The code and setup I am working with are meant to do is control a RBG LED through a On/Off/On Switch and 2 potentiometers, the potentiometers control brightness and color and the switch toggles the program between keeping a solid color (chosen by the potentiometer) being off and changing colors automatically (sort of a light show)
now as for the problem, when I put this code into my arduino and load it up, everything works splendidly, but then when I put it on my own microcontroller circuit all hell breaks loose, well that might be a slight exageration.. what happens is the program keeps thinking that it should switch to the light show mode even when no power is given that input or if its in solid color mode, it will either blink (going from off to the show in intervals about one second) or if it is in solid color mode it will switch from one mode to another in similar intervals. the show functions as it should once the input is ACTUALLY recieving power.
A description of my setup, I'm using an atmega 328 with an arduino bootloader, programmed by simply putting it in the arduino uno and then taking it out once its programmed, for power regulation i am using a 100 uf capacitor with a .01 uf capacitor to filter out undesirable frequencies, and for the clock i am using a 16mhz crystal with 2 22pf capacitors. I've been killing myself over this for days, if anyone has any ideas, you'll be my savior..
const int buttonLightPin = A3; //sets buttonLight to input 12
const int buttonShowPin = A5; //sets buttonShow to input 13
const int brightnessPotPin = A0; //sets the pot output to A0
const int colorPotPin = A1; // sets the color during solid light
int brightnessPotState; //variable for storing the value of the brightness pot
float brightnessSet =1; // variable for storing the brightness level
int buttonState = 2; // variable for storing the mode that the devvice is in
// 0 is for off, 1 is for light show and 2 is for solid color
int PIN_RED = 3; // input for red; red jumper, white cord
int PIN_GREEN = 5; // input for green; green jumper
int PIN_BLUE = 9; //input for blue; red jumper, yellow cord
int counter;
int numColors = 255;
int animationDelay = 15; //adjustable speed of animation
float brightness = 0; // default brightness level
int lag = 15;
int showCounter = 0;
int lightCounter = 0;
int offCounter = 0;
pinMode(buttonLightPin, INPUT);
pinMode(buttonShowPin, INPUT);
pinMode(brightnessPotPin, INPUT_PULLUP);
pinMode(colorPotPin, INPUT_PULLUP);
pinMode(PIN_RED, OUTPUT);
pinMode(PIN_BLUE, OUTPUT);
pinMode(PIN_GREEN, OUTPUT);
Serial.print("Begin");
float colorNumber = counter > numColors ? counter - numColors: counter;
float saturation = 1; // Between 0 and 1 (0 = gray, 1 = full color)
float hue = (colorNumber / float(numColors)) * 360;
float brightness = setBrightness();
long color = HSBtoRGB(hue, saturation, brightness);
int red = color >> 16 & 255;
int green = color >> 8 & 255;
int blue = color & 255;
buttonState = setButtonState(); //function below for determining button state
Serial.print(" MODE: ");
if(buttonState == 1) // if buttonstate is 1, light show will commence
showCounter++;
if(showCounter > 10)
lightCounter = 0;
offCounter = 0;
Serial.print("SHOW");
setColor(red, green, blue); //writes the color chosen by HSBtoRGB
Serial.print(" Red: ");
Serial.print(red);
Serial.print("\t");
Serial.print(" Green: ");
Serial.print(green);
Serial.print("\t");
Serial.print(" Blue: ");
Serial.print(blue);
counter = (counter + 1) % (numColors * 2); // sets counter to increment the color changes
delay(animationDelay);
else if(buttonState == 2) // if buttonstate is 2, LEDs will emit solid colors determined by the colorPotPin
lightCounter++;
if(lightCounter > 10)
showCounter = 0;
offCounter = 0;
Serial.print("SOLID COLOR");
solidColor(brightness);
else if(buttonState == 0) // if buttonstate is 0, no light will emit
offCounter++;
if(offCounter > 10)
lightCounter = 0;
showCounter = 0;
Serial.print("OFF");
off();
Serial.print("\t");
Serial.println("END");
float setBrightness() // finds brightness from pot
float brightnessPotState; //variable for storing the value of the brightness pot
brightnessPotState = analogRead(brightnessPotPin); //reads brightness
Serial.print(" Brightness Pot: ");
Serial.print(brightnessPotState);
