
moreVals[2] = 54;
if (stuffedAnimals == 5) {
moreVals[0] = 47;
moreVals[1] = 162;
moreVals[2] = 54;
if (stuffedAnimals == 6) {
moreVals[0] = 51;
moreVals[1] = 62;
moreVals[2] = 212;
// โฐโโค โ PART 8: Dizzy
void spin() {
// โ Code to create the connecting animation
strip.show();
delay(20);
strip.show();
delay(20);
// โฐโโค โ PART 9: Bling Bling
void flash() {
// โ Code to flash the Neopixels
strip.show();
delay(200);
strip.show();
delay(200);
strip.show();
delay(200);
strip.show();
delay(200);
// โฐโโค โ PART 10: Complicated Geometry
// โ Code to figure out the real color values???
if(WheelPos < 85) {
WheelPos -= 85;
WheelPos -= 170;
Changes made:
- Modified the code so it would work with 6 lamps
- Changed a bit of the colours on the Adafruit Neopixels
- Added some more status
- Also renamed some of the variables
You can check for more differences in diff checker
What the serial monitor displays:
20:27:36.744 -> โธฎโธฎโธฎโฐ Connecting to Adafruit IO โค*wm:[1] AutoConnect
20:27:36.882 -> *wm:[2] Connecting as wifi client...
20:27:36.916 -> *wm:[2] setSTAConfig static ip not set, skipping
20:27:36.988 -> *wm:[1] Connecting to SAVED AP: Lamp
20:27:37.405 -> *wm:[1] connectTimeout not set, ESP waitForConnectResult...
20:27:46.115 -> *wm:[2] Connection result: WL_NO_SSID_AVAIL
20:27:46.152 -> *wm:[1] AutoConnect: FAILED
20:27:46.186 -> *wm:[2] Starting Config Portal
20:27:46.221 -> *wm:[2] Disabling STA
20:27:46.254 -> *wm:[2] Enabling AP
20:27:46.254 -> *wm:[1] StartAP with SSID: KLOK
20:27:46.687 -> *wm:[2] AP has anonymous access!
20:27:47.201 -> *wm:[1] AP IP address: 192.168.4.1
20:27:47.235 -> *wm:[1] Starting Web Portal
20:27:47.268 -> *wm:[2] HTTP server started
20:27:47.305 -> *wm:[2] Config Portal Running, blocking, waiting for clients...
20:28:06.795 -> *wm:[2] NUM CLIENTS: 0
20:28:36.776 -> *wm:[2] NUM CLIENTS: 0
20:29:06.789 -> *wm:[2] NUM CLIENTS: 0
20:29:36.775 -> *wm:[2] NUM CLIENTS: 0
20:30:06.773 -> *wm:[2] NUM CLIENTS: 0
20:30:36.775 -> *wm:[2] NUM CLIENTS: 0
20:31:06.775 -> *wm:[2] NUM CLIENTS: 0
20:31:36.778 -> *wm:[2] NUM CLIENTS: 0
20:32:06.789 -> *wm:[2] NUM CLIENTS: 0
20:32:40.012 -> *wm:[2] NUM CLIENTS: 0
20:33:07.609 -> *wm:[2] NUM CLIENTS: 0
20:33:37.876 -> *wm:[2] NUM CLIENTS: 0
20:34:08.768 -> *wm:[2] NUM CLIENTS: 0
20:34:36.768 -> *wm:[2] NUM CLIENTS: 0
20:35:06.799 -> *wm:[2] NUM CLIENTS: 0
20:35:37.506 -> *wm:[2] NUM CLIENTS: 0
20:36:09.502 -> *wm:[2] NUM CLIENTS: 0
20:36:36.795 -> *wm:[2] NUM CLIENTS: 0
20:37:07.136 -> *wm:[2] NUM CLIENTS: 0
20:37:36.833 -> *wm:[2] NUM CLIENTS: 0
20:38:06.880 -> *wm:[2] NUM CLIENTS: 0
20:38:43.096 -> *wm:[2] NUM CLIENTS: 0
20:39:09.076 -> *wm:[2] NUM CLIENTS: 0
20:39:36.778 -> *wm:[2] NUM CLIENTS: 0
20:40:07.937 -> *wm:[2] NUM CLIENTS: 0
20:40:36.823 -> *wm:[2] NUM CLIENTS: 0
20:41:09.358 -> *wm:[2] NUM CLIENTS: 0
20:41:39.096 -> *wm:[2] NUM CLIENTS: 0
