I have modified a code so a selfdrivng car that can take the input from two ultrasoundsensensors but it is not working, help. This is my code before I modified it and it works:
Förformatterad text
#include <Servo.h>
int pinLB=6; // define pin6 as left back connect with IN1
int pinLF=9; // define pin9 as left forward connect with IN2
int pinRB=10; // define pin10 as right back connect with IN3
int pinRF=11; // define pin11 as right back connect with IN4
int inputPin = A0; // define ultrasonic receive pin (Echo)
int outputPin =A1; // define ultrasonic send pin(Trig)
int Fspeedd = 0; // forward distance
int Rspeedd = 0; // right distance
int Lspeedd = 0; // left distance
int directionn = 0; //
Servo myservo; // new myservo
int delay_time = 250; // set stable time
int Fgo = 8;
int Rgo = 6;
int Lgo = 4;
int Bgo = 2;
// forward
// turn right
// turn left
// back
pinMode(pinLB,OUTPUT);
pinMode(pinLF,OUTPUT);
pinMode(pinRB,OUTPUT);
pinMode(pinRF,OUTPUT);
pinMode(inputPin, INPUT);
pinMode(outputPin, OUTPUT);
myservo.attach(5); // define the servo pin(PWM)
void advance(int a) // forward
digitalWrite(pinRB,LOW);
digitalWrite(pinRF,HIGH);
digitalWrite(pinLB,LOW);
digitalWrite(pinLF,HIGH);
delay(a * 15);
void turnR(int d) //turn right
digitalWrite(pinLB,HIGH);
digitalWrite(pinLF,LOW);
delay(d * 50);
void turnL(int e) //turn left
digitalWrite(pinRB,HIGH);
digitalWrite(pinRF,LOW);
delay(e * 50);
void stopp(int f) //stop
delay(f * 100);
void back(int g) //back
delay(g * 300);
void detection() //test the distance of different direction
delay(200);
ask_pin_F(); // read forward distance
if(Fspeedd < 25) // if distance less then 10
stopp(1);
back(2);
stopp(1);
ask_pin_L();
delay(delay_time);
ask_pin_R();
delay(delay_time);
if(Lspeedd > Rspeedd) //if left distance more than right distance
directionn = Rgo;
if(Lspeedd <= Rspeedd)//if left distance not more than right
//distance
directionn = Lgo;
//if left if (Lspeedd < 10 && Rspeedd < 10) distance and right
//distance both less than 10
directionn = Bgo;
directionn = Fgo; // forward go
void ask_pin_F() // test forward distance
myservo.write(90);
digitalWrite(outputPin, LOW);
delayMicroseconds(2);
digitalWrite(outputPin, HIGH);
delayMicroseconds(10);
float Fdistance = pulseIn(inputPin, HIGH);
Fdistance= Fdistance/5.8/10;
Serial.print("F distance:");
Serial.println(Fdistance);
Fspeedd = Fdistance;
void ask_pin_L() // test left distance
myservo.write(150);
delay(delay_time);
float Ldistance = pulseIn(inputPin, HIGH);
Ldistance= Ldistance/5.8/10;
Serial.print("L distance:");
Serial.println(Ldistance);
Lspeedd = Ldistance;
void ask_pin_R() // test right distance
myservo.write(20);
delay(delay_time);
float Rdistance = pulseIn(inputPin, HIGH);
Rdistance= Rdistance/5.8/10;
Serial.print("R distance:");
Serial.println(Rdistance);
Rspeedd = Rdistance;
myservo.write(90);
detection();
if(directionn == 2)
back(3);
turnL(2);
Serial.print(" Reverse ");
if(directionn == 6)
back(1);
turnR(6);
Serial.print(" Right ");
if(directionn == 4)
back(1);
turnL(6);
Serial.print(" Left ");
if(directionn == 8)
advance(1);
Serial.print(" Advance ");
Serial.print(" ");
}Förformatterad text
And this is the code after I modified it:
Förformatterad text
#include <Servo.h>
int inputPin1 = A0; // define ultrasonic receive pin (Echo)
int outputPin1 =A1; // define ultrasonic send pin(Trig)
int inputPin2 = A5; // define obi wan receive pin
int outputPin2 =A5; // define obi wan send pin
int Bspeedd = 0; // back distance
Servo myservo1; // new myservo
Servo myservo2;
int Fgo = 8;
int Rgo = 6;
int Lgo = 4;
int Bgo = 2;
// forward
// turn right
// turn left
// back
pinMode(inputPin1, INPUT);
pinMode(outputPin1, OUTPUT);
myservo1.attach(5); // define the servo pin(PWM)
pinMode(inputPin2, INPUT);
pinMode(outputPin2, OUTPUT);
myservo2.attach(3); // define the servo pin(PWM)
delay(a * 15);
delay(d * 50);
delay(e * 50);
delay(f * 100);
delay(g * 1);
myservo1.write(90);
digitalWrite(outputPin1, LOW);
digitalWrite(outputPin1, HIGH);
float Fdistance = pulseIn(inputPin1, HIGH);
void ask_pin_B()
myservo2.write(90);
digitalWrite(outputPin2, LOW);
digitalWrite(outputPin2, HIGH);
float Bdistance = pulseIn(inputPin2, HIGH);
Bdistance= Bdistance/5.8/10;
Serial.print("B distance:");
Serial.println(Bdistance);
Bspeedd = Bdistance;
myservo1.write(150);
delay(delay_time);
float Ldistance = pulseIn(inputPin1, HIGH);
myservo2.write(20);
delay(delay_time);
float Rdistance = pulseIn(inputPin2, HIGH);
myservo1.write(20);
delay(delay_time);
float Rdistance = pulseIn(inputPin1, HIGH);
myservo2.write(150);
delay(delay_time);
float Ldistance = pulseIn(inputPin2, HIGH);
delay(200);
if(Fspeedd < 20) // if distance less then 10
stopp(1);
back(2);
delay(200);
ask_pin_B(); // read forward distance
if(Bspeedd < 20) // if distance less then 10
stopp(1);
back(2);
if(Bspeedd < 25) // if distance less then 10
stopp(1);
ask_pin_L();
delay(delay_time);
ask_pin_R();
delay(delay_time);
directionn = Rgo;
//distance
directionn = Lgo;
directionn = Bgo;
myservo.write(90);
detection();
if(directionn == 2)
back(3);
turnL(2);
if(directionn == 6)
back(1);
turnR(6);
if(directionn == 4)
back(1);
turnL(6);
if(directionn == 8)
advance(1);
Serial.print(" ");
