Code mixing RH_ASK & BLE-Keyboard failed
i am trying RH_ASK code mix with BLE-Keyboard(version 0.3.2).
it is my code-
#include <RH_ASK.h>
#ifdef RH_HAVE_HARDWARE_SPI
#include <SPI.h> // Not actually used but needed to compile
#include <BleKeyboard.h>
#endif
 RH_ASK driver(2000, 4, 5, 0); // pin_4 is RX , pin_5 is TX
BleKeyboard bleKeyboard;
int LED = 27;     //
int LED_1 = 14;
int LED_2 = 12;
int RF_SIGNAL = 13;
unsigned long old_milli = 0;
    pinMode(LED, OUTPUT);
    pinMode(LED_1, OUTPUT);
    pinMode(LED_2, OUTPUT);
    pinMode(RF_SIGNAL, OUTPUT);
       digitalWrite(LED_1, LOW);
       digitalWrite(LED_2, LOW);
       digitalWrite(RF_SIGNAL, HIGH);
       digitalWrite(LED,HIGH);
    Serial.println("Starting BLE work!");
    bleKeyboard.begin();
#ifdef RH_HAVE_SERIAL
#endif
if (!driver.init())
         Serial.println("init failed");
#else
#endif
delay(300);    digitalWrite(RF_SIGNAL, LOW);
    uint8_t buf[RH_ASK_MAX_MESSAGE_LEN];
    uint8_t buflen = sizeof(buf);
    if (driver.recv(buf, &buflen)) // Non-blocking
	int i;
  if (buf[0] == 11)  { Serial.println(" A ");      VOL ();}
    if (buf[0] == 21)  { Serial.println(" B ");    ESC ();  }
  if (buf[0] == 31)  { Serial.println("C ");       LEFT_LIGHT ();}
    if (buf[0] == 32)  { Serial.println("c ");       OFF ();}
    if (buf[0] == 41)  { Serial.println(" D ");   RIGHT_LIGHT ();  }
      if (buf[0] == 42)  { Serial.println(" d ");   OFF ();  }
  digitalWrite(RF_SIGNAL, HIGH);  old_milli = millis();
    if  (millis() > (old_milli + 300)) { digitalWrite(RF_SIGNAL, LOW); }
}   // -------------------------------------- END LOOP ------------------------------------
void LEFT_LIGHT () { digitalWrite(LED_1, HIGH);   digitalWrite(LED_2, LOW);     }
void RIGHT_LIGHT () { digitalWrite(LED_1, LOW);   digitalWrite(LED_2, HIGH);     }
void OFF () { digitalWrite(LED_1, LOW);   digitalWrite(LED_2, LOW);     }
void VOL () {    if(bleKeyboard.isConnected()) {    bleKeyboard.write(KEY_MEDIA_VOLUME_UP);  }   }
void ESC ()  {    if(bleKeyboard.isConnected()) {    bleKeyboard.write(KEY_ESC);  }   }
after uploading above code to esp32, Radio_head function are working good with
connected leds. my android bluetooth search "ESP32 Keyboard but not being connected. phone also state
but if remove RadioHead code all elements. it is connected and bluetooth keyboard functions working well.
please check my above mixed code . what is wrong in mixing. what code stop bluetooth connection. i want to use both of (RadioHead and Ble- keyboard functions ) here
.... thank you...
Cross post flagged.
Which Arduino board do you have?
What radio is RadioHead supposed to control and how is it wired?
@charnjit ,
Your other topic on the same subject deleted.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