20:42:08.744 -> *wm:[2] NUM CLIENTS: 0
20:42:43.122 -> *wm:[2] NUM CLIENTS: 0
20:43:11.434 -> *wm:[2] NUM CLIENTS: 0
20:43:41.791 -> *wm:[2] NUM CLIENTS: 0
20:44:08.409 -> *wm:[2] NUM CLIENTS: 0
20:44:43.173 -> *wm:[2] NUM CLIENTS: 0
20:45:10.658 -> *wm:[2] NUM CLIENTS: 0
20:45:42.989 -> *wm:[2] NUM CLIENTS: 0
20:46:06.793 -> *wm:[2] NUM CLIENTS: 0
20:46:36.797 -> *wm:[2] NUM CLIENTS: 0
20:47:06.803 -> *wm:[2] NUM CLIENTS: 0
20:47:36.809 -> *wm:[2] NUM CLIENTS: 0
20:48:06.794 -> *wm:[2] NUM CLIENTS: 0
20:48:36.800 -> *wm:[2] NUM CLIENTS: 0
20:49:06.787 -> *wm:[2] NUM CLIENTS: 0
20:49:36.792 -> *wm:[2] NUM CLIENTS: 0
20:50:06.955 -> *wm:[2] NUM CLIENTS: 0
20:50:37.952 -> *wm:[2] NUM CLIENTS: 0
20:51:06.961 -> *wm:[2] NUM CLIENTS: 0
20:51:53.578 -> *wm:[2] NUM CLIENTS: 0
20:52:13.308 -> *wm:[2] NUM CLIENTS: 0
20:52:41.984 -> *wm:[2] NUM CLIENTS: 0
20:53:12.934 -> *wm:[2] NUM CLIENTS: 0
20:53:41.803 -> *wm:[2] NUM CLIENTS: 0
20:54:06.803 -> *wm:[2] NUM CLIENTS: 0
20:54:36.794 -> *wm:[2] NUM CLIENTS: 0
20:55:09.575 -> *wm:[2] NUM CLIENTS: 0
20:55:39.194 -> *wm:[2] NUM CLIENTS: 0
20:56:07.033 -> *wm:[2] NUM CLIENTS: 0
20:56:36.987 -> *wm:[2] NUM CLIENTS: 0
20:57:08.689 -> *wm:[2] NUM CLIENTS: 0
20:57:37.539 -> *wm:[2] NUM CLIENTS: 0
20:58:09.096 -> *wm:[2] NUM CLIENTS: 0
20:58:40.688 -> *wm:[2] NUM CLIENTS: 0
20:59:10.862 -> *wm:[2] NUM CLIENTS: 0
20:59:41.006 -> *wm:[2] NUM CLIENTS: 0
21:00:11.677 -> *wm:[2] NUM CLIENTS: 0
21:00:41.925 -> *wm:[2] NUM CLIENTS: 0
21:01:08.146 -> *wm:[2] NUM CLIENTS: 0
21:01:37.850 -> *wm:[2] NUM CLIENTS: 0
21:02:07.828 -> *wm:[2] NUM CLIENTS: 0
21:02:36.801 -> *wm:[2] NUM CLIENTS: 0
21:03:06.817 -> *wm:[2] NUM CLIENTS: 0
21:03:36.824 -> *wm:[2] NUM CLIENTS: 0
21:04:06.801 -> *wm:[2] NUM CLIENTS: 0
21:04:38.505 -> *wm:[2] NUM CLIENTS: 0
21:05:09.228 -> *wm:[2] NUM CLIENTS: 0
21:05:39.963 -> *wm:[2] NUM CLIENTS: 0
21:06:09.943 -> *wm:[2] NUM CLIENTS: 0
21:06:37.070 -> *wm:[2] NUM CLIENTS: 0
21:07:07.118 -> *wm:[2] NUM CLIENTS: 0
21:07:37.491 -> *wm:[2] NUM CLIENTS: 0
21:08:08.420 -> *wm:[2] NUM CLIENTS: 0
21:08:43.174 -> *wm:[2] NUM CLIENTS: 0
21:09:15.122 -> *wm:[2] NUM CLIENTS: 0
21:09:37.152 -> *wm:[2] NUM CLIENTS: 0
21:10:06.897 -> *wm:[2] NUM CLIENTS: 0
21:10:36.912 -> *wm:[2] NUM CLIENTS: 0
21:11:06.909 -> *wm:[2] NUM CLIENTS: 0
21:11:36.905 -> *wm:[2] NUM CLIENTS: 0
21:12:06.896 -> *wm:[2] NUM CLIENTS: 0
21:12:36.909 -> *wm:[2] NUM CLIENTS: 0
21:13:06.907 -> *wm:[2] NUM CLIENTS: 0
21:13:36.903 -> *wm:[2] NUM CLIENTS: 0
21:14:06.901 -> *wm:[2] NUM CLIENTS: 0
21:14:36.920 -> *wm:[2] NUM CLIENTS: 0
21:15:06.898 -> *wm:[2] NUM CLIENTS: 0
21:15:36.927 -> *wm:[2] NUM CLIENTS: 0
21:16:06.911 -> *wm:[2] NUM CLIENTS: 0
21:16:36.933 -> *wm:[2] NUM CLIENTS: 0
21:17:06.915 -> *wm:[2] NUM CLIENTS: 0
21:17:36.922 -> *wm:[2] NUM CLIENTS: 0
21:18:06.922 -> *wm:[2] NUM CLIENTS: 0
