code not compiling correctly
i have two different sketches obtained from http://www.freeduino.de/blog/nokia-1100-lcd-display
neither of them will compile and i cant figure it out
i figued one of the people more familiar with the code might spot the typo/formatting error thats catching me up
the first one on that link gives me
sketch_mar12a.cpp: In function 'void LcdCharacter(char)':
sketch_mar12a:116: error: invalid conversion from 'const byte*' to 'byte'
sketch_mar12a:116: error: initializing argument 2 of 'void LcdWrite(byte, byte)'
and the second one tells me
sketch_mar12a.cpp: In function 'void LcdPixel(byte, byte, int)':
sketch_mar12a:559: error: invalid conversion from 'byte*' to 'byte'
sketch_mar12a:578: error: incompatible types in assignment of 'byte' to 'byte [780]'
so lines 117 and 560/578 respectively
if this isnt the right place i apologize in advance
It would be really nice if you posted the code here so we know exactly what you're talking about.
However, if I'm reading this correctly, the problem is that the LcdCharacter function is trying to pass a pointer to a byte (ie an array) to the LcdWite function, which takes a normal byte.
To fix it, you're going to have to make LcdWrite take a byte (just change the start to:
void LcdWrite(byte, byte*) {
) and then make LcdWrite iterate over 5 lines rather than just using shiftOut once. I'm not sure how to do that, since it's pretty much hardware-dependent.
So, in essence: The code you've copied is incorrect.
EDIT: Actually, it's probably a better idea to not change the LcdWrite function and instead make LcdCharacter call LcdWrite 5 times, once for each row. However, it still depends on exactly what kind of hardware you have.
thank you for checking it out
i have an arduino uno r3 which i believe is compatible with dueminalove sketch's (atmega 328)
this is the first code the second one is too long to post here but is on the end of that page i linked to
// Arduino Dueminalove Atmega328
// Interfacing with the Nokia 1100 LCD, PCF8814
// Arduino pinout // Nokia 1100 LCD pinout (VDD & VDDI ==> 3.3V, VLED+ connected via 10 ohm resistor to 3.3V)
#define PIN_SCE 10 // 2 XCS Connected via resistor-voltage-divider 1.8K & 3.2K
#define PIN_SDIN 11 // 4 SDA
#define PIN_RESET 12 // 1 XRES
#define PIN_SCLK 13 // 5 SCLK
#define LCD_C LOW // Command
#define LCD_D HIGH // Data
static const byte ASCII[][5] ={
{0x00, 0x00, 0x00, 0x00, 0x00} // 20
,{0x00, 0x00, 0x5f, 0x00, 0x00} // 21 !
,{0x00, 0x07, 0x00, 0x07, 0x00} // 22 "
,{0x14, 0x7f, 0x14, 0x7f, 0x14} // 23 #
,{0x24, 0x2a, 0x7f, 0x2a, 0x12} // 24 $
,{0x23, 0x13, 0x08, 0x64, 0x62} // 25 %
,{0x36, 0x49, 0x55, 0x22, 0x50} // 26 &
,{0x00, 0x05, 0x03, 0x00, 0x00} // 27 '
,{0x00, 0x1c, 0x22, 0x41, 0x00} // 28 (
,{0x00, 0x41, 0x22, 0x1c, 0x00} // 29 )
,{0x14, 0x08, 0x3e, 0x08, 0x14} // 2a *
,{0x08, 0x08, 0x3e, 0x08, 0x08} // 2b +
,{0x00, 0x50, 0x30, 0x00, 0x00} // 2c ,
,{0x08, 0x08, 0x08, 0x08, 0x08} // 2d -
,{0x00, 0x60, 0x60, 0x00, 0x00} // 2e .
,{0x20, 0x10, 0x08, 0x04, 0x02} // 2f /
,{0x3e, 0x51, 0x49, 0x45, 0x3e} // 30 0
,{0x00, 0x42, 0x7f, 0x40, 0x00} // 31 1
,{0x42, 0x61, 0x51, 0x49, 0x46} // 32 2
,{0x21, 0x41, 0x45, 0x4b, 0x31} // 33 3
,{0x18, 0x14, 0x12, 0x7f, 0x10} // 34 4
,{0x27, 0x45, 0x45, 0x45, 0x39} // 35 5
,{0x3c, 0x4a, 0x49, 0x49, 0x30} // 36 6
,{0x01, 0x71, 0x09, 0x05, 0x03} // 37 7
,{0x36, 0x49, 0x49, 0x49, 0x36} // 38 8
,{0x06, 0x49, 0x49, 0x29, 0x1e} // 39 9
,{0x00, 0x36, 0x36, 0x00, 0x00} // 3a :
,{0x00, 0x56, 0x36, 0x00, 0x00} // 3b ;
,{0x08, 0x14, 0x22, 0x41, 0x00} // 3c <
,{0x14, 0x14, 0x14, 0x14, 0x14} // 3d =
,{0x00, 0x41, 0x22, 0x14, 0x08} // 3e >
,{0x02, 0x01, 0x51, 0x09, 0x06} // 3f ?
