code merge problem
Hi~ Hello
I'm programing beginner
I want to make two codes into one code.
One is the 'DOT Matirx' clock code.
http://www.filedropper.com/dotmatrixclock
The other one is 'TM1637+DHT22' temp,humidity code.
http://www.filedropper.com/tm1637dht22
Can you combine two codes?
Please help me.
Sure you can. What is the resulting program supposed to do?
Thank you for answer.
I’ve merged two codes. (dotmatrix_clock + tm1637.dht22_temperature sensor)
The ‘DotMatrix clock’ works well, but …
‘TM1637 display’ does not work properly
Only once and then it stops.
Where is the wrong code? (no problem with the sketch upload.)
Merge_Code Check please~ (I checked ‘add----------------’)
Merge_Code.txt (46.8 KB)
