Code isue. what am i missing here
const String PHONE = "+9876543210";
#define rxPin 4
#define txPin 2
#define BAUD_RATE 9600
HardwareSerial sim800(1);
#define LED_PIN 23
#define PIR_SENSOR_PIN 14
String smsStatus,senderNumber,receivedDate,msg;
//bool led = false;
bool pirSensor = false;
  pinMode(LED_PIN, OUTPUT);
  pinMode(PIR_SENSOR_PIN, INPUT);
while(sim800.available()){
  parseData(sim800.readString());
while(Serial.available())  {
  sim800.println(Serial.readString());
void parseData(String buff){
  Serial.println(buff);
  unsigned int len, index;
  index = buff.indexOf("\r");
  buff.remove(0, index+2);
  buff.trim();
  if(buff != "OK"){
    index = buff.indexOf(":");
    String cmd = buff.substring(0, index);
    cmd.trim();
    if(cmd == "+CMTI"){
      index = buff.indexOf(",");
      String temp = buff.substring(index+1, buff.length());
      temp = "AT+CMGR=" + temp + "\r";
      sim800.println(temp);
    else if(cmd == "+CMGR"){
      extractSms(buff);
      if(senderNumber == PHONE){
        doAction();
  else{
void extractSms(String buff){
   unsigned int index;
    smsStatus = buff.substring(1, index-1);
    senderNumber = buff.substring(0, 11);
    buff.remove(0,19);
    receivedDate = buff.substring(0, 20);
    buff.remove(0,buff.indexOf("\r"));
    buff.trim();
    index =buff.indexOf("\n\r");
    buff = buff.substring(0, index);
    buff.trim();
    msg = buff;
    buff = "";
    msg.toLowerCase();
  if (digitalRead(PIR_SENSOR_PIN) = HIGH)&& false) {
    Reply ("indbrud")
   // pirSensor = true;
 void doAction(){
  if (msg == "ARM") {
    pirSensor = false;
    Led = HIGH
    Reply("PIR sensor armed");
  } else if (message == "DISARM") {
    pirSensor = true;
    Led = LOW
    Reply("PIR sensor disarmed");
smsStatus = "";
  senderNumber="";
  receivedDate="";
  msg="";
void Reply(String text)
    sim800.print("AT+CMGF=1\r");
    sim800.print("AT+CMGS=\""+PHONE+"\"\r");
    sim800.print(text);
    delay(100);
    sim800.write(0x1A);
    Serial.println("SMS Sent Successfully.");
    sim800.println("AT+CMGD=1,4");
    sim800.println("AT+CMGDA= \"DEL ALL\"");
What am I missing here? ... you need to post your code properly (in code tags (</>), and tell us what the actual problem is?
are you missing the country code?
The problem is the output when the pir is trigged and the alarm is armed. I get a error when i try to compile it.
For which board? What errors?
Compilation error: 'doAction' was not declared in this scope.
Its a esp32 board and i think a arduino can run the code. I use the most of the code in a relay setup and the only change in code is in the end
This code(around line 101)
if (digitalRead(PIR_SENSOR_PIN) = HIGH) && false) {
  Reply ("indbrud")
Is outside of any function, and is therefore illegal. You closed the previous function above this line.
Learn to auto-format your code in the IDE, then learn to observe what the formatter is showing you.
First fix the issue shown by @camsysca.
Then, In File>Preferences turn on "Show verbose output during compile" and work through all the warnings which are being treated as errors. There are many errors which need correcting.
I am struckling... my english is bad and i cant change the code to run in danish so to now i am learning the hard way. mostly using google translate and it givs me some time more problems then i came with.
This compiles for me
#define rxPin 4
#define txPin 2
#define LED_PIN 23
String smsStatus, senderNumber, receivedDate, msg;
bool Led = false;
  while (sim800.available())
  while (Serial.available())
  //unsigned int len, index;
  unsigned int  index;
  buff.remove(0, index + 2);
  buff.trim();
  if (buff != "OK")
    cmd.trim();
    if (cmd == "+CMTI")
      String temp = buff.substring(index + 1, buff.length());
    else if (cmd == "+CMGR")
      extractSms(buff);
      if (senderNumber == PHONE)
        doAction();
  unsigned int index;
  smsStatus = buff.substring(1, index - 1);
  buff.remove(0, 19);
  buff.remove(0, buff.indexOf("\r"));
  buff.trim();
  index = buff.indexOf("\n\r");
  buff.trim();
  msg = buff;
  buff = "";
  msg.toLowerCase();
    Reply("indbrud")
void doAction()
  if (msg == "ARM")
    pirSensor = false;
    Led = HIGH;
  //else if (message == "DISARM")
  else if (msg == "DISARM")
    pirSensor = true;
    Led = LOW;
  smsStatus = "";
  senderNumber = "";
  receivedDate = "";
  msg = "";
  sim800.print("AT+CMGS=\"" + PHONE + "\"\r");
  sim800.print(text);
  delay(100);
  sim800.write(0x1A);
thanks :smile: what do i do to get reply when the pir sensor gets trigged
