Code optimization - please help
I am using the code from the project:
after adding a few lines of code from the esp service the code has grown to 110%
I do not know how can I optimize it or can someone help me?
Project in the annex:
Moderator Edit: Malware link removed.
I think you will need to post the files individually, to get any help. Not many people will download a zip file.
@Morcinek92, if you post a link to that site on this forum again you will be banned.
This is my code:
#include <SPI.h>
#include "DW1000Ranging.h"
#include "DW1000Device.h"
#include <MatrixMath.h>
#include <math.h>
// If false, then use the calibration. If true, don't use the calibration.
#define CALIBRATE_FIRST false
#define CALIBRATE_SECOND false
String hostip   = "192.168.1.58";
String udpport  = "9999";
String ID = "TAG%NR=1&";
int ADC_Pin = 1; // Pin analogowy
int value = 0;
float volt = 0;
int LED = 6;
//First distance from ground truth 2 meters
//Second from ground truth 5 meters.
#define BEACON_1_FIRSTDIST 2.368
#define BEACON_1_SECONDDIST 5.372
#define USE_MEDIAN_FILT true
#define BEACON_1_ADDRESS 0x1A1A
#define BEACON_2_ADDRESS 0x1A2A
#define BEACON_3_ADDRESS 0x1A3A
#define BEACON_1_X 0.00f
#define BEACON_1_Y 7.01f
#define BEACON_2_X 0.0f
#define BEACON_2_Y 0.0f
#define BEACON_3_X 7.92f
#define BEACON_3_Y 7.92f
#define BEACON_1_FIRSTDIST 2.00
#define BEACON_1_SECONDDIST 5.00
float beacon_1_slope = 3.0f/(BEACON_1_SECONDDIST-BEACON_1_FIRSTDIST);
float beacon_1_offset = 5.0f-(1.0f/beacon_1_slope*BEACON_1_SECONDDIST);
#define BEACON_2_FIRSTDIST 3.22
#define BEACON_2_SECONDDIST 6.18
float beacon_2_slope = 3.0f/(BEACON_2_SECONDDIST-BEACON_2_FIRSTDIST);
float beacon_2_offset = 5.0f-(1.0f/beacon_2_slope*BEACON_2_SECONDDIST);
#define BEACON_3_FIRSTDIST 3.08
#define BEACON_3_SECONDDIST 6.26
float beacon_3_slope = 3.0f/(BEACON_3_SECONDDIST-BEACON_3_FIRSTDIST);
float beacon_3_offset = 5.0f-(1.0f/beacon_3_slope*BEACON_3_SECONDDIST);
//#define BEACON_1_OFFSET 0.0368f
//#define BEACON_1_MULTIPLIER 1.0692f
//#define BEACON_2_OFFSET 0.6336f
//#define BEACON_2_MULTIPLIER 1.0440f
//#define BEACON_3_OFFSET 0.5575f
//#define BEACON_3_MULTIPLIER 1.0666f
// connection pins
const uint8_t PIN_RST = 3; // reset pin
const uint8_t PIN_IRQ = 7; // irq pin
const uint8_t PIN_SS = 10; // spi select pin
volatile unsigned long delaySent = 0;
volatile boolean sentAck = false;
volatile float range = 0;
volatile int address = 0;
volatile float dist[3] = {00.0, 00.0, 00.0};
float beacons[3][2] = {{BEACON_1_X, BEACON_1_Y},
                       {BEACON_2_X, BEACON_2_Y},
                       {BEACON_3_X, BEACON_3_Y}};
float shortestDistanceBeacon1 = 900.0f;
float shortestDistanceBeacon2 = 900.0f;
float shortestDistanceBeacon3 = 900.0f;
float A[3][3];
#define N (5)
struct cir {
    float a[N];
    unsigned h;
    unsigned t;
    unsigned n;
typedef volatile struct cir cir_t;
cir_t *cir_new() {
    cir_t *cir = malloc(sizeof(*cir));
    cir->h = 0;
    cir->t = N - 1;
    cir->n = N;
    return cir;
// if adding 1 to tail == head, then there is nothing
float cir_empty(cir_t *cir) {
    return (cir->t + 1) % N == cir->h;
// if adding 1 to head = tail, then we have no space.
