Code or tutorial to send data from Uno to Azure IoT Hub or Event Hub
Any experience to share with me about how to send for example temperature data to Azure?
Hi Kenny,
The below mentioned blogs documents/describes the process of building a temperature and humidity sensor component, how to stream the sensor data to Microsoft Azure Event Hub, perform some analytics operations and react upon the data with respect to certain pre-defined thresholds.
This blog post is in three series:
Hope this helps.
Regards,
Pradeep
Hi,Can the arduino uno connect to AZURE IoT hubs??
