Code issue with pushbutton not stopping a sketch
Not entirely sure if
What i am trying to do is combine two "starter sketches" as it were, (the strand test for the neoPixels from Adafruit and the "4. Play the wave file only when the button is held down and only once (kind of like a musical keyboard") and have them both come on simultaneously when a momentary button is released and turn off when the button is pushed. What happens is that on the initial pass the sketch kinda works a little (nothing comes on until i release the button), but if i push it again to try to stop it, no go. I'm going to include the code, but it's probably nothing new to anyone (like i said, basic starter code,) but if anyone has any idea how i can solve this issue, i would be forever grateful. Thanks in advance!
#include <FatReader.h>
#include <SdReader.h>
#include <avr/pgmspace.h>
#include "WaveUtil.h"
#include "WaveHC.h"
#define PIN 6
Adafruit_NeoPixel strip = Adafruit_NeoPixel(15, 6, NEO_GRB + NEO_KHZ800);
SdReader card;    // This object holds the information for the card
FatVolume vol;    // This holds the information for the partition on the card
FatReader root;   // This holds the information for the filesystem on the card
FatReader f;      // This holds the information for the file we're play
WaveHC wave;      // This is the only wave (audio) object, since we will only play one at a time
#define DEBOUNCE 5  // button debouncer
// here is where we define the buttons that we'll use. button "1" is the first, button "6" is the 6th, etc
byte buttons[] = {14, 15, 16, 17, 18, 19};
// This handy macro lets us determine how big the array up above is, by checking the size
#define NUMBUTTONS sizeof(buttons)
// we will track if a button is just pressed, just released, or 'pressed' (the current state
volatile byte pressed[NUMBUTTONS], justpressed[NUMBUTTONS], justreleased[NUMBUTTONS];
// this handy function will return the number of bytes currently free in RAM, great for debugging!
int freeRam(void)
  extern int  __bss_end;
  extern int  *__brkval;
  int free_memory;
  if((int)__brkval == 0) {
    free_memory = ((int)&free_memory) - ((int)&__bss_end);
  else {
    free_memory = ((int)&free_memory) - ((int)__brkval);
  return free_memory;
void sdErrorCheck(void)
  if (!card.errorCode()) return;
  putstring("\n\rSD I/O error: ");
  Serial.print(card.errorCode(), HEX);
  putstring(", ");
  Serial.println(card.errorData(), HEX);
  while(1);
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  byte i;
  // set up serial port
  putstring_nl("WaveHC with ");
  Serial.print(NUMBUTTONS, DEC);
  putstring_nl("buttons");
  putstring("Free RAM: ");       // This can help with debugging, running out of RAM is bad
  Serial.println(freeRam());      // if this is under 150 bytes it may spell trouble!
  // Set the output pins for the DAC control. This pins are defined in the library
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  // pin13 LED
  pinMode(13, OUTPUT);
  // Make input & enable pull-up resistors on switch pins
  for (i=0; i< NUMBUTTONS; i++) {
    pinMode(buttons[i], INPUT);
    digitalWrite(buttons[i], HIGH);
  //  if (!card.init(true)) { //play with 4 MHz spi if 8MHz isn't working for you
  if (!card.init()) {         //play with 8 MHz spi (default faster!)
    putstring_nl("Card init. failed!");  // Something went wrong, lets print out why
    sdErrorCheck();
    while(1);                            // then 'halt' - do nothing!
  // enable optimize read - some cards may timeout. Disable if you're having problems
  card.partialBlockRead(true);
// Now we will look for a FAT partition!
  uint8_t part;
  for (part = 0; part < 5; part++) {     // we have up to 5 slots to look in
    if (vol.init(card, part))
      break;                             // we found one, lets bail
  if (part == 5) {                       // if we ended up not finding one  :(
    putstring_nl("No valid FAT partition!");
    sdErrorCheck();      // Something went wrong, lets print out why
  // Lets tell the user about what we found
  putstring("Using partition ");
  Serial.print(part, DEC);
  putstring(", type is FAT");
  Serial.println(vol.fatType(),DEC);     // FAT16 or FAT32?
  // Try to open the root directory
  if (!root.openRoot(vol)) {
    putstring_nl("Can't open root dir!"); // Something went wrong,
  // Whew! We got past the tough parts.
