Code not working on Arduino cloud
Below is a code for fall detection using MPU6050 accelerometer which works fine on serial monitor but as it's made an IoT using arduino cloud. It gets slowed down and doesn't work when a fall is triggered or needs more intense fall. Is there any timing/delay issues or difference between working of arduino cloud and arduino offline?
#include <Wire.h>
int bzr = 2;
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_WROVER_BOARD
//#define USE_TTGO_T7
const int MPU_addr = 0x68; // I2C address of the MPU-6050
 int16_t AcX, AcY, AcZ, Tmp, GyX, GyY, GyZ;
 float ax = 0, ay = 0, az = 0, gx = 0, gy = 0, gz = 0;
 boolean fall = false; //stores if a fall has occurred
 boolean trigger1 = false; //stores if first trigger (lower threshold) has occurred
 boolean trigger2 = false; //stores if second trigger (upper threshold) has occurred
 boolean trigger3 = false; //stores if third trigger (orientation change) has occurred
 byte trigger1count = 0; //stores the counts past since trigger 1 was set true
 byte trigger2count = 0; //stores the counts past since trigger 2 was set true
 byte trigger3count = 0; //stores the counts past since trigger 3 was set true
 int angleChange = 0;
void sendSensor()
   mpu_read();
   ax = (AcX - 2050) / 16384.00;
   ay = (AcY - 77) / 16384.00;
   az = (AcZ - 1947) / 16384.00;
   gx = (GyX + 270) / 131.07;
   gy = (GyY - 351) / 131.07;
   gz = (GyZ + 136) / 131.07;
   // calculating Amplitute vactor for 3 axis
   float Raw_Amp = pow(pow(ax, 2) + pow(ay, 2) + pow(az, 2), 0.5);
   int Amp = Raw_Amp * 10;  // Mulitiplied by 10 bcz values are between 0 to 1
   Serial.println(Amp);
if (Amp <= 2 && trigger2 == false) { //if AM breaks lower threshold (0.4g)
trigger1 = true;
Serial.println("TRIGGER 1 ACTIVATED");
if (trigger1 == true) {
trigger1count++;
if (Amp >= 12) { //if AM breaks upper threshold (3g)
       trigger2 = true;
       Serial.println("TRIGGER 2 ACTIVATED");
       trigger1 = false; trigger1count = 0;
   if (trigger2 == true) {
     trigger2count++;
     angleChange = pow(pow(gx, 2) + pow(gy, 2) + pow(gz, 2), 0.5); Serial.println(angleChange);
     if (angleChange >= 30 && angleChange <= 400) { //if orientation changes by between 80-100 degrees
trigger3 = true; trigger2 = false; trigger2count = 0;
Serial.println("TRIGGER 3 ACTIVATED");
if (trigger3 == true) {
trigger3count++;
if (trigger3count >= 10) {
       //delay(10);
       if ((angleChange >= 0) && (angleChange <= 10)) { //if orientation changes remains between 0-10 degrees
fall = true; trigger3 = false; trigger3count = 0;
else { //user regained normal orientation
Serial.println("TRIGGER 3 DEACTIVATED");
if (fall == true) { //in event of a fall detection
Serial.println("FALL DETECTED");
digitalWrite(bzr,HIGH);
delay (3000);
fall = false;
digitalWrite(bzr,LOW);
if (trigger2count >= 6) { //allow 0.5s for orientation change
     Serial.println("TRIGGER 2 DECACTIVATED");
   if (trigger1count >= 6) { //allow 0.5s for AM to break upper threshold
     Serial.println("TRIGGER 1 DECACTIVATED");
void mpu_read() {
   Wire.beginTransmission(MPU_addr);
   Wire.write(0x3B);  // starting with register 0x3B (ACCEL_XOUT_H)
   Wire.endTransmission(false);
   Wire.requestFrom(MPU_addr, 14, true); // request a total of 14 registers
   AcX = Wire.read() << 8 | Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
   AcY = Wire.read() << 8 | Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
   AcZ = Wire.read() << 8 | Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
   Tmp = Wire.read() << 8 | Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
   GyX = Wire.read() << 8 | Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
   GyY = Wire.read() << 8 | Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
   GyZ = Wire.read() << 8 | Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
  pinMode(bzr, OUTPUT);
   Wire.begin();
   Wire.write(0x6B);  // PWR_MGMT_1 register
   Wire.write(0);     // set to zero (wakes up the MPU-6050)
   Wire.endTransmission(true);
sendSensor();
