Code modification
I need LED to be on for 2sec and off for 5sec without using delay function. How to modify the following code to do this?
const int ledPin1 = 13; // pin number for relay 1
int ledState1 = LOW; long previousMillis1 = 0; long interval1 = 2000; // interval at which to blink (milliseconds) for LED1 //long interval2 = 5000; // interval at which LED1 is off (milliseconds)
void LED1() //FUNCTION TO TURN ON AND OFF LED1. { unsigned long currentMillis = millis();
if(currentMillis - previousMillis1 > interval1) { previousMillis1 = currentMillis; if (ledState1 == LOW) ledState1 = HIGH; else ledState1 = LOW; digitalWrite(ledPin1, ledState1); } }
void setup() { pinMode(ledPin1, OUTPUT); // set the digital pin as output: }
void loop() { LED1(); }
Think: You're testing a variable, "interval1," to see if it's time to change the state of the LED. You want the ontime and the offtime to be different. You never change the value of "interval1."
What do you need to do?
  if(currentMillis - previousMillis1 > (ledState1 ? interval1 : interval2))
That's a shortcut version of:
  unsigned long interval;
  if (ledState1)
        interval = interval1;  //  LED stays ON for this time interval
        interval = interval2;  //  LED stays OFF for this time interval
  if(currentMillis - previousMillis1 > interval)
Thank you! I am very new to coding. So can you please show the whole code but not only idea. In my code blinking is with equal interval, but I need LED to be off for longer time. I am just learning.
unsigned long previousMillis1 = 0;
const unsigned long interval1 = 2000;          // interval at which to blink (milliseconds) for LED1
const unsigned long interval2 = 5000;     // interval at which LED1 is off (milliseconds)
    ledState1 = !ledState1;
  LED1();
http://www.gammon.com.au/blink
Thank you!