  putstring_nl("Ready!");
  TCCR2A = 0;
  TCCR2B = 1<<CS22 | 1<<CS21 | 1<<CS20;
  //Timer2 Overflow Interrupt Enable
  TIMSK2 |= 1<<TOIE2;
SIGNAL(TIMER2_OVF_vect) {
  check_switches();
void check_switches()
  static byte previousstate[NUMBUTTONS];
  static byte currentstate[NUMBUTTONS];
  byte index;
  for (index = 0; index < NUMBUTTONS; index++) {
    currentstate[index] = digitalRead(buttons[index]);   // read the button
    Serial.print(index, DEC);
    Serial.print(": cstate=");
    Serial.print(currentstate[index], DEC);
    Serial.print(", pstate=");
    Serial.print(previousstate[index], DEC);
    Serial.print(", press=");
    if (currentstate[index] == previousstate[index]) {
      if ((pressed[index] == LOW) && (currentstate[index] == LOW)) {
          // just pressed
          justpressed[index] = 1;
      else if ((pressed[index] == HIGH) && (currentstate[index] == HIGH)) {
          // just released
          justreleased[index] = 1;
      pressed[index] = !currentstate[index];  // remember, digital HIGH means NOT pressed
    //Serial.println(pressed[index], DEC);
    previousstate[index] = currentstate[index];   // keep a running tally of the buttons
  byte i;
  if (justpressed[0]) {
    justpressed[0] = 0;
    playfile("elvis.WAV");
    while (wave.isplaying && pressed[0]) {
      //Serial.print(".");
      //rainbowCycle(20);
      //delay(500);
    wave.stop();
//strip.setBrightness(1);
// Plays a full file from beginning to end with no pause.
void playcomplete(char *name) {
  // call our helper to find and play this name
  playfile(name);
  while (wave.isplaying) {
  // do nothing while its playing
  // now its done playing
void playfile(char *name) {
  // see if the wave object is currently doing something
  if (wave.isplaying) {// already playing something, so stop it!
    wave.stop(); // stop it
  // look in the root directory and open the file
  if (!f.open(root, name)) {
    putstring("Couldn't open file "); Serial.print(name); return;
  // OK read the file and turn it into a wave object
  if (!wave.create(f)) {
    putstring_nl("Not a valid WAV"); return;
  // ok time to play! start playback
  wave.play();
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
   return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  } else if(WheelPos < 170) {
    WheelPos -= 85;
   return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
   WheelPos -= 170;
   return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
    delay(wait);
  TCCR2A = 0;
  TIMSK2 |= 1<<TOIE2;
Comments here are ABSOLUTELY essential. How often is the timer supposed to interrupt the code?
    justpressed[0] = 0;
justpressed is not an array of booleans. It would be far easier to read your code if you did not pretend that they were. Explicitly define what you expect justpressed[ 0 ] to contain in each of these statements.
Personally, I'd ditch the timer, the ISR, and the check_buttons() function. Look at the state change detection example to see how to determine that a switch has become pressed, or has become released.
So i have to admit that i'm really weak when it comes to code, so your suggestions went over my head unfortunately. While playing around with the code last night i came up with something that kinda does the trick (turns the audio & lights on and off when i actually want). The problem with this new code, however, is that the lights do not cycle through a color wheel as i would like. Ultimately i want the lights to fade between colors and then turn off when i want..... i'm almost thinking that manipulating this little bit might be a more efficient solution (this is for a class project) . (BTW, i cobbled together this code from Adafruit, so i dont know if parts or pieces are needed or not)
#include "WaveHC.h"
#define PIN 6
SdReader card;
FatVolume vol;
FatReader root;
FatReader f;
int freeRam(void)
  int free_memory;
  else {
  return free_memory;
  putstring(", ");
  while(1);
int upDownFlag=1;  //flag used to see if throbing is rising or dropping 0=dropping, 1=rising
    int throbBright=1;// current brightness value
    int maxThrob=255;
    int minThrob=1; //***Set this below 11 to see bug*** (Bug not present so far)
  strip.begin();
  strip.setBrightness(throbBright); //Start with minimum brightness
      for( int i=0; i<strip.numPixels();i++){ //set all leds to a set color
        strip.setPixelColor(i,255, 255, 255 ); //Use to adjust color of pixels
      strip.show(); // Initialize all pixels to set color
  byte i;
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  // pin13 LED
    sdErrorCheck();
  uint8_t part;
  TCCR2A = 0;
  TIMSK2 |= 1<<TOIE2;
  check_switches();
  byte index;
          // just pressed
          // just released
  byte i;
    justpressed[0] = 0;
      fadeIn();        //Turns on NeoPixels
      delay(75);
      //delay(500);
    wave.stop();
  sdErrorCheck();              // Check for error during play
    delay(25);
        fadeOut();               //Turns off NeoPixels
           strip.setBrightness(throbBright); //set brightness
           strip.show();//Display pixels
  playfile(name);
  wave.play();
  if(WheelPos < 85) {
    WheelPos -= 85;
   WheelPos -= 170;
  uint16_t i, j;
    strip.show();
//FADE IN
void fadeIn(){
        if (upDownFlag==1){//if flag is 1 bring up brightness to maxThrob then flip flag
        throbBright=throbBright+10;
        if (throbBright>maxThrob) {
          throbBright=maxThrob;
          upDownFlag=0;
      delay(1);
//FADE OUT
       void fadeOut(){
       if (upDownFlag==0){//if flag is 1 bring up brightness to maxThrob then flip flag
       throbBright=throbBright-10;
       if (throbBright<minThrob) {
          throbBright=minThrob;
          upDownFlag=1;
      delay(15);
You call a function called fadeIn() while the song is playing, apparently. I say apparently because the code is piss-poorly formatted, making it hard to read. There is no excuse for that when Tools + Auto Format does such a nice job.
