Code only works when Serial Monitor opens/reset button is pressed
@Idahowalker
Let me try that out, when I get a second.
@Idahowalker @ruilviana
The blink method seems to work just fine with the mega in the system. It worked as expected using both the on board power supply and and the laptop USB connection.
Now add in bits of your code, leaving the wiring in place and leave the blinking led in place as an indicator all is well.
Disconnect the relays outputs so an enable of the relay will not damage something.
Such as comment out all the code in loop() but blink and uncomment 'everything' in setup.
Oh so the mega and the shield are, at this point, not the issue.
Also, when you make code changes, like getting rid of serial.end, post your new updated code.
does that work? If it does add in another function and use serial prints to view results.
With over 300ms of delay your code will be stopped for 3/10th of every second. If it is critical for the unit to stop when the stop button is pressed 1/3 of a second without a response might be life/death? Serious question.
I'll try that code in a few minutes.
The 300ms delay is specifically in the code to allow for the thread to start moving before a "baseline" value is recorded for the motion sensor. It may not be necessary.
Perhaps using millis() might work in this case. By using millis() you could still have a delay but, also, still check on the safety button sate.
Let's say the safety button is done by an interrupt.
In the ISR set a Boolean to true. each time loop runs it can check for the safety button Boolean value sate and respond accordingly.
demonstration of several things at the same time.
Obviously connecting 5 V to "Vin" or the "barrel jack" is a mistake.
In fact, using "Vin" or the "barrel jack" is in general, a mistake.
But correctly powered, by regulated 5 V to the USB jack or the "5V" pin with no PC connected, it is very much not obvious why it malfunctions and clearly some sort of hardware problem so testing code is unlikely to get anywhere. :astonished:
@Paul_B
@Idahowalker
Any thoughts on the dependency of the serial monitor? This is what took my suspicious away from it being a power issue.
Anyway, another observation I noticed is that the onboard LED for pin 13 blinks twice when when I open up the serial monitor. Does this signify anything?
*As an update to this, if I open and then close the serial monitor, the program still works as expected. But if I unplug the usb or power down the supplies and then try to power up and use the program I need to reopen the serial monitor before the program will work again. I'm expecting that the board needs to be reset in some fashion or have some sort of connection triggered by the opening of the serial monitor.
Another observation when testing the blink program is that the program takes ~10 seconds to function properly. Either the light will stay on for longer than the delay time or it will flutter before falling into the prescribed flashing pattern.
The Arduino MEGA will automatically reset when you open the serial monitor.
This is because it has a built-in automatic reset circuit that uses the DTR signal to start the boot loader for sketch transfer.
In other words, I think your problem can be unified into the fact that "work fine after an external reset but do not execute correctly at the power-on reset".
Precisely the issue, the board is on a shield which doesn't give access to the reset button, but I grounded a wire that I connected to the reset pin and it worked after that.
Yeah, it's the same as pressing the reset button.
Also, the act of "opening the serial monitor" does that with Mega's internal circuitry.
Probably not a problem, but I would like to check the boot loader and fuse settings.
Do you know about ICSP?
Also, is the board temporarily removable and do you have another Arduino board?
I'm not familiar with ICSP. And yeah I have another clone Mega and another regular mega as well as other uno/nanos.
Use spare Mega and Uno.
Connect the two as follows.
Once properly connected, connect only Uno to your PC's USB.
Then open the IDE and set the board to Arduino Uno.
[Tools -> Board -> Arduino AVR boards -> Arduino Uno]
From the sketch sample, open ArduinoISP.
[File -> Examples -> 11. ArduinoISP -> ArduinoISP]
Click the Upload button to program this sample sketch into Uno as is.
Note: Select the correct COM port to which Uno is connected.
Switch the IDE board to Mega.
[Tools -> Board -> Arduino AVR boards -> Arduino Mega or Mega 2560]
Note: Uno is still connected to the USB! Does not change the connection! IDE menu only!
Change the programmer to Arduino as ISP.
[Tools -> Programmer -> Arduino as ISP]
Note: It's not "Arduino ISP", please note that the names are similar!
Let's burn the bootloader.
[Tools -> Burn Bootloader]
Remove Uno from your PC's USB and unplug all connecting wires from Uno and Mega.
Connect Mega to your PC via USB and write a sketch of your project.
Install it in the project and check the operation.
If you encounter any errors or other problems during the process, please post an error message.
EDIT:
There was a good instruction video.
https://www.youtube.com/watch?v=X5achE10rCI
@chrisknightley
I'm getting this error message:
Arduino: 1.8.13 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Error while burning bootloader.
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Full Error Message Below:
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cstk500v1 -PCOM6 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xD8:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM6
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
         this check.
avrdude done.  Thank you.
The this error message has been omitted by the IDE.
Can you post the full message of the error by doing the following IDE settings?
[File -> Preferences]
Just got it to work by using a different Uno.
But the same issue still arises. Does not work upon powering up but will work after a reset.
Looks like programmer (in this case your Uno) is can't communicate with Mega.
Please re-check the wiring again.
And I'm so sorry, my bed is approaching...
Good test!
Use other Arduinos have similar problems?
So it may not be a problem, with that Mega bootloader.
May need to investigate again.
I've changed out the board to a clone mega that I had and I'm still having the same issue.
Okay, It is possible to isolate the problem more.
Sorry, I'm going to sleep today. :zzz:
Other posters may also give you more hints on how to solve the problem.
I has basically sloppy head... :joy:
