Code not exiting While loop
I am building a project where a while loop continues until a button is pressed. The button sets x as 1, which terminates the loop. However, the loop does not end. Any suggestions?
int a = 0;
int b = 0;
int x = 0;
int PotSenValue = 0;
int SoilSenValue = 0;
int ButtonState = 0;
const int Pump = 2;
const int LedPin= 1;
const int Button = 0;
const int SoilSen = A2;
const int PotSen = A3;
  pinMode(Pump, OUTPUT);
  pinMode(LedPin, OUTPUT);
  pinMode(Button, INPUT);
  while (x < 1) {
   int PotSenValue = analogRead(PotSen);
   if (PotSenValue < 505) {
    int a = 0.5 * (505 - PotSenValue);
    digitalWrite(LedPin, HIGH);
    delay(a);
    digitalWrite(LedPin, LOW);
    delay(a);
  else if (PotSenValue > 515) {
    int b = 0.5 * (PotSenValue - 505);
    delay(b);
    delay(b);
  else if ( (PotSenValue > 505) && (PotSenValue < 515) ) { //This is the part where the button will end the loop upon press
      ButtonState = digitalRead(Button);
      if (ButtonState == HIGH) {
        int x = 1;
        delay(100);
  delay(100);
  } //End of the While loop
//The rest of the code will repeat here forever
int x = 0;
There you already declare a variable x of type int.
        int x = 1;
        delay(100);
And now, you are re-declaring it. Remove int from x.
Also, your code does not compile? Did you miss one more curly braces?
Awesome thanks. I sill compiles, but I will remove the second 'int' tonight.
If that doesn't close the while loop I am thinking of perhaps replacing the x = 1; with a break; statement and declaring x = 1 outside the loop. I'll work on it tonight and keep you posted. Thanks for the advice.
Your code as it is compiles OK because the two x variables that you declare have different scopes, so it is valid code but is not doing what you want.
Google "C variable scope" for more information.