if(brightnessPotState <= 1000) // converts pot input(0-1023) into a percentage
//i ignored the final 23 values and lumped it into a solid 100%
brightnessSet = brightnessPotState/1000;
brightnessSet = 1;
return brightnessSet; // returns the percentage brightness
int setButtonState() //toggles between Show, Light, and off
int buttonShow; // variable storing the value of the buttonShowPin
int buttonLight; //variable storing the value of the buttonLightPin
int x;
buttonShow = digitalRead(buttonShowPin);
buttonLight = digitalRead(buttonLightPin);
Serial.print("\t");
Serial.print (" Button Show: ");
Serial.print (buttonShow);
Serial.print ("\t");
Serial.print (" Button Light: ");
Serial.print (buttonLight);
if (buttonShow == HIGH)
return(1);
else if( buttonLight == HIGH)
return(2);
else if(buttonLight == LOW && buttonShow == LOW)
return(0);
void off() // turns off all LEDs
analogWrite(PIN_RED, LOW);
analogWrite(PIN_GREEN, LOW);
analogWrite(PIN_BLUE, LOW);
void solidColor(float brightness) //sets the color for light mode
int redSolid;
int blueSolid;
int greenSolid;
float colorPotState; //varible for storing the value of the color pot
colorPotState = analogRead(colorPotPin);
Serial.print("Color Pot State: ");
Serial.print(colorPotState);
if (colorPotState < 341) //first 1/3 of the pots potential value
colorPotState= (colorPotState * 3)/4; // converts pot value into a 0-255 range
redSolid = (256 - colorPotState) * brightness; //full to 0
greenSolid = colorPotState * brightness; // 0 to full
blueSolid = 1; //off
else if(colorPotState < 682) //second 1/3 of the pots potential value
colorPotState= ((colorPotState-341) * 3)/4; // converts pot value into a 0-255 range
redSolid = 1; //off
greenSolid = (256 - colorPotState) * brightness; //full to 0
blueSolid = colorPotState * brightness; // 0 to full
else // Remainder of the pots value
colorPotState= ((colorPotState-683) * 3)/4; // converts pot value into a 0-255 range
redSolid = colorPotState * brightness; // 0 to full
greenSolid = 1; //off
blueSolid = (256 - colorPotState) * brightness; //full to 0
Serial.print(redSolid);
Serial.print("\t");
Serial.print(greenSolid);
Serial.print("\t");
Serial.print("\t");
Serial.print(blueSolid);
analogWrite(PIN_RED, redSolid); //set red level based on pot value
analogWrite(PIN_GREEN, greenSolid); //set green level based on pot value
analogWrite(PIN_BLUE, blueSolid); //set blue level based on pot value
void setColor (unsigned char red, unsigned char green, unsigned char blue) //sets the color for each instance of the show
analogWrite(PIN_RED, red); // set red leve
analogWrite(PIN_GREEN, green); // set red leve
analogWrite(PIN_BLUE, blue); // set red leve
long HSBtoRGB(float _hue, float _sat, float _brightness) //interprets and changes the color
float red = 0.0; // initialize local variables
float green = 0.0;
float blue = 0.0;
if (_sat == 0.0) // if there is no saturation, the color will turn off
red = _brightness;
green = _brightness;
blue = _brightness;
if (_hue == 360.0) // when hue reaches 360, it resets to 0
_hue = 0;
int slice = _hue / 60.0; // initializes varible to break the process into 6 "slices"
float hue_frac = (_hue / 60.0) - slice; // each slice is one 6th of the process
float aa = _brightness * (1.0 - _sat); // sets the 3 different functions for increasing and decreasing color based on saturation, brightness, and hue
float bb = _brightness * (1.0 - _sat * hue_frac);
float cc = _brightness * (1.0 - _sat * (1.0 - hue_frac));
switch(slice) //depending on which slice the program is in, it will pick one of these options to adjust the color
case 0:
red = _brightness;
green = cc;
blue = aa;
case 1:
red = bb;
blue = aa;
case 2:
red = aa;
blue = cc;
case 3:
red = aa;
green = bb;
blue = _brightness;
case 4:
red = cc;
green = aa;
blue = _brightness;
case 5:
red = _brightness;
green = aa;
blue = bb;
default:
red = 0.0;
green = 0.0;
blue = 0.0;
long ired = red * 255.0; // set red
long igreen = green * 255.0; // set gren
long iblue = blue * 255.0; // set blue
return long((ired << 16) | (igreen << 8) | (iblue)); // return colors
Sounds like the input pin is floating when the button is not pressed. I assume (as the code does not turn on the internal pullup on A5) that there is a external pull-down resistor on that pin?
