hi all . i have a code tat i got from a site . i need to add some more command to it .and i need some help
the code
int mA1 = 8;
int mA2 = 9;
int mB1 = 10;
int mB2 = 11;
void setup(){
pinMode(mA1, OUTPUT);
pinMode(mA2, OUTPUT);
pinMode(mB1, OUTPUT);
pinMode(mB2, OUTPUT);
void loop(){
if (Serial.available() > 0) {
char motors = Serial.read();
switch(motors) {
case 'R':
digitalWrite(mA1,LOW);
digitalWrite(mA2,HIGH);
digitalWrite(mB1,LOW);
digitalWrite(mB2,HIGH);
case 'L':
digitalWrite(mA1,HIGH);
digitalWrite(mA2,LOW);
digitalWrite(mB1,HIGH);
digitalWrite(mB2,LOW);
case 'U':
case 'D':
case 'C':
i want to add letter A , B for headlights , horns
thanks in advance
And which pins are these additional devices attached to, and how should they behave?
i want to connect a buzzer and some bright LED with a transistor or a relay
to any pin 7 to 3
And the second part of the question?
at the moment there is no devise attached arduino there than 2 motor to drive it .
How are the buzzer and the lights supposed to behave?
Attaching them is simple.
ok went sending letter A the buzzer should buzz 1 second delay and went sending letter B the LED must stay on.
So, you already know how to set the pin modes for the these, so now you need to look at the blink without delay example to see how to turn the buzzer off after one second (1000 milliseconds).
is this right see at the bottom
int mA1 = 8;
int mA2 = 9;
int mB1 = 10;
int mB2 = 11;
void setup(){
pinMode(13, OUTPUT);
void loop(){
switch(motors) {
case 'R':
case 'L':
case 'U':
case 'D':
case 'C':
case 'A':
digitalWrite(13, HIGH);
system
July 8, 2012, 7:53pm
10
Well, for safety, I'd add a break, but yes.
What does your testing show?
system
July 9, 2012, 6:06am
11
I will give it test asap . And tell u the result
system
July 9, 2012, 10:49am
12
when i sending "X and Y" the led works . on and off
but when i sending "H" even though i gave a delay of 1000 milliseconds it stays on .
i tried with and without break
int mA1 = 8;
int mA2 = 9;
int mB1 = 10;
int mB2 = 11;
void setup(){
pinMode(2, OUTPUT);
void loop(){
switch(motors) {
case 'R':
case 'L':
case 'F':
case 'B':
case 'S':
case 'X':
digitalWrite(2,HIGH);
case 'Z':
digitalWrite(2, LOW);
case 'H':
system
July 9, 2012, 10:53am
13
it stays on
Probably because you didn't switch it off.
Also, have another read of reply #7
system
July 9, 2012, 11:29am
15
but i gave a delay 1000
Yes, you delayed the loop by one second. (delayed, as in made it unresponsive for a whole second)
But you didn't turn the pin off.
system
July 9, 2012, 11:39am
16
how do i do tat
sorry for my lack of knowledge in coding
system
July 9, 2012, 11:41am
17
Like most digital operations, it is the opposite of turning it on, which you did just before the delay
system
July 9, 2012, 11:51am
18
so should i do this
case 'H':
digitalWrite(13, LOW);
system
July 9, 2012, 11:53am
19
That will turn it off after a second, yes, but it won't stop the "delay" making your loop unresponsive.
Suppose you've just turned on the horn, then notice you're about to slam into a wall.
The loop will not see your emergency stop command until a second later, which could be too late.
See reply #7
system
July 9, 2012, 12:06pm
20
thanks
i got both work now.
next planing to add pan & tilt
