code issues
hi there when this code is called up in the main loop it only calls it once then does other things so this code below only does one revolution then stops how can i make this run continously until when the arduino is reset?
void LED2() {
digitalWrite(lockoutled,HIGH);
digitalWrite(lockoutled,LOW);
You'll need to post the whole sketch to get any meaningful help.
wildbill:
Joes, also when you do use a code box instead of quote box (because code boxes have scroll bars). To do so either click on the little button with a "#", or use "code" instead of "quote" in the brackets.
the full code:
/*                       PRIVA GAS / OIL CONTROL
const int heatbutton     = 2 ;
const int ignition_fan_2 = 10;
const int saleswitch     = 4 ;
const int solenoid       = 12;
const int photo_pressure = 3 ;
const int lockoutled     = 8 ;
const int heatbutton_feed= 5 ;
const int fan            = 9 ;
const int map1_or2       = 6 ;
const int relay230_24    = 11;
const int ionisation_in  = 7 ;
const int ventbutton     = 13;
      int ionisation     = 5 ;
bool DoneInitialization = false;
  pinMode(heatbutton,       INPUT );
  pinMode(ignition_fan_2,   OUTPUT);
  pinMode(saleswitch,       INPUT );
  pinMode(solenoid,         OUTPUT);
  pinMode(photo_pressure,   INPUT );
  pinMode(lockoutled,       OUTPUT);
  pinMode(heatbutton_feed,  OUTPUT);
  pinMode(fan,              OUTPUT);
  pinMode(map1_or2,         INPUT );
  pinMode(relay230_24,      OUTPUT);
  pinMode(ionisation_in,    INPUT );
  pinMode(ventbutton,       INPUT );
  digitalWrite(heatbutton_feed, HIGH);
   //              ******  map 1 or 2  ******
    if (digitalRead(map1_or2)==   HIGH)  {
     oil();  }                                 // Oil map
    else {
     gaz();  }                                 // Gaz map
  //                            ******  Serial  ******
  Serial.print("** PRIVA CONTROL  **");
  void newLine();
  Serial.print("Pilot or ign       :");
  Serial.println(digitalRead(map1_or2));
  Serial.print("Ionisation swith input  :");
  Serial.println(digitalRead(ionisation_in));
  Serial.print("photo or pressure       :");
  Serial.println(digitalRead(photo_pressure));
  Serial.print("sales switch           :");
  Serial.println(digitalRead(saleswitch));
  Serial.print("Ionisation              :");
  Serial.println(analogRead(ionisation));
  //                           ******  gaz map-1  ******
    void gaz() {
  if (digitalRead(heatbutton)==   HIGH) {                 // Heat button
  digitalWrite(fan,               HIGH);
  delay(4000);
  if (digitalRead(saleswitch)==   HIGH) {                 // sale switch if HIGH
  digitalWrite(solenoid,          HIGH);
  delay(5000);
 digitalWrite(ignition_fan_2,     HIGH);
 else {                                                  // sale switch if LOW
   delay(10);
   digitalWrite(solenoid,          LOW);
    digitalWrite(fan,              LOW);
    LED2();
   digitalWrite(heatbutton_feed,   LOW);
 if (digitalRead(photo_pressure)== LOW)  {                // pressure if LOW
   delay(10);
   LED1();
   else {                                                //when heat button is LOW
  digitalWrite(ignition_fan_2,     LOW);
  if (digitalRead(photo_pressure)==LOW) {                //   low gaz pressure
   LED1();                                               //   Lock out LED
    if (digitalRead(ventbutton)== HIGH) {
  else {
   //                       ******  oil map-2  ******
   void oil() {
    delay(10);    //debounce
    if (!DoneInitialization)
      if (digitalRead(ionisation_in)==     HIGH) {          // if ionisation swith HIGH
        int val = analogRead(ionisation);
        if (val <900) {
          LED3();
          return;
      else {
        if (digitalRead(photo_pressure)==  HIGH)
        {                                                   // if photo swith HIGH
        delay(10);
          LED1();
         return;
      delay(4000);
    digitalWrite(relay230_24,       HIGH);            // 230V out put to ignition
    DoneInitialization=true;                          // Initialization is done, don't run it again until button has been low
    if (digitalRead(saleswitch)==   LOW) {            // sale switch if LOW
      LED2();
    delay(3000);
    if (digitalRead(ionisation_in)== HIGH)             // if ionisation swith HIGH
      if (val >900) {                                  // ionisation if LOW
       LED3();
    if (digitalRead(photo_pressure)==LOW)  {           // photo if LOW
      delay(10);
      LED1();
    else {
    else {                                          // switching off
    DoneInitialization=false;                       // resetting the count
    digitalWrite(relay230_24,     LOW);
    if (digitalRead(ventbutton)== LOW) {
    delay(5000);
    //                ******  vent button  ******
    if (digitalRead(heatbutton)== LOW) {
    else {
   //         ****** LED blink LOCK OUTS ******
        void LED1() {                 // gaz: HIGH/LOW pressure     oil: photo LOW  or auxhillary
        void LED2() {                  // sale switch if LOW
        void LED3() {                  // ionisations
You’ll need to post the whole sketch to get any meaningful help.
