const int buttonPin = 2;
const int ledPin = 13;
int wait_time = 10;
bool wait_finished = false;
// variables will change:
int buttonState = 0;
Serial.print("wait_finished set to true.");
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH || wait_finished == false) {
digitalWrite(ledPin, LOW);
wait_finished == false;
if (buttonState == LOW && wait_finished == true) {
digitalWrite(ledPin, HIGH);
else if (buttonState == LOW) {
wait();
void wait() {
if (wait_finished == false) {
delay(wait_time * 1000);
wait_finished = true;
Serial.println("wait_finished set to true.");
My goal is to wait for 10 seconds when the button is not pressed, then turn the LED on. However, after it waits for the first time, the LED would turn immediately on whenever I lift the button without waiting. What did I miss here?
if you have connected an external pullup resistor to the pin 2 this might work without a dirty, blocking delay():
const int buttonPin = 2; // was 2
const byte wait_time = 10; // in seconds
//bool wait_finished = false;
//int buttonState = 0;
Serial.begin(115200); // speed up for the year 2021
Serial.println(F("wait_finished set to true.")); // use F-Makro for fix text
pinMode(buttonPin, INPUT); // INPUT or INPUT_PULLUP
static uint32_t buttonReleaseMillis = 0;
static int previousButtonState = HIGH;
int buttonState = digitalRead(buttonPin);
if (buttonState == HIGH && previousButtonState == LOW) {
Serial.println(F("button was pressed"));
if (buttonState == LOW && previousButtonState == HIGH) {
Serial.println(F("button was released"));
buttonReleaseMillis = millis(); // remember the "time" when the button was released
if (buttonState == LOW && millis() - buttonReleaseMillis > wait_time * 1000UL && digitalRead(ledPin) == LOW) {
Serial.println(F("Alarm"));
previousButtonState = buttonState;
