Code order of execution - Arduino newbie
Hi All Im trying to get a pressure switch to open a solonoid and alow it achieve a set pressure before triggering a switch on pin5 pulling it low which then releases the pressure on the solonoid for a pre set time then adding a value to the counter before repeating.
once the counter has achieved 30 cycles it should delay indefinately
the problem I am having is how the code is executing it seems to be skipping the loop I have tried to put in place and jumps straight to delaying indefinitely after the switch pulls low for the first time.
See linked flow chart explaining what I am trying to achieve;
The serial monitor log:
Void setup complete
Loop started
Switch pressed beginning 30 cycles
pin high pause
cycles completed:
1
cycles complete!!
1
delay indefinetely
and the code here:
// Pressure cycling code change variable 'solonoidlowtimer' to adjust time delay between solonoid active and inactive
// Try to avoid solonoid on time exeeding the time duration of solonoid off due to overheating
int solonoidpin = 9;   // Solonoid is connected to digital pin 9
int switchPin = 5;   // switch connected to digital pin 5
int startButton = 6; // button to start cycle code
int counter = 0;
int solonoidlowtimer = 1000;  //Time delay for the solonoid being in relaxed position
  delay (200);
   pinMode(solonoidpin, OUTPUT);   // sets the Solonoid to be an output
    pinMode(startButton, INPUT);   // sets the switchPin to be an input
  pinMode(switchPin, INPUT);   // sets the switchPin to be an input
  digitalWrite(switchPin, HIGH);   // sets the default (unpressed) state of switchPin to Low
  Serial.println("Void setup complete");
void loop()   // run over and over again
  Serial.println("Loop started");
  counter =0;
    if (counter < 30)
     { for (int ii = 0; ii < 30; ii++);
      { Serial.println("Switch pressed beginning 30 cycles");
          delay (20);
         digitalWrite(solonoidpin, HIGH);
       Serial.println("pin high pause");
    while  (digitalRead(switchPin)== HIGH);
        digitalRead(switchPin);
        delay(20);
      counter++;
    digitalWrite(solonoidpin, LOW);
      delay(solonoidlowtimer);   //off period to return pressure to zero
    Serial.println("cycles completed:");
    Serial.println(counter);
     else;
if (counter > 29);    //  Check to see if cycling is still required
  Serial.println("cycles complete!!");
  Serial.println("delay indefinetely");
  solonoidpin = 1;
delay (1000000000000000);
Im 99% sure its to do with how I stack my '}'s I’ve tried numerous ways of trying to fix it an it just ends up breaking in a new and unsuspecting way haha… now i’m seeking a degree of insight from someone with abilities above my own… (not a challange haha!)
Many thanks in advance!
Ok, so I have just solved it… after spending a few hours looking at it 2mins after I post I’ve resolved it with a couple of simple changes
int counter = 0;
  delay (200);
    counter =0;
    if (counter < 30)
      { Serial.println("Switch pressed beginning 1000 cycles");
          delay (20);
        delay(20);
      counter++;
     else;
if (counter > 29)    //  Check to see if cycling is still required
  solonoidpin = 1;
Any constructive criticism of what I have written would still be appreciated :slight_smile:
First, try and format the code better so it’s easier to read. The IDE can help you with auto format (press Ctrl+T). But I did to do some clean up myself. A lot of extra new lines. Also, after a {, go to a new line.
int counter = 0;
  delay (200);
  counter = 0;
  if (counter < 30)
      delay (20);
      while  (digitalRead(switchPin) == HIGH);
        delay(20);
      counter++;
  else;
      solonoidpin = 1;
And after that I spotted the same error twice:
 else;
OEPS! The statements ends after a ; :wink:
Extra tips:
You do know you don’t need an external resistor if you do
pinMode(switchPin, INPUT_PULLUP);   // sets the switchPin to be an input
Some examples of bad comments
Untrue comments are worse than no comment at all. To avoid this, don’t repeat yourself in the comments
If you want to have the pin HIGH as default, switch the two statements. First a digitalWrite() and a pinMode() after that. Now the pin is LOW for a very small time. Might not hurt but can be avoided.
Make it easier for yourself by using the same name scheme throughout. Aka solenoidPin and solenoidLowTime (it’s not a timer).
Also, ever needed to have pin -12678? An byte is a better suited variable type. And make it const because you never change it. And I like to start the variable name with a capital to remember me it’s a const.
const byte SolenoidPin = 9;
And your code talks about a start button (which seems smart) but you never use it.
Also, the flow diagram talks about 1000 cycles.
        delay(20);
The digitalRead() inside does nothing…
Also, this is a good time to talk about blocking code. It’s better to let the loop() loop (hence the name). So instead of locking the code in a loop full of waiting, just let the loop() do the looping and simply do nothing if you don’t want to :smiley: But then again, you need to get rid of delay() as well. For now this isn’t a real problem because you can do what you want. But note it’s nearly impossible to add different stuff to the code if you want to do more.
No need to check again. If it’s not < 30 then you know it’s above 29;)
For sure it’s a long time but it’s NOT indefinitely…
while(true);
is. But looking code like that is usually seen as ugly. And that’s where a nice start button would be handy.
Thank you very much septillion, alot of the minor typos/ comments come from trouble shooting and changing little bits obviously missing the good practice to double check the comments beside
the same goes for the 1000 cycles - I dropped it down to 30 so I could check the delay function worked correctly, and removal of the start button was simply to make everything a touch less complex to trouble shoot.. its back in now :)
I'll give it a revamp incorporating your comments
Thank you for the time you spared on this!
