Code only works when serial monitor is open !
I know that the problem is with ( while Serial) but I’m not sure how to fix it!
#include <MKRGSM.h>
#include<math.h>
#include<stdio.h>
#include "arduino_secrets.h"
#include <SPI.h>
#include "Adafruit_BLE.h"
#include "Adafruit_BluefruitLE_SPI.h"
#include "Adafruit_BluefruitLE_UART.h"
#include <Wire.h>
#include <Adafruit_LSM9DS0.h>
#include <Adafruit_Sensor.h>
#define BLUEFRUIT_HWSERIAL_NAME      Serial1
int val_x,val_y,val_z;
const char GPRS_APN[]      = SECRET_GPRS_APN;
const char GPRS_LOGIN[]    = SECRET_GPRS_LOGIN;
const char GPRS_PASSWORD[] = SECRET_GPRS_PASSWORD;
    #define FACTORYRESET_ENABLE         1
    #define MINIMUM_FIRMWARE_VERSION    "0.6.6"
    #define MODE_LED_BEHAVIOUR          "MODE"
    Adafruit_BluefruitLE_UART ble(Serial1, BLUEFRUIT_UART_MODE_PIN);
#define PINNUMBER  ""
GSM gsmAccess;
GSM_SMS sms;
GSMLocation location;
GPRS gprs;
Adafruit_LSM9DS0 lsm = Adafruit_LSM9DS0();
// char array of the message
char remoteNumber[20]= "00442030954971";
char txtMsg[200]="run";
// A small helper
void error(const __FlashStringHelper*err) {
  Serial.println(err);
  while (1);
  while (!Serial);     // will pause Zero, Leonardo, etc until serial console opens
  Serial.println("LSM raw read demo");
  // Try to initialise and warn if we couldn't detect the chip
  if (!lsm.begin())
    Serial.println("Oops ... unable to initialize the LSM9DS0. Check your wiring!");
    while (1);
  Serial.println("Found LSM9DS0 9DOF");
  Serial.println("");
  Serial.println("");
  Serial.println(F("Adafruit Bluefruit Command Mode Example"));
  Serial.println(F("---------------------------------------"));
  Serial.println("SMS Messages Sender");
   boolean connected = false;
   while(!connected){
    if((gsmAccess.begin(PINNUMBER) == GSM_READY) &&
        (gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD) == GPRS_READY)) {
      connected = true ;
    else {
      Serial.println("Not connected");
  Serial.println("GSM initialized");
    location.begin();
    Serial.print(F("Initialising the Bluefruit LE module: "));
  if ( !ble.begin(VERBOSE_MODE) )
    error(F("Couldn't find Bluefruit, make sure it's in CoMmanD mode & check wiring?"));
  Serial.println( F("OK!") );
   if ( FACTORYRESET_ENABLE )
    /* Perform a factory reset to make sure everything is in a known state */
    Serial.println(F("Performing a factory reset: "));
    if ( ! ble.factoryReset() ){
      error(F("Couldn't factory reset"));
  /* Disable command echo from Bluefruit */
  ble.echo(false);
  Serial.println("Requesting Bluefruit info:");
  /* Print Bluefruit information */
  ble.info();
  Serial.println(F("Please use Adafruit Bluefruit LE app to connect in UART mode"));
  Serial.println(F("Then Enter characters to send to Bluefruit"));
  ble.verbose(false);  // debug info is a little annoying after this point!
  // LED Activity command is only supported from 0.6.6
  if ( ble.isVersionAtLeast(MINIMUM_FIRMWARE_VERSION) )
    // Change Mode LED Activity
    Serial.println(F("******************************"));
    Serial.println(F("Change LED activity to " MODE_LED_BEHAVIOUR));
    ble.sendCommandCheckOK("AT+HWModeLED=" MODE_LED_BEHAVIOUR);
void locationcheck()
  if (location.available()) {
    Serial.print("Location: ");
    Serial.print(location.latitude(), 7);
    Serial.print(", ");
    Serial.println(location.longitude(), 7);
    Serial.print("Altitude: ");
    Serial.print(location.altitude());
    Serial.print(" started");
    Serial.println("m");
    Serial.print("Accuracy: +/- ");
    Serial.print(location.accuracy());
  float a;
   for (int i=0;i<10;i++)
  lsm.read();
  Serial.print("sensor");
  val_x = (lsm.accelData.x);
  val_y = (lsm.accelData.y);
  val_z = (lsm.accelData.z);
  // Check for user input
  char inputs[BUFSIZE+1];
  if ( getUserInput(inputs, BUFSIZE) )
    // Send characters to Bluefruit
    Serial.print("[Send] ");
    Serial.println(inputs);
    ble.print("AT+BLEUARTTX=");
    ble.println(inputs);
    // check response stastus
    if (! ble.waitForOK() ) {
      Serial.println(F("Failed to send?"));
  locationcheck();
  if (!ble.isConnected()) {
   if ( 8734<val_x<14169)
   sendSMS();
   Serial.print("Right shift");
   if ( -17902<val_x<-8750)
   sendSMS();
   Serial.print("right shift");
 void setupSensor()
  lsm.setupAccel(lsm.LSM9DS0_ACCELRANGE_2G);
 void sendSMS(){
  float lat = location.latitude();
  float lon = location.longitude();
  String txt;
  txt += String(lat, 7);
  txt += F(":");
  txt += String(lon, 7);
  Serial.print("Message to mobile number: ");
  Serial.println(remoteNumber);
  // sms text
  Serial.println("SENDING");
  Serial.println("Message:");
  Serial.println(lat, 7);
  Serial.println(lon, 7);
  // send the message
  sms.beginSMS(remoteNumber);
  sms.print(txt);
  sms.endSMS();
  Serial.println("\nCOMPLETE!\n");
bool getUserInput(char buffer[], uint8_t maxSize)
  // timeout in 100 milliseconds
  TimeoutTimer timeout(100);
  memset(buffer, 0, maxSize);
  while( (!Serial.available()) && !timeout.expired() ) { delay(1); }
  if ( timeout.expired() ) return false;
  delay(2);
  uint8_t count=0;
  do
    count += Serial.readBytes(buffer+count, maxSize);
    delay(2);
  } while( (count < maxSize) && (Serial.available()) );
return true;
psmelakt:
I know that the problem is with ( while Serial) but I'm not sure how to fix it!
