Hi Reader,
I am using a Nano, an IR remote/IR receiver (both work well), and a rgb LED. Hardware, circuit, etc is in order.
My problem is that when I go from ex. red to cyan ("passing" cyan and then reaching the end of the while loop), "myColOld" becomes "cyan" when I want it to be "red".
But if I go from cyan to red (reaching the end of the while loop without "passing" red) then "myColOld" becomes "cyan" like I want it to.
Help would be much appreciated.
Here is the complete code:
//brightness should be kept the same while switching between colors
//intensity ratio needs to reset as color is changed
#include <IRremote.h>
int IRPin=2;
int bluePin=A2;
int greenPin=A1;
int redPin=A0;
int blueStrength;
int greenStrength;
int redStrength;
int SPV=140;
float intensityRatio;
String myCom="OFF";
String myCol;
String myColOld;
String myColNew;
IrReceiver.begin(IRPin, ENABLE_LED_FEEDBACK);
pinMode(bluePin,OUTPUT);
pinMode(greenPin,OUTPUT);
pinMode(redPin,OUTPUT);
Serial.println("Hi User, welcome to the IR-Remote RGB LED controller!");
Serial.println("These are the commands:");
Serial.println("Red button: On/OFF");
Serial.println("1 = Red");
Serial.println("2 = Green");
Serial.println("3 = Blue");
Serial.println("4 = Cyan");
Serial.println("5 = Magenta");
Serial.println("6 = Yellowish");
Serial.println("0 = White");
Serial.println("UP = Increase brighntess");
Serial.println("DOWN = Decrease brightness");
Serial.println("Remember, these commands will ONLY work after the LED has started. You can read which command you have selected on the LCD screen");
digitalWrite(bluePin,LOW);
digitalWrite(greenPin,LOW);
digitalWrite(redPin,LOW);
intensityRatio=1.0;
while(IrReceiver.decode()==0){
IrReceiver.decodedIRData.decodedRawData, HEX;
IrReceiver.resume();
if(IrReceiver.decodedIRData.decodedRawData == 0xBA45FF00 && myCom=="OFF") {
myCom = "ON";
myCol = "white";
myColOld = "white";
Serial.println("Command selected = ON");
blueStrength=255;
greenStrength=255;
redStrength=255;
while(myCom!="OFF"){
analogWrite(bluePin,blueStrength);
analogWrite(greenPin,greenStrength);
analogWrite(redPin,redStrength);
if(IrReceiver.decodedIRData.decodedRawData == 0xBA45FF00) {
myCom="OFF";
Serial.println("Command selected = OFF");
if(IrReceiver.decodedIRData.decodedRawData == 0xF30CFF00) {
myCom = "red";
myColNew = "red";
Serial.println("Command selected = Red");
blueStrength=0;
greenStrength=0;
if((255*intensityRatio)>=SPV){
redStrength=255*intensityRatio;
else{
redStrength=SPV;
if(myCol=="white" && myColNew=="red"){
myCol="red";
myColOld="white";
if(myCol=="red" && myColNew=="red"){
myCol="red";
myColOld="red";
if(myCol=="green" && myColNew=="red"){
myCol="red";
myColOld="green";
if(myCol=="blue" && myColNew=="red"){
myCol="red";
myColOld="blue";
if(myCol=="cyan" && myColNew=="red"){
myCol="red";
myColOld="cyan";
if(myCol=="magenta" && myColNew=="red"){
myCol="red";
myColOld="magenta";
if(myCol=="yellow" && myColNew=="red"){
myCol="red";
myColOld="yellow";
Serial.print("myCol: ");
Serial.println(myCol);
Serial.print("myColOld: ");
Serial.println(myColOld);
if(IrReceiver.decodedIRData.decodedRawData == 0xE718FF00) {
myCom = "green";
myColNew = "green";
Serial.println("Command selected = Green");
blueStrength=0;
greenStrength=255*intensityRatio;
else{
greenStrength=SPV;
redStrength=0;
if(myCol=="white" && myColNew=="green"){
myCol="green";
myColOld="white";
if(myCol=="red" && myColNew=="green"){
myCol="green";
myColOld="red";
if(myCol=="green" && myColNew=="green"){
myCol="green";
myColOld="green";
if(myCol=="blue" && myColNew=="green"){
myCol="green";
myColOld="blue";
if(myCol=="cyan" && myColNew=="green"){
myCol="green";
myColOld="cyan";
if(myCol=="magenta" && myColNew=="green"){
myCol="green";
myColOld="magenta";
if(myCol=="yellow" && myColNew=="green"){
myCol="green";
myColOld="yellow";
if(IrReceiver.decodedIRData.decodedRawData == 0xA15EFF00) {
myCom = "blue";
myColNew = "blue";
Serial.println("Command selected = Blue");
blueStrength=255*intensityRatio;
else{
blueStrength=SPV;
greenStrength=0;
redStrength=0;
if(myCol=="white" && myColNew=="blue"){
myCol="blue";
myColOld="white";
if(myCol=="red" && myColNew=="blue"){
myCol="blue";
myColOld="red";
if(myCol=="green" && myColNew=="blue"){
myCol="blue";
