Code only working on one computer
hi guys,
I am still pretty new to Arduino so please bear with me. I am working with and RFID tag to scan a card. I got code working and the tag works fine, but only on one computer, not on my laptop(Mac) or another Dell. The origanal computer, where the code works is a Mac and it has a different operating system compared to my laptop.
I have downloaded all the libraries that are nessary, and the version of Arduino is the same.
Here is my code.
Any help would be really appericated.
/* Start of Code */
/* Simple RFID Arduino Sketch(RC522)
Created by Yvan / https://Brainy-Bits.com
This code is in the public domain...
You can: copy it, use it, modify it, share it or just plain ignore it!
Thx!
The MFRC522 Library used, was created by LJOS here: GitHub - ljos/MFRC522: Arduino RFID Library for MFRC522
The FastLED Library used, was created by focalintent here: Releases · FastLED/FastLED · GitHub
#include <MFRC522.h> // Include of the RC522 Library
#include <SPI.h> // Used for communication via SPI with the Module
#define SDAPIN 10 // RFID Module SDA Pin is connected to the UNO 10 Pin
#define RESETPIN 8 // RFID Module RST Pin is connected to the UNO 8 Pin
byte FoundTag; // Variable used to check if Tag was found
byte ReadTag; // Variable used to store anti-collision value to read Tag information
byte TagData[MAX_LEN]; // Variable used to store Full Tag Data
byte TagSerialNumber[5]; // Variable used to store only Tag Serial Number
byte GoodTagSerialNumber[5] = {12, 134, 158, 211}; // The Tag Serial number we are looking for
byte GoodTagSerialNumber2[5] = {192, 252, 71, 37}; // The Tag Serial number we are looking for
MFRC522 nfc(SDAPIN, RESETPIN); // Init of the library using the UNO pins declared above
SPI.begin();
// Start to find an RFID Module
Serial.println("Looking for RFID Reader");
nfc.begin();
byte version = nfc.getFirmwareVersion(); // Variable to store Firmware version of the Module
// If can't find an RFID Module
if (! version) {
Serial.print("Didn't find RC522 board.");
while(1); //Wait until a RFID Module is found
// If found, print the information about the RFID Module
Serial.print("Found chip RC522 ");
Serial.print("Firmware version: 0x");
Serial.println(version, HEX);
String GoodTag="False"; // Variable used to confirm good Tag Detected
// Check to see if a Tag was detected
// If yes, then the variable FoundTag will contain "MI_OK"
FoundTag = nfc.requestTag(MF1_REQIDL, TagData);
if (FoundTag == MI_OK) {
delay(200);
// Get anti-collision value to properly read information from the Tag
ReadTag = nfc.antiCollision(TagData);
memcpy(TagSerialNumber, TagData, 4); // Write the Tag information in the TagSerialNumber variable
//Serial.println("Tag detected.");
//Serial.print("Serial Number: ");
for (int i = 0; i < 4; i++) { // Loop to print serial number to serial monitor
Serial.print(TagSerialNumber*);*
Serial.print(", ");
Serial.println("");
// Check if detected Tag has the right Serial number we are looking for
for(int i=0; i < 4; i++){
if (GoodTagSerialNumber != TagSerialNumber*) {*
break; // if not equal, then break out of the "for" loop
if (i == 3) { // if we made it to 4 loops then the Tag Serial numbers are matching
GoodTag="TRUE";
if (GoodTag == "TRUE"){
Serial.println("Success!!!!!!!");
//check another card
if (GoodTagSerialNumber2 != TagSerialNumber*) {*
GoodTag="TRUE";
Serial.println("Another Success!!!!!!!");
////end of code//
What does this...
... actually mean?
Do you mean you can only compile the code on one computer? Or that when you take an Arduino with good code to another computer, the Serial.print() lines don't show in the monitor on that other computer, or what?
(You see, the Arduino code doesn't work (if that means run?) on any computer other than the Arduino itself. That's why I don't know what you mean.)