You have not told us what Arduino board you are using.
What happens if you comment out line 47?
...R
I wonder if this does what you think it does.
This is the warning I get (compiling for a 328P based board):
C:\Users\sterretje\AppData\Local\Temp\arduino_modified_sketch_955932\sketch_aug03b.ino: In function 'void setup()':
C:\Users\sterretje\AppData\Local\Temp\arduino_modified_sketch_955932\sketch_aug03b.ino:5:13: warning: comparisons like 'X<=Y<=Z' do not have their mathematical meaning [-Wparentheses]
   if ( 8734 < val_x < 14169)
Robin2:
The first line of the code contains something possibly related to a MKR; so possibly that.
OP might have to take precautions. You can bring a Leonardo (using external power) to a grinding halt within a few minutes if you send data after you opened the serial monitor and next disconnect the cable; this might be the same for the MKR.
if ( 8734<val_x<14169)Evaluate left to right.
Is val_x greater than 8734?
This give is a result true or false, aka one or zero.
Is one or zero less than 14169?
True.
Robin2:
...R
I'm using an Arduino MKRGSM 1400 the code works fine when the serial monitor is open.
i think the problem is only with while serial part and solution should be by adding a time limit next to it for example ( wait 30 seconds and check if there is a serial connection if not run the code ) but i'm not good in programming and i'm not sure how to do it.
sterretje:
C:\Users\sterretje\AppData\Local\Temp\arduino_modified_sketch_955932\sketch_aug03b.ino:5:13: warning: comparisons like ‘X<=Y<=Z’ do not have their mathematical meaning [-Wparentheses]
It should be working fine because these values are from the sensor i’m just telling it to send a SMS when the values are in this range.
also i tried connecting the usb and the battery in the same time and run the code then i disconnected the usb but the code still wasn’t working.
You are calling "while(!Serial);" before "Serial.begin()" - that may be an issue.
psmelakt:
No, that’s not what you are saying with that line. You think that line says when val_x is in this range, but you’re not using good syntax. That line is equivalent to:
if (true)
and it says to do something all the time. It’s already been explained why it means that. If you want to compare to a range, then you have to do that in two comparisons and use AND. You can’t just make up your own syntax and expect it to work.
Delta_G:
if (true)
in my original code i used this if statement and it worked fine!
if (val_z<=665 && val_x<365)
psmelakt:
  while (!Serial && (millis() < 30000));
psmelakt:
Yes, doing it that way will work. But you have to have the AND in it. You can’t have it like the one I pointed out earlier.
This one is legal and compiles but doesn’t do what you think it does.
Whandall:
that did it :slight_smile: now the code works.
You just as well leave the test out. Lot simpler :wink:
hey guys, Just a quick question!
my laptop can't read my arduino any more ! it happened after connecting a battery and the usb in the same time; However, this wasn't the first time that i did that.
Hello psmelakt
Quote from: Whandall on Aug 04, 2018, 06:46 pm
Code: [Select]
“now the code works.” : sure, one day or another you will have millis() >= 30000.
Have you read post #6 ?
Regards,
bidouillelec
bidouilleelec:
Hello psmelakt
"now the code works." : sure, one day or another you will have millis() >= 30000.
Crap. This is in setup, millis starts with zero and counts up, so "one day or another" happens after 30 seconds.
bidouilleelec:
which is
Danois90:
Why should anyone read that irrelevant superstitious post anyway?
Hello Wandall
Posted by Whandall
  • Today at 05:23 pm
Quote
Quote from: bidouilleelec on Today at 05:17 pm
Hello psmelakt
Crap. This is in setup, millis starts with zero and counts up, so “one day or another” happens after 30 seconds.
which is
Quote from: Danois90 on Aug 03, 2018, 01:53 pm
You are calling “while(!Serial);” before “Serial.begin()” - that may be an issue.
Are you sure? Did you test it?
I did.
Regards,
bidouilleelec
bidouilleelec:
Hello Wandall
I did.
Regards,
bidouilleelec
And what was the result?
I did test it numerous times in the past (and now again) and it does not make a difference as far as I can see.
Hello Sterretje
The result is :
Post #6 is right.
Post #9 is just adding a delay and testing !Serial is unusefull as Serial.begin is after the test. (sure one day comes after 30ms)
Regards,
bidouilleelec
bidouilleelec:
You realize that the sketch works if there is a serial connection?
And that devices without native USB return true always?
That's what while (!Serial); is waiting for.
Adding a timeout to the endless wait makes the sketch work even if there is no serial connection.
The connection test (operator bool) does not need a begin before it can be used.