myColOld="green";
if(myCol=="blue" && myColNew=="blue"){
myCol="blue";
myColOld="blue";
if(myCol=="cyan" && myColNew=="blue"){
myCol="blue";
myColOld="cyan";
if(myCol=="magenta" && myColNew=="blue"){
myCol="blue";
myColOld="magenta";
if(myCol=="yellow" && myColNew=="blue"){
myCol="blue";
myColOld="yellow";
if(IrReceiver.decodedIRData.decodedRawData == 0xF708FF00) {
myCom = "cyan";
myColNew = "cyan";
Serial.println("Command selected = Cyan");
if((155*intensityRatio)>=SPV){
greenStrength=155*intensityRatio;
else{
greenStrength=SPV;
redStrength=0;
if(myCol=="white" && myColNew=="cyan"){
myCol="cyan";
myColOld="white";
if(myCol=="red" && myColNew=="cyan"){
myCol="cyan";
myColOld="red";
if(myCol=="green" && myColNew=="cyan"){
myCol="cyan";
myColOld="green";
if(myCol=="blue" && myColNew=="cyan"){
myCol="cyan";
myColOld="blue";
if(myCol=="cyan" && myColNew=="cyan"){
myCol="cyan";
myColOld="cyan";
if(myCol=="magenta" && myColNew=="cyan"){
myCol="cyan";
myColOld="magenta";
if(myCol=="yellow" && myColNew=="cyan"){
myCol="cyan";
myColOld="yellow";
if(IrReceiver.decodedIRData.decodedRawData == 0xE31CFF00) {
myCom = "magenta";
myColNew = "magenta";
Serial.println("Command selected = Magenta");
greenStrength=0;
redStrength=155*intensityRatio;
else{
redStrength=SPV;
if(myCol=="white" && myColNew=="magenta"){
myCol="magenta";
myColOld="white";
if(myCol=="red" && myColNew=="magenta"){
myCol="magenta";
myColOld="red";
if(myCol=="green" && myColNew=="magenta"){
myCol="magenta";
myColOld="green";
if(myCol=="blue" && myColNew=="magenta"){
myCol="magenta";
myColOld="blue";
if(myCol=="cyan" && myColNew=="magenta"){
myCol="magenta";
myColOld="cyan";
if(myCol=="magenta" && myColNew=="magenta"){
myCol="magenta";
myColOld="magenta";
if(myCol=="yellow" && myColNew=="magenta"){
myCol="magenta";
myColOld="yellow";
if(IrReceiver.decodedIRData.decodedRawData == 0xA55AFF00) {
myCom = "yellow";
myColNew = "yellow";
Serial.println("Command selected = Yellow");
blueStrength=0;
greenStrength=SPV;
if(myCol=="white" && myColNew=="yellow"){
myCol="yellow";
myColOld="white";
if(myCol=="red" && myColNew=="yellow"){
myCol="yellow";
myColOld="red";
if(myCol=="green" && myColNew=="yellow"){
myCol="yellow";
myColOld="green";
if(myCol=="blue" && myColNew=="yellow"){
myCol="yellow";
myColOld="blue";
if(myCol=="cyan" && myColNew=="yellow"){
myCol="yellow";
myColOld="cyan";
if(myCol=="magenta" && myColNew=="yellow"){
myCol="yellow";
myColOld="magenta";
if(myCol=="yellow" && myColNew=="yellow"){
myCol="yellow";
myColOld="yellow";
if(IrReceiver.decodedIRData.decodedRawData == 0xE916FF00) {
myCom = "white";
myColNew = "white";
Serial.println("Command selected = White");
if(myCol=="white" && myColNew=="white"){
myCol="white";
myColOld="white";
if(myCol=="red" && myColNew=="white"){
myCol="white";
myColOld="red";
if(myCol=="green" && myColNew=="white"){
myCol="white";
myColOld="green";
if(myCol=="blue" && myColNew=="white"){
myCol="white";
myColOld="blue";
if(myCol=="cyan" && myColNew=="white"){
myCol="white";
myColOld="cyan";
if(myCol=="magenta" && myColNew=="white"){
myCol="white";
myColOld="magenta";
if(myCol=="yellow" && myColNew=="white"){
myCol="white";
myColOld="yellow";
if(IrReceiver.decodedIRData.decodedRawData == 0xF807FF00) {
myCom = "down";
Serial.println("Command selected = Decrease LED intensity");
if(blueStrength >= SPV){
blueStrength=blueStrength-((blueStrength/100)*5);
float NewBlueStrength=blueStrength-((blueStrength/100)*5);
intensityRatio=NewBlueStrength/blueStrength;
Serial.println(intensityRatio);
if(greenStrength >= SPV){
greenStrength=greenStrength-((greenStrength/100)*5);
float NewGreenStrength=blueStrength-((greenStrength/100)*5);
intensityRatio=NewGreenStrength/greenStrength;
if(redStrength >= SPV){
redStrength=redStrength-((redStrength/100)*5);
float NewRedStrength=redStrength-((redStrength/100)*5);
intensityRatio=NewRedStrength/redStrength;
if(IrReceiver.decodedIRData.decodedRawData == 0xF609FF00) {
myCom = "up";
Serial.println("Command selected = Increase LED intensity");
Serial.print("blueStrength: ");
Serial.println(blueStrength);
Serial.print("greenStrength: ");
Serial.println(greenStrength);
Serial.print("redStrength: ");
Serial.println(redStrength);
if(myColOld != myCol){
intensityRatio=1.0;