austinphilp:
for power regulation I am using a 100 µf capacitor with a .01 µf capacitor to filter out undesirable frequencies,
Just as a matter of curiosity, what are you using as a regulator?
And ...
Why are you defining the analog inputs as INPUT_PULLUP (that might actually work, but I don't know whether it does; you may have researched it more closely), but not the pushbutton inputs?
Paul__B:
Yes you can turn on the pull-up resistor for an analog input. However, any analog readings that are taken, need to take into account that now a voltage divider is setup on that pin.
How do I take it into account? i changed all of the analog inputs to INPUT_PULLUP and now my serial output is telling me that all both modes are active when neither are recieving power?
And ...
I assume you mean besides the capacitors? a switching 5v power supply i bought online (https://www.sparkfun.com/products/8269), my use of input pullup was based off of advice from someone on this forum when designing my code, im not 100% sure..
no, there is no internal or external pullup/ pulldown on that pin, but as I said above turning it on made both inputs think they're recieving power..
austinphilp:
That's how pull-up works (internal or external). They "pull" the pin "up" to whatever voltage their connected to. In this case it is 5volts.
It's not the potentiometer it's the switch, I'll use a jumper to simulate switch inputs but it doesn't make a difference, it thinks both inputs are on when using the pull-up resistor, I'm not home so I can't draw up a schematic right now but if u still need it when I get home ill work it up
austinphilp:
Again, that's how pull-ups work. The pin is "HIGH" when there is no connection (or the switch is off) and the pin is "LOW" when the switch is closed. The code doesn't care if "high" means "on" or "off".
CMOS inputs - as on the Arduino - are very high impedance, which means that unless connected to something, the voltage they see could be absolutely anything (between 0 and Vcc, since internal diodes prevent the voltage going outside that range) and can or will present a fairly random digital state.
When using a switch, you need to arrange it so that when the switch is on, the input is at one particular logic level, and when it is off, the input goes to the other logic level. The preferred way of doing this is to have the switch (button) connect from the input to ground, and have a resistor "pull-up" from the input to Vcc so that when the switch is pressed, the input reads low, when it is not pressed, the resistor pulls the input up and the input reads high.
Such a resistor is provided internally in the Arduino chip and is enabled on an input when that port is written to as "high" even though it is actually defined as an input. When the switch pulls the input low, some small current (about 500 µA) necessarily flows from the resistor, but that is no particular problem. You need then to write your code understanding that a high corresponds to the button not pressed, and a low to it being pressed.
Enabling that pull-up on a port used as an analog input effectively puts a 10k ohm resistor between the port and Vcc, which is then in your case, between the wiper of the potentiometer and the end connected to Vcc and will tend to bias the voltage read from the potentiometer, upward making it non-linear. On the other hand, should the potentiometer for whatever reason be not connected, it will reliably substitute a reading near to maximum, which may be a useful safety feature.
Its fixed!! thank you so much paul, your explanation did help, Ive set the code to interpret high inputs as off and ive wired the switch to the ground, when the ground is applied to either input it turns it to that mode with no blinking or switching! thank you so much!