float cir_full(cir_t *cir) {
    return cir->h == cir->t;
void cir_enqueue(cir_t *cir, float x) {
    if (cir_full(cir)) cir->t = (cir->t + 1) % N;
    cir->a[cir->h] = x;
    cir->h = (cir->h + 1) % N;
    // for(int i = 0; i < N; i++) {
    //     printf("%d ", cir->a[i]);
    // printf(": %d %d\n", cir->t, cir->h);
int compare(const void *x, const void * y) {
    float ix = *(float*)x;
    float iy = *(float*)y;
    return (int)(ix - iy);
float cir_median(cir_t *cir) {
    float q[cir->n];
    int qcount = 0;
    // Populate the array
    if(cir_empty(cir)) return 0;
    else if(cir_full(cir)) {
        qcount = cir->n;
        for(int i = 0; i < cir->n; i++) {
            q[i] = cir->a[i];
    } else if(cir->t > cir->h) {
        for(int i = 0; i < cir->h; i++) {
            q[qcount] = cir->a[i];
            qcount++;
        for(int i = cir->t; i < cir->n - 1; i++) {
            qcount++;
        for(int i = cir->t; i < cir->h; i++) {
            qcount++;
    // Sort the array
    qsort(q, qcount, sizeof(float), compare);
    // for(int i = 0; i < qcount; i++) {
    //     printf("%d ", q[i]);
    // printf("\n");
    return q[qcount/2];
cir_t *cir1 = cir_new();
cir_t *cir2 = cir_new();
cir_t *cir3 = cir_new();
  Serial1.begin(115200);
  analogReference(INTERNAL);
  pinMode(LED, OUTPUT);
  //init the configuration
  DW1000Ranging.initCommunication(PIN_RST, PIN_SS, PIN_IRQ);
  DW1000Ranging.attachNewRange(newRange);
  DW1000Ranging.startAsTag("7D:00:22:EA:82:60:3B:9C", DW1000.MODE_LONGDATA_RANGE_ACCURACY);
  //DW1000Ranging.useRangeFilter(true);
  unsigned long start, step_start, finished;
  start = micros();
  for(int i = 0; i < 3; i++) {
    A[i][0] = -2.0f*beacons[i][0];
    A[i][1] = -2.0f*beacons[i][1];
    A[i][2] = 1.0f;
  Matrix.Invert((float*)A, 3);
  step_start = micros();
  Serial.println(step_start - start);
int loopCtr = -1;
  int value = analogRead(ADC_Pin);
  volt = value * (2.56 / 1024.0) * 1.66;
  if (loopCtr == 10000) {
  // Ramka : TAG%NR=3&V=X.XX
  String msgUdp =  "SendToUDP " + hostip + " " + udpport + " " + ID + "V=" + volt;
  Serial1.println(msgUdp);
  digitalWrite(LED, HIGH);
  if (loopCtr == 15000) {
  digitalWrite(LED, LOW);
  if (loopCtr == 17000){
    loopCtr = 0;
  loopCtr++;
  DW1000Ranging.loop();
void newRange() {
  address = DW1000Ranging.getDistantDevice()->getShortAddress();
  range = DW1000Ranging.getDistantDevice()->getRange();
  if(range < 0) address = NULL;
  if(address == BEACON_1_ADDRESS){
    range *= CALIBRATE_FIRST||CALIBRATE_SECOND?1.0f:beacon_1_slope;
    range -= CALIBRATE_FIRST||CALIBRATE_SECOND?0.0f:beacon_1_offset;
    cir_enqueue(cir1,range);
    dist[0] = (USE_MEDIAN_FILT)?cir_median(cir1):range;
    if(CALIBRATE_FIRST||CALIBRATE_SECOND){
      if(dist[0] < shortestDistanceBeacon1 && dist[0] > 0){
        shortestDistanceBeacon1 = dist[0];
  else if(address == BEACON_2_ADDRESS){
    range *= CALIBRATE_FIRST||CALIBRATE_SECOND?1.0f:beacon_2_slope;
    range -= CALIBRATE_FIRST||CALIBRATE_SECOND?0.0f:beacon_2_offset;
    cir_enqueue(cir2,range);
    dist[1] = (USE_MEDIAN_FILT)?cir_median(cir2):range;
      if(dist[1] < shortestDistanceBeacon2 && dist[1] > 0){
        shortestDistanceBeacon2 = dist[1];
  else if(address == BEACON_3_ADDRESS){
    range *= CALIBRATE_FIRST||CALIBRATE_SECOND?1.0f:beacon_3_slope;