Joes, also when you do use a code box instead of quote box (because code boxes have scroll bars). To do so either click on the little button with a “#”, or use “code” instead of “quote” in the brackets.
sorry just pushed wrong button
Looks like you need to hit some pretty specific conditions for the various if paths to call out the LED2 function.
Need to be in void oil or void gaz and saleswitch needs to be Low.
You could add some serial.prints and see if the code flow is following the expected path, or if variables aren't getting the values you expected.
Joes:
No problem...
it all works exactly how i want it to apart from the three LED blink LOCK OUTS at the bottom they only do the code in each section once when called up.
I can't see why those led routines wouldn't get called repeatedly. Of course, the led won't flash in a continuous pattern for any of the functions because of all the other delays in the code, but I'd expect them to run again and again given that restriction. What do you actually observe the led doing?
the led does exactly what it says in the code but only does it once.
Then it is time, as Crossroads said, to add some print statements to your code to see the execution path.
I just had a question. Does it not have to be in the void loop part of the sketch to run over and over again or will it do that command anywhere with in the sketch. For my own curiosity.
Thanks
good question
Cut and paste into bottom of void loop. Let me know?
mhastie1234:
Your entry points are setup() which gets called once, and loop() which gets called repeatedly. If you want your code to run repeatedly, put it in loop() or in a function called from loop().
ok
i have just changed it all about so everything is now in void loop the only problem is that the led part to the code is running all the time istead of when its called up i think i have written up the call up command incorrectly?
const int fan            = 9 ;
  void newLine();
    if (digitalRead(map1_or2)==   LOW)  {
  delay(4000);
  delay(5000);
   delay(10);
    void LED2();
   delay(10);
   void LED1();
   void LED1();                                         //   Lock out LED
  else {
   else {
        if (val <900) {
         void LED3();
          return;
      else {
        delay(10);
          void LED1();
         return;
      delay(4000);
      void LED2();
    delay(3000);
       void LED3();
      delay(10);
      void LED1();
    else {
    delay(5000);
    else {
       void LED1(); {                 // gaz: HIGH/LOW pressure     oil: photo LOW  or auxhillary
        void LED2(); {                  // sale switch if LOW
        void LED3(); {                  // ionisations
A really good idea, before you post code, is to hit ctrl-t in the IDE, to sort out the indentation.
It makes it easier to read.
const int fan            = 9 ;
  void newLine();
      delay(4000);
        delay(5000);
        delay(10);
        void LED2();
        delay(10);
        void LED1();
      if (digitalRead(photo_pressure)==  LOW) {              //   low gaz pressure
      else {
  else {
          if (val <900) {
            void LED3();
            return;
          {                                                   // if clixon swith LOW
            delay(10);
            void LED1();
            return;
        else {
            delay(10);
            void LED1();
            return;
        delay(4000);
        void LED2();
      delay(3000);
          void LED3();
        delay(10);
        void LED1();
      else {
        delay(5000);
        else {
  void LED1();
  void LED2();
  void LED3();
  {                  // ionisations
There seems to be a closing brace after the closing brace of LED3.
Which has an excess semicolon.
That's not right.
yes as we send we was going to try it all in the loop
You can't define functions inside other functions