,{0x32, 0x49, 0x79, 0x41, 0x3e} // 40 @
,{0x7e, 0x11, 0x11, 0x11, 0x7e} // 41 A
,{0x7f, 0x49, 0x49, 0x49, 0x36} // 42 B
,{0x3e, 0x41, 0x41, 0x41, 0x22} // 43 C
,{0x7f, 0x41, 0x41, 0x22, 0x1c} // 44 D
,{0x7f, 0x49, 0x49, 0x49, 0x41} // 45 E
,{0x7f, 0x09, 0x09, 0x09, 0x01} // 46 F
,{0x3e, 0x41, 0x49, 0x49, 0x7a} // 47 G
,{0x7f, 0x08, 0x08, 0x08, 0x7f} // 48 H
,{0x00, 0x41, 0x7f, 0x41, 0x00} // 49 I
,{0x20, 0x40, 0x41, 0x3f, 0x01} // 4a J
,{0x7f, 0x08, 0x14, 0x22, 0x41} // 4b K
,{0x7f, 0x40, 0x40, 0x40, 0x40} // 4c L
,{0x7f, 0x02, 0x0c, 0x02, 0x7f} // 4d M
,{0x7f, 0x04, 0x08, 0x10, 0x7f} // 4e N
,{0x3e, 0x41, 0x41, 0x41, 0x3e} // 4f O
,{0x7f, 0x09, 0x09, 0x09, 0x06} // 50 P
,{0x3e, 0x41, 0x51, 0x21, 0x5e} // 51 Q
,{0x7f, 0x09, 0x19, 0x29, 0x46} // 52 R
,{0x46, 0x49, 0x49, 0x49, 0x31} // 53 S
,{0x01, 0x01, 0x7f, 0x01, 0x01} // 54 T
,{0x3f, 0x40, 0x40, 0x40, 0x3f} // 55 U
,{0x1f, 0x20, 0x40, 0x20, 0x1f} // 56 V
,{0x3f, 0x40, 0x38, 0x40, 0x3f} // 57 W
,{0x63, 0x14, 0x08, 0x14, 0x63} // 58 X
,{0x07, 0x08, 0x70, 0x08, 0x07} // 59 Y
,{0x61, 0x51, 0x49, 0x45, 0x43} // 5a Z
,{0x00, 0x7f, 0x41, 0x41, 0x00} // 5b [
,{0x02, 0x04, 0x08, 0x10, 0x20} // 5c ¥
,{0x00, 0x41, 0x41, 0x7f, 0x00} // 5d ]
,{0x04, 0x02, 0x01, 0x02, 0x04} // 5e ^
,{0x40, 0x40, 0x40, 0x40, 0x40} // 5f _
,{0x00, 0x01, 0x02, 0x04, 0x00} // 60 `
,{0x20, 0x54, 0x54, 0x54, 0x78} // 61 a
,{0x7f, 0x48, 0x44, 0x44, 0x38} // 62 b
,{0x38, 0x44, 0x44, 0x44, 0x20} // 63 c
,{0x38, 0x44, 0x44, 0x48, 0x7f} // 64 d
,{0x38, 0x54, 0x54, 0x54, 0x18} // 65 e
,{0x08, 0x7e, 0x09, 0x01, 0x02} // 66 f
,{0x0c, 0x52, 0x52, 0x52, 0x3e} // 67 g
,{0x7f, 0x08, 0x04, 0x04, 0x78} // 68 h
,{0x00, 0x44, 0x7d, 0x40, 0x00} // 69 i
,{0x20, 0x40, 0x44, 0x3d, 0x00} // 6a j
,{0x7f, 0x10, 0x28, 0x44, 0x00} // 6b k
,{0x00, 0x41, 0x7f, 0x40, 0x00} // 6c l
,{0x7c, 0x04, 0x18, 0x04, 0x78} // 6d m
,{0x7c, 0x08, 0x04, 0x04, 0x78} // 6e n
,{0x38, 0x44, 0x44, 0x44, 0x38} // 6f o
,{0x7c, 0x14, 0x14, 0x14, 0x08} // 70 p
,{0x08, 0x14, 0x14, 0x18, 0x7c} // 71 q
,{0x7c, 0x08, 0x04, 0x04, 0x08} // 72 r
,{0x48, 0x54, 0x54, 0x54, 0x20} // 73 s
,{0x04, 0x3f, 0x44, 0x40, 0x20} // 74 t
,{0x3c, 0x40, 0x40, 0x20, 0x7c} // 75 u
,{0x1c, 0x20, 0x40, 0x20, 0x1c} // 76 v
,{0x3c, 0x40, 0x30, 0x40, 0x3c} // 77 w
,{0x44, 0x28, 0x10, 0x28, 0x44} // 78 x
,{0x0c, 0x50, 0x50, 0x50, 0x3c} // 79 y
,{0x44, 0x64, 0x54, 0x4c, 0x44} // 7a z
,{0x00, 0x08, 0x36, 0x41, 0x00} // 7b {
,{0x00, 0x00, 0x7f, 0x00, 0x00} // 7c |
,{0x00, 0x41, 0x36, 0x08, 0x00} // 7d }
,{0x10, 0x08, 0x08, 0x10, 0x08} // 7e ?
