Code Problem. TTP223/Buzzer
Hello:
I am a total beginner with the code. I am trying to activate a buzzer with a TTP223, but I have problems trying to integrate the two devices. This is what I did:
//detector.ino
#define PINSENSOR 7
#define BUZZER 9
int sound = 250;
int F_Estado(int pin){
return digitalRead(pin);
void F_Comunicacion (int Estado){
if (Estado) {
Serial.print("DETECTION");
else{
Serial.print("NO DETECTION");
pinMode (PINSENSOR, INPUT);
pinMode (BUZZER, OUTPUT);
void loop(){
 if (digitalRead( 7 )== HIGH) {
 digitalWrite (9,250);
 int estadoSensor = F_Estado(PINSENSOR);
F_Comunicacion (estadoSensor);
I wonder if someone can help me understand what that I have missing. Thank you. (First Pos
Please use code tags.
Read this before posting a programming question
Please edit your post, select the code, and put it between [code][/code] tags.
You can do that by hitting the “Code” icon above the posting area. It is the first icon, with the symbol: </>
You digitalWrite the value HIGH or LOW, not 250.
Thank you, I changed 250 for HIGH, but still no working,
V/R
Araneo
What does this achieve? You wrote a function to return the pin state? Why not just use digitalRead?
Where in your code are you activating a buzzer?
