[code] Nand Flash 4Mbit (512 Kbytes) - S71295 (SST
Just a quick code made to interface with a Flash chip. We used it on the www.Beat707.com design. (Rugged Circuits and Wusik)
/* Nand Flash 4Mbit (512 Kbytes) - S71295 (SST) */
#include <SPI.h>
char buf[16];
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
  #define FLASH_SSn 55
#else
  #define FLASH_SSn 15
#endif
  Serial.begin(38400);
  SPI.begin();
  SPI.setDataMode(SPI_MODE0);
  pinMode(FLASH_SSn, OUTPUT); digitalWrite(FLASH_SSn, HIGH);
    pinMode(11, INPUT); // Conflicts with SPI MOSI...do not use
    pinMode(13, INPUT); // Conflicts with SPI CLOCK...do not use
  #endif
  digitalWrite(FLASH_SSn, LOW);
  SPI.setBitOrder(MSBFIRST);
  flashInit();
  flashIDread();
  Serial.println("");
  Serial.println("Checking Non-Empty Sectors...");
  for (long x=0; x<128; x++)
    flashReadInit((4096UL*x));
    boolean sectorEmpty = true;
    for (int q=0; q<4096; q++)
      if (flashReadNext() != 0xFF) { sectorEmpty = false; break; }
    if (!sectorEmpty)
      Serial.print("Sector: ");
      if ((x+1) < 10) Serial.print("00"); else if ((x+1) < 100) Serial.print("0");
      Serial.println(x+1, DEC);
    flashReadFinish();
inline void volatile nop(void) { asm __volatile__ ("nop"); }
void flashEnable()    { SPI.setBitOrder(MSBFIRST); nop(); }
void flashDisable()   { SPI.setBitOrder(LSBFIRST); nop(); }
void flashWaitUntilDone()
  uint8_t data = 0;
  while (1)
    digitalWrite(FLASH_SSn,LOW);
    (void) SPI.transfer(0x05);
    data = SPI.transfer(0);
    digitalWrite(FLASH_SSn,HIGH);
    if (!bitRead(data,0)) break;
    nop();
void flashInit()
  flashEnable();
  SPI.transfer(0x50); //enable write status register instruction
  delay(50);
  SPI.transfer(0x01); //write the status register instruction
  SPI.transfer(0x00);//value to write to register - xx0000xx will remove all block protection
  delay(50);
  flashDisable();
void flashIDread()
  uint8_t id, mtype, dev;
  flashEnable();
  (void) SPI.transfer(0x9F); // Read ID command
  id = SPI.transfer(0);
  mtype = SPI.transfer(0);
  dev = SPI.transfer(0);
  char buf[16] = {0};
  sprintf(buf, "%02X %02X %02X", id, mtype, dev);
  Serial.print("SPI ID ");
  Serial.println(buf);
  flashDisable();
void flashTotalErase()
  flashEnable();
  SPI.transfer(0x06);//write enable instruction
  nop();
  (void) SPI.transfer(0x60); // Erase Chip //
  flashWaitUntilDone();
  flashDisable();
void flashSetAddress(uint32_t addr)
  (void) SPI.transfer(addr >> 16);
  (void) SPI.transfer(addr >> 8);
  (void) SPI.transfer(addr);
void flashReadInit(uint32_t address)
  flashEnable();
  (void) SPI.transfer(0x03); // Read Memory - 25/33 Mhz //
  flashSetAddress(address);
uint8_t flashReadNext() { return SPI.transfer(0); }
void flashReadFinish()
  flashDisable();
void flashWriteByte(uint32_t address, uint8_t data)
  flashEnable();
  nop();
  (void) SPI.transfer(0x02); // Write Byte //
  (void) SPI.transfer(data);
  flashDisable();
void flashSectorErase(uint8_t sectorAddress)
  flashEnable();
  nop();
  (void) SPI.transfer(0x20); // Erase 4KB Sector //
  flashSetAddress(4096UL*long(sectorAddress));
  flashDisable();
Hi, what is the exact type of the NAND flash you provided the code for? I need to program HY27US08121A or also made by Samsung or Elpida( with different names but same organization).
Hello, the chip used was this one: Nand Flash 4Mbit (512 Kbytes) - S71295 (SST)
No idea if it will work with yours, sorry.
This is NOT NAND-FLASH, this is SERIAL FLASH and they are completely different…
Which means that the code is WRONG for a Nand-Flash chip.
see here: http://www.sst.com/dotAsset/40490.pdf
and here: http://hardcoreforensics.com/blog/2012/01/02/arduino-mega-direct-reading-of-a-nand-flash-memory-chip