How fadeIn() relates to "cycle though the color wheel" is not at all clear.
You will be required to explain the code. Now would be a good time to learn how it actually works. The timer and interrupts and all the mysterious diddling are going to be hardest to explain, when they are complete overkill for reading, apparently, one switch.
Forgive me, the class this is for is actually a sculpture class, lol, thus my complete ignorance as far as the code is concerned (im pretty much brand new to arduino coding, or any kind of coding for that matter). I admit, this code probably looks like a freaking nightmare to someone with a little more experience. I did the Auto- format like you suggested, but im not sure that will do anything great. What does it do exactly?
Properly aligns open and close curly braces.
Properly indents code between the open and close curly braces.
In general, it improves the structure of your program.
In the same way sentences are easier to read with consistent spacing between words, code is easier to read when it is uniformly presented.
So, the relationship between fadeIn() and "cycle though the color wheel"?
I made the assumption that the code was for a programming class. Since it's not, you can ignore a lot of what I said. It's still far more complex that it needs to be. making it difficult to understand, but that can wait.
Cool! I suppose at this point its all baby steps, but steps nonetheless for me at this point. You've been a bigger help than you might realize. That said, any suggestion on how to make my lights cycle through colors instead of simply turning on as white and staying white? I really want to use color for this sculpture!!! :slight_smile:
That's what fadeIn() does. Try calling rainbowCycle(), instead. That delay(500); in rainbowCycle() might be a bit excessive. The cycle will take 740 seconds (more than 12 minutes) to complete.
While i thought that was a great idea, apparently it doesnt work. When i substitute rainbowCycle() the button starting and stopping doesnt work the way i want. Hmmmmmm, im stumpped. Any ideas on how to make the fadeIn() cycle through colors?
Notice that fadeIn() does not loop. It does one thing, and then returns. Next time it is called, it does one thing and returns.
Notice that rainbowCycle() does loop. And delay(). You'll either need to rewrite rainbowCycle() to perform one thing per call, or define a different action for fadeIn().
How, exactly, do you want the LED(s) to progress through the red, green, and blue colors, from completely off to completely on?
There is not a pretty progression from red off to red on, then red on while blue fades from off to on, then red and blue on while green fades from off to on.
So hey, just thought i'd share with you some of the changes to the code i was working on...... i think it might be a little neater and perhaps a bit easier to read. Its still not perfect, but i think its a step in the right direction, though. Perhaps you might be able to give me a few more tips if you can?
#include "WaveHC.h"
// Which pin on the Arduino is connected to the NeoPixels?
#define PIN            6
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS      16
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
// Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
// example for more information on possible values.
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
int delayval = 1500; // delay for half a second
  Button
 Turns on and off a light emitting diode(LED) connected to digital
 pin 13, when pressing a pushbutton attached to pin 2.
 The circuit:
 * LED attached from pin 13 to ground
 * pushbutton attached to pin 2 from +5V
 * 10K resistor attached to pin 2 from ground
 * Note: on most Arduinos there is already an LED on the board
 attached to pin 13.
 created 2005
 by DojoDave <http://www.0j0.org>
 modified 30 Aug 2011
 by Tom Igoe
 This example code is in the public domain.
 http://www.arduino.cc/en/Tutorial/Button
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin = A0;     // the number of the pushbutton pin
const int ledPin =  6;      // the number of the LED pin
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
  putstring(", ");
  while(1);
  strip.begin();
  strip.show();                // initialize all pixels to 'off'
  strip.setBrightness(255); // initialize brightness
    sdErrorCheck();
  uint8_t part;
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
void loop(){
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (buttonState == LOW) {
      // turn LED on:
      rainbowCycle(20);
    wave.stop();
    pattern1();
    delay(5000);
  else {
    pattern1();
    // turn LED off:
    //rainbowCycle(0);
    Serial.print(name);
    return;
    return;
  wave.play();
//SUBROUTINES**************************************************
//COLOR WHEEL
  if(WheelPos < 85) {
    WheelPos -= 85;
  else {
    WheelPos -= 170;
  uint16_t i, j;
  for(j=0; j<256*1; j++) { // 5 cycles of all colors on wheel
    strip.show();
    delay(20);
void pattern1() {
  for(int i=0;i<NUMPIXELS;i++)
    strip.setPixelColor(i, strip.Color(0,0,0));
  strip.show(); // This sends the updated pixel color to the hardware.
  //delay(delayval); // Delay for a period of time (in milliseconds).
