Code issues with Box and loop mk3 iron man helmet code
WARNING: library ServoEasing claims to run on avr, megaAVR, esp8266, esp32, STM32, stm32, stm32duino, sam, samd, apollo3 architecture(s) and may be incompatible with your current board which runs on megaavr architecture(s).
C:\Users\Alfred Fux�n\Documents\Arduino\libraries\ServoEasing\src\ServoEasing.cpp: In function 'void enableServoEasingInterrupt()':
C:\Users\Alfred Fux�n\Documents\Arduino\libraries\ServoEasing\src\ServoEasing.cpp:1118:5: error: 'TIFR1' was not declared in this scope
     TIFR1 |= _BV(OCF1B);    // clear any pending interrupts;
In file included from c:\users\alfred fux�n\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5\avr\include\avr\io.h:99:0,
                 from c:\users\alfred fux�n\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5\avr\include\avr\pgmspace.h:90,
                 from C:\Users\Alfred Fux�n\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/String.h:31,
                 from C:\Users\Alfred Fux�n\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/IPAddress.h:24,
                 from C:\Users\Alfred Fux�n\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/ArduinoAPI.h:30,
                 from C:\Users\Alfred Fux�n\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/Arduino.h:23,
                 from C:\Users\Alfred Fux�n\Documents\Arduino\libraries\ServoEasing\src\ServoEasing.cpp:31:
C:\Users\Alfred Fux�n\Documents\Arduino\libraries\ServoEasing\src\ServoEasing.cpp:1118:18: error: 'OCF1B' was not declared in this scope
C:\Users\Alfred Fux�n\Documents\Arduino\libraries\ServoEasing\src\ServoEasing.cpp:1119:5: error: 'TIMSK1' was not declared in this scope
     TIMSK1 |= _BV(OCIE1B);    // enable the output compare B interrupt
C:\Users\Alfred Fux�n\Documents\Arduino\libraries\ServoEasing\src\ServoEasing.cpp:1119:5: note: suggested alternative: 'TIMERB1'
     TIMERB1
C:\Users\Alfred Fux�n\Documents\Arduino\libraries\ServoEasing\src\ServoEasing.cpp:1119:19: error: 'OCIE1B' was not declared in this scope
C:\Users\Alfred Fux�n\Documents\Arduino\libraries\ServoEasing\src\ServoEasing.cpp:1125:5: error: 'TCCR1B' was not declared in this scope
     TCCR1B |= _BV(ICNC1);
C:\Users\Alfred Fux�n\Documents\Arduino\libraries\ServoEasing\src\ServoEasing.cpp:1125:5: note: suggested alternative: 'TCB1'
     TCB1
C:\Users\Alfred Fux�n\Documents\Arduino\libraries\ServoEasing\src\ServoEasing.cpp:1125:19: error: 'ICNC1' was not declared in this scope
C:\Users\Alfred Fux�n\Documents\Arduino\libraries\ServoEasing\src\ServoEasing.cpp:1128:5: error: 'OCR1B' was not declared in this scope
     OCR1B = ((clockCyclesPerMicrosecond() * REFRESH_INTERVAL_MICROS) / 8) - 100;
C:\Users\Alfred Fux�n\Documents\Arduino\libraries\ServoEasing\src\ServoEasing.cpp: In function 'void disableServoEasingInterrupt()':
C:\Users\Alfred Fux�n\Documents\Arduino\libraries\ServoEasing\src\ServoEasing.cpp:1223:5: error: 'TIMSK1' was not declared in this scope
     TIMSK1 &= ~(_BV(OCIE1B)); // disable the output compare B interrupt
C:\Users\Alfred Fux�n\Documents\Arduino\libraries\ServoEasing\src\ServoEasing.cpp:1223:5: note: suggested alternative: 'TIMERB1'
     TIMERB1
C:\Users\Alfred Fux�n\Documents\Arduino\libraries\ServoEasing\src\ServoEasing.cpp:1223:21: error: 'OCIE1B' was not declared in this scope
exit status 1
Compilation error: exit status 1
Welcome to the forum
Your topic was MOVED to its current forum category which is more appropriate than the original as it has nothing to do with Installation and Troubleshooting of the IDE
Please post your full sketch, using code tags when you do
i've followed a tutorial from "box and loop" how to make a mk 3 iron man helmet but can't manage to compile the code he gave- I'm using an arduino nano every and version 2.0.0 of the program. I have no knowledge of arduinos and need all the help I can get.
thx hubert :slight_smile:
[image]
Who or what is "box and loop" ?
Please post a link to what you are following
What version of the ServoEasing library do you have installed??? They added ATmega4809 support in version 2.2.0 (July 2020). The current version is 3.1.0.
It workt, thx a milion