,{0x78, 0x46, 0x41, 0x46, 0x78} // 7f ?
void LcdCharacter(char character){
LcdWrite(LCD_D, 0x00);
for (int index = 0; index < 5; index++)
LcdWrite(LCD_D, ASCII[character - 0x20]
void LcdClear(void){
for (int index = 0; index < 864 ; index++)
void LcdInitialise(void){
digitalWrite(PIN_RESET, LOW);
digitalWrite(PIN_RESET, HIGH);
LcdWrite(LCD_C, 0x2F); // Charge pump ON
LcdWrite(LCD_C, 0x24); // Vop MSB *Don't change*
LcdWrite(LCD_C, 0x80); // Vop LSB *Here you can change contrast*
LcdWrite(LCD_C, 0xA4); // A4 = normal display mode, A5 = all pixels ON
LcdWrite(LCD_C, 0xAF); // Display ON
void LcdString(char *characters){
while (*characters){
LcdCharacter(*characters++);
void LcdWrite(byte dc, byte data){
digitalWrite(PIN_SDIN, dc); // dc is sampled with the first rising SCLK edge
digitalWrite(PIN_SCE, LOW); // LCD enable
digitalWrite(PIN_SCLK, HIGH); // First rising SCLK edge
digitalWrite(PIN_SCLK, LOW);
shiftOut(PIN_SDIN, PIN_SCLK, MSBFIRST, data); // SDIN is sampled at the rising edge of SCLK.
digitalWrite(PIN_SCE, HIGH);
void setup(void){
pinMode(PIN_SCE, OUTPUT);
pinMode(PIN_RESET, OUTPUT);
pinMode(PIN_SDIN, OUTPUT);
pinMode(PIN_SCLK, OUTPUT);
LcdInitialise();
LcdClear();
LcdWrite(LCD_C, 0xA7); // Inverted display
delay(200);
LcdWrite(LCD_C, 0xA6); // Normal display
void loop(void){
LcdString("Nokia 1100 LCD says Hello World");
delay(5000);
LcdInitialise();
Moderator edit: CODE TAGS. You forgot the CODE TAGS
ok i got it to compile and am about to start testing (gotta find some small resistors)
i just searched for the beginning of this code section on google and found a 99% similar one (syntax?)
i figure its best to break it down and understand it
original code
new code
    LcdWrite(LCD_D, ASCII[character - 0x20][index]);
after comparing the two i figured out that it wont compile without LcdWrite(LCD_D, ASCII[character - 0x20][index]); instead of LcdWrite(LCD_D, ASCII[character - 0x20] );
(the addition of [index] on the end)
#define PIN_SCE 3 // 2 XCS Connected via resistor-voltage-divider 1.8K & 3.2K
#define PIN_SDIN 4 // 4 SDA
#define PIN_RESET 5 // 1 XRES
#define PIN_SCLK 6 // 5 SCLK
const int buttonPin = 12;     // the number of the pushbutton pin
,{0x10, 0x08, 0x08, 0x10, 0x08} // 7e ←
,{0x78, 0x46, 0x41, 0x46, 0x78} // 7f →
int buttonState = 0;         // variable for reading the pushbutton status
LcdWrite(LCD_C, 0x23); // CONTRAST?
void setup(void){
pinMode(buttonPin, INPUT);
LcdInitialise();
LcdClear();
delay(200);
void loop(void){
buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    // turn LED on:
    LcdClear();
    LcdString(":-)DAMNIT I SAID DONT DO THAT !!");
    delay(2500);
    LcdInitialise();
    LcdClear();
  else {
    // turn LED off:
    LcdString("DONT PUSH MY BUTTONS");
    LcdInitialise();
this one is workin and it has a button routine built in (pin 12 high)
Hello,
Can you tell me how you connected the LCD to the Arduino.
Or can you make a wiring drawing of it.
Manny thanks
