Hi guys I currently have a project for an automated high power led lighting system which has 4 channels controlled using pwm and an rtc clock.
My issue is that this is my first time using an arduino for such a major thing and rtc. I do have a basic code layout but i need to optimize it since it is using up 95% of the memory so i was wondering if someone could help me improve it.
#include <Wire.h>
#include "Sodaq_DS3231.h"
//declare times and corresponding led brightness
const char* ledTime[] = {"00:00", "00:15", "00:30", "00:45", "01:00", "01:15", "01:30", "01:45", "02:00", "02:15", "02:30", "02:45", "03:00", "03:15", "03:30", "03:45", "04:00", "04:15", "04:30", "04:45", "05:00", "05:15", "05:30", "05:45", "06:00", "06:15", "06:30", "06:45", "07:00", "07:15", "07:30", "07:45", "08:00", "08:15", "08:30", "08:45", "09:00", "09:15", "09:30", "09:45", "10:00", "10:15", "10:30", "10:45", "11:00", "11:15", "11:30", "11:45", "12:00", "12:15", "12:30", "12:45", "13:00", "13:15", "13:30", "13:45", "14:00", "14:15", "14:30", "14:45", "15:00", "15:15", "15:30", "15:45", "16:00", "16:15", "16:30", "16:45", "17:00", "17:15", "17:30", "17:45", "18:00", "18:15", "18:30", "18:45", "19:00", "19:15", "19:30", "19:45", "20:00", "20:15", "20:30", "20:45", "21:00", "21:15", "21:30", "21:45", "22:00", "22:15", "22:30", "22:45", "23:00", "23:15", "23:30", "23:45"};
int ch1[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,5,12,24,36,48,60,72,84,96,108,120,132,144,156,168,180,192,204,216,228,240,232,224,216,208,200,192,184,176,168,160,152,144,136,128,120,112,104,96,88,80,72,64,56,48,40,32,24,16,5,0,0,0,0,0,0,0,0,0,0};
int ch2[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,8,18,36,54,72,90,108,126,144,162,180,198,216,234,252,237,222,207,192,177,162,147,132,117,102,87,72,57,42,27,12,5,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
int ch3[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,9,18,27,36,45,54,63,72,81,90,99,108,117,126,135,144,153,162,153,144,135,126,117,108,99,90,81,72,63,54,45,36,27,18,9,3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
int ch4[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,6,18,36,54,72,90,108,126,144,150,139,128,117,106,95,84,73,62,51,40,29,18,7,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
int fan[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,25,50,75,100,125,150,175,200,255,255,200,175,150,125,100,75,50,25,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
void setup() /*----( SETUP: RUNS ONCE )----*/
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(3, OUTPUT);
// Start rtc stuff
Wire.begin();
rtc.begin();
}/*--(end setup )---*/
void loop() /*----( LOOP: RUNS CONSTANTLY )----*/
DateTime now = rtc.now(); //get the current date-time
int HR = now.hour();
int MIN = now.minute();
String timeNow= String(HR)+":"+String(MIN);
for (int x=0; x<sizeof(ledTime); x=x+1){
if (String(ledTime[x]) == timeNow){
analogWrite(5, ch4[x]);
analogWrite(6, ch3[x]);
analogWrite(9, ch2[x]);
analogWrite(10, ch1[x]);
analogWrite(3, fan[x]);
x = sizeof(ledTime);
}/* --(end main loop )-- */
I’m guessing that the memory usage is cause of the arrays, is there a better way to set it up.
Also in the loop I go through to check if the current timematches any in the array using a for loop, does the arduino ide have something like python where you can get an index from a value.