    range -= CALIBRATE_FIRST||CALIBRATE_SECOND?0.0f:beacon_3_offset;
    cir_enqueue(cir3,range);
    dist[2] = (USE_MEDIAN_FILT)?cir_median(cir3):range;
      if(dist[2] < shortestDistanceBeacon3 && dist[2] > 0){
        shortestDistanceBeacon3 = dist[2];
  Serial.print("1: ");Serial.print(dist[0]);Serial.print(" 2: ");Serial.print(dist[1]);Serial.print(" 3: ");Serial.print(dist[2]);
  // ITERATIVE STEPS BELOW
  float y[3];
    y[i] = float((dist[i])*(dist[i]) - (beacons[i][0])*(beacons[i][0]) - (beacons[i][1])*(beacons[i][1]));
  float x[3];
  Matrix.Multiply((float*)A, (float*)y, 3, 3, 1, (float*)x);
  float estimate[2] = {x[0], x[1]};
  Serial.print(" Location: ["); Serial.print(estimate[0]); Serial.print("m, "); Serial.print(estimate[1]); Serial.print("m] \n");
  if(estimate[0] > 4.0f){
    digitalWrite(6,HIGH);
  else digitalWrite(6,LOW);
  DW1000Ranging.setLoc(estimate[0], estimate[1]);
It takes up to 110%, will anyone help me with optimization?
beacon_1_slope and beacon_1_offset are never assigned a value other than the in the declaration. This mean each variable stays as a variable and not optimized in the same manner as the #define statements directly above.
Where are these used? Search your code for unused or under used variables?
int loopCtr = -1;
Why are these declarations floating between two subroutines?
Why declare a run of variable in the middle of a subroutine? Best to place at the start.
vois setup() {
This way it is easier to keep track of what you have declared and what is unused (hint, hint).
No ISR = No volatile.
float volt = 0;
Someone can double check me but isn’t the result of int * float = int? So that even though volt is a float, it will only receive int values because value is and int?
This doesn’t compare?
I question the use of String.
A search shows these are the only places these four Strings are used. Why not char and then call Serial.print() multiple times, thereby not including the String library?
Place this and its two similars in a single function and allow the compiler to optimize it rather than three hard coded instances.
#include <SPI.h>
#include <math.h>
// connection pins
float A[3][3];
#define N (5)
struct cir {
    float a[N];
    unsigned h;
    unsigned t;
    unsigned n;
cir_t *cir_new() {
    cir->h = 0;
    cir->t = N - 1;
    cir->n = N;
    return cir;
    cir->a[cir->h] = x;
    float q[cir->n];
    int qcount = 0;
        qcount = cir->n;
            q[i] = cir->a[i];
            qcount++;
            qcount++;
            qcount++;
    // Sort the array
    // printf("\n");
    return q[qcount/2];
  pinMode(6, OUTPUT);
  start = micros();
    A[i][2] = 1.0f;
int volt = 0;
int loopCtr = -1;
  volt = analogRead(1) * (2.56 / 1024.0) * 1.66;
  String msgUdp =  "SendToUDP 192.168.1.58 9999 TAG%NR=1&V=" + volt;
  digitalWrite(6, HIGH);
  digitalWrite(6, LOW);
    loopCtr = 0;
  loopCtr++;
void newRange() {
  float y[3];
  float x[3];
Thank you very much for your answer :slight_smile:
I made a few corrections and got 102% as of now.
Regarding “int * float = int?”
I get a float at the exit - I checked.
I did not understand these other hints … could you please explain a bit more?
thank you
Morcinek92:
I did not understand these other hints ... could you please explain a bit more?
Which one(s)? I'm not sure what else there is to explain. What do you need explained?
