code problem
Hi
I have some problem this PID code please help to check if I compile giving error.
double Setpoint,Input,tmp = 0;
const int numReading=10;
int readings[numReading];
int index=0;
int total=0;
int average=0;
int Duty_C=0;
int error=0;
int prev_error=0;
int out=0;
double P_Gain = 2, I_Gain = 0.3, D_Gain = 0.3; // PID Coefficients example
//I/O pin numbers
int sensorPin = 0;
int setpointPin = 1;
int PWM_Pin = 3;
  for (int thisReading = 0; //thisReading < numReadings;thisReading++)
  readings[thisReading] = 0;
Setpoint = analogRead (1);
pinMode(PWM_Pin, OUTPUT); // DC motor control
Setpoint = analogRead(setpointPin); //reading setpoint
delay(100); //100ms delay
//Reading temperature average of 10 samples
// subtract the last reading:
total= total - readings[index];
// read from the sensor:
readings[index] = analogRead(sensorPin);
// add the reading to the total:
total= total + readings[index];
// advance to the next position in the array:
index = index + 1;
delay(50);//50ms delay
// if we're at the end of the array...
if (index >= numReadings)
// ...wrap around to the beginning:
index = 0;
// calculate the average:
average = total / numReadings;
// send it to the computer (as ASCII digits)
delay(20); //20ms delay
//Temperature = (5*average*100)/1024
if(average <= 20 )// if the temperature is too low (equal to or less than 10 degrees)
digitalWrite(13,HIGH); //turn the blue LED on, which is connected to the digital pin 13
out = 0;
analogWrite(PWM_Pin, out); // Fan off
delay(100);
else if (average > 52) /
analogWrite(PWM_Pin, 255); //Fan Full speed , it's too hot!
delay(100);
else //otherwise calculate the needed speed
tmp = analogRead(1); //reading setpoint
Setpoint = tmp/10;
delay(100);//100ms d
error = average - Setpoint; //calculate the difference
delay(10);//10ms delay
if(error > 1)
Duty_C = pid(error, prev_error); // call pid function
out = error ;//+ 32; //run fan , calculated error + minimum output to run the fan
delay(200); //200ms delay
analogWrite(PWM_Pin, out); // write to the Fan
digitalWrite(13,HIGH); // write to the blue cool diod
delay(500); //0.5s delay
prev_error = error; //save old error to be used by the PID function
Duty_C = 0; // reset register
out = 0;
analogWrite(PWM_Pin, out); // motor off it's too cold and start blinking the blue diod
delay(200);
digitalWrite(13,LOW); // write to the blue cool diod
delay(200);
What do you think you are doing here?
Why is half the statement commented out?
The rest of the errors complain about numReadings. Why are you using numReadings in the code? You have a variable called numReading (without the s).
