hey guys, not sure what is the problem here, its not my code its a example i got off the interweb for a count down timer with a rotary encoder but keeps giving this errorArduino: 1.8.12 (Windows 7), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
sketch_may26a:100:15: error: stray '\342' in program
hours = hours β 1;
sketch_may26a:100:16: error: stray '\200' in program
hours = hours β 1;
sketch_may26a:100:17: error: stray '\223' in program
hours = hours β 1;
sketch_may26a:104:19: error: stray '\342' in program
minutes = minutes β 1;
sketch_may26a:104:20: error: stray '\200' in program
sketch_may26a:104:21: error: stray '\223' in program
sketch_may26a:126:19: error: stray '\342' in program
seconds = seconds β 1;
sketch_may26a:126:20: error: stray '\200' in program
sketch_may26a:126:21: error: stray '\223' in program
C:\Users\timothy\AppData\Local\Temp\arduino_modified_sketch_787141\sketch_may26a.ino: In function 'void loop()':
sketch_may26a:100:19: error: expected ';' before numeric constant
hours = hours β 1;
sketch_may26a:104:23: error: expected ';' before numeric constant
sketch_may26a:126:23: error: expected ';' before numeric constant
exit status 1
option enabled in File -> Preferences.
#include <Wire.h>
LiquidCrystal_I2C lcd(0x3f, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address
#define Start 4 // start stop button
int hours = 0;
int minutes = 0;
int seconds = 0;
boolean timeState = false;
#define encoderPinA 2 // right
#define encoderPinB 3 // left
#define encoderButton 5 // switch
int HMS = 1;
int encoderPos = 0; // a counter for the dial
unsigned int lastReportedPos = 1; // change management
static boolean rotating = false; // debounce management
boolean A_set = false;
boolean B_set = false;
pinMode(Start, INPUT_PULLUP);
pinMode(encoderPinA, INPUT_PULLUP); //enabling pullups
pinMode(encoderPinB, INPUT_PULLUP);
pinMode(encoderButton, INPUT_PULLUP);
attachInterrupt(0, doEncoderA, CHANGE); //pin 2
attachInterrupt(1, doEncoderB, CHANGE); //pin 3
Serial.begin(9600); // output
lcd.begin(16, 2); // initialize the lcd for 16 chars 2 lines, turn on backlight
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("COUNT DOWN TIMER");
lcd.setCursor(4, 1);
lcd.print("00:00:00");
if (digitalRead(encoderButton) == LOW)
HMS = HMS + 1;
if (HMS == 4)
HMS = 1;
rotating = true; // reset the debouncer
encoderPos = constrain(encoderPos, -1, 1);
if (lastReportedPos != encoderPos) {
if (HMS == 1) {
hours = hours + encoderPos;
hours = constrain(hours, 0, 48);
else if (HMS == 2) {
minutes = minutes + encoderPos;
minutes = constrain(minutes, 0, 60);
else if (HMS == 3) {
seconds = seconds + encoderPos;
seconds = constrain(seconds, 0, 60);
// Serial.println(encoderPos); // for testing
// Serial.print("hours ");
// Serial.println(hours);
// Serial.print("minutes ");
// Serial.println(minutes);
// Serial.print("seconds ");
// Serial.println(seconds);
// Serial.println(" ");
if (hours <= 9)
lcd.print("0");
lcd.print(hours);
lcd.print(":");
if (minutes <= 9)
lcd.print("0");
lcd.print(minutes);
lcd.print(":");
if (seconds <= 9)
lcd.print("0");
lcd.print(seconds);
encoderPos = 0;
lastReportedPos = encoderPos;
if (digitalRead(Start) == LOW) { //start count down timer
timeState = true;
//delay(1000);
while (timeState == true) {
if (minutes == 0 && hours >= 1) {
minutes = 60;
hours = hours β 1;
if (seconds == 0 && minutes >= 1) {
seconds = 60;
else if (minutes == 0 && hours == 0 && seconds == 0) { //count down alarm
tone(11, 600, 250);
delay(250);
tone(11, 800, 250);
delay(250);
if (digitalRead(Start) == LOW) { // turn alarm off
timeState = false;
seconds = 1; /////////////////////////////////////////////
lcd.clear();
delay(992); // delay for keping time master setting!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
//Serial.print(βhours β); // for testing
//Serial.println(hours);
//Serial.print(βminutes β);
//Serial.println(minutes);
//Serial.print(βseconds β);
//Serial.println(" ");
if (hours <= 9)
lcd.print("0");
lcd.print(hours);
lcd.print(":");
if (minutes <= 9)
lcd.print("0");
lcd.print(minutes);
lcd.print(":");
if (seconds <= 9)
lcd.print("0");
lcd.print(seconds);
timeState = false;
// Interrupt on A changing state
void doEncoderA() {
// debounce
if ( rotating ) delay (1); // wait a little until the bouncing is done
// Test transition, did things really change?
if ( digitalRead(encoderPinA) != A_set ) { // debounce once more
A_set = !A_set;
// adjust counter + if A leads B
if ( A_set && !B_set )
encoderPos = 1;
rotating = false; // no more debouncing until loop() hits again
// Interrupt on B changing state
void doEncoderB() {
if ( digitalRead(encoderPinB) != B_set ) {
B_set = !B_set;
// adjust counter β 1 if B leads A
if ( B_set && !A_set )
encoderPos = -1;
rotating = false;
