I have a robot with a PING Sensor and a Motor Shield from adafruit. At the moment, I am trying to get my robot to move forward until an object is located within a certain distance, and then move backward and turn right once an object is located within a certain distance.
With the code I have right now, my robot just moves forward into the object, and doesn't recognize that an object is in the way. My PING sensor is functional and works with other test code, so I know that is not the problem.
Here is what I have so far:
#include <AFMotor.h>
AF_DCMotor motor1(1, MOTOR12_8KHZ);
AF_DCMotor motor2(2, MOTOR12_8KHZ);
AF_DCMotor motor3(3, MOTOR12_1KHZ);
AF_DCMotor motor4(4, MOTOR12_1KHZ);
const int pingPin = 19;
Serial.begin(9600); // set up Serial library at 9600 bps
motor1.setSpeed(200); // set the speed to 200/255
motor2.setSpeed(200);
motor3.setSpeed(200);
motor4.setSpeed(200);
void forward()
motor1.run(FORWARD);
motor2.run(FORWARD);
motor3.run(FORWARD);
motor4.run(FORWARD);
void backward()
motor1.run(BACKWARD);
motor2.run(BACKWARD);
motor3.run(BACKWARD);
motor4.run(BACKWARD);
void haltMotors()
motor1.run(RELEASE);
motor2.run(RELEASE);
motor3.run(RELEASE);
motor4.run(RELEASE);
void turnRight()
long duration, inches;
pinMode(pingPin, OUTPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(5);
pinMode(pingPin, INPUT);
duration = pulseIn(pingPin, HIGH);
inches = microsecondstoInches(duration);
while (inches > 5) //while robot is 5 inches away from object
forward();
haltMotors(); //stop the motors before reversing direction
while (inches < 10) //move robot back 10 inches before turning
backward();
turnRight();
long microsecondstoInches (long microseconds)
return microseconds / 74 / 2;
forward();
That's the problem. You will always stay in that while loop because "inches" never gets the chance to be changed. You need to look for the distance in that while loop to.
Ditto for the other while loop, you must check the new distance some times
Ok, so I created a function called, getDistance(). Here is what I have, but it is still not moving correctly. I hate to ask for answers, but I am unsure where I am going wrong.
void forward()
void backward()
void haltMotors()
void turnRight()
getDistance();
forward();
getDistance();
backward();
turnRight();
float getDistance()
The getDistance function is defined to return a float. There needs to, then, be a return statement, with the value to return. Since, presumably, the value to return is the distance in inches, and inches is a local variable, of type long, it is strange that getDistance()'s return type is not long.
Alright, so I changed float getDistance(), to long getDistance(). I also added a return statement, to return the duration and the inches. But it is still having problems.
void forward()
void backward()
void haltMotors()
void turnRight()
getDistance();
forward();
getDistance();
backward();
turnRight();
float getDistance()
I get an error that says inches was not declared in the scope, and the first while loop was highlighted.
Change "getDistance();" inside the while loops to "inches = getDistance();" and add "return inches;" at the end of the getDistance() function. Also, I would change all places where you define "inches" as long so that it defines "inches" as float.
