code problem
hi i am new to the subject ;)
when I put this code get error and can not do.
int opened=0;
int outerSensor=0; int inne
rSensor=0; int countIn=0;
int countOut=0; int inSense=0; int outSense=0; int entering=0;
int exiting=0; int cycleLock=0; int timeout=0;
int delayLoop=0;
void setup(void) { Serial.begin(9600); pinMode(2, OUTPUT);
pinMode(3, OUTPUT); pinMode(4,OUTPUT);
d}
igitalWrite(4,HIGH);
void loop() { outerSensor=analogRead(A1); //delay(500);
innerSensor=analogRead(A0); Serial.println("a0");
Serial.println(innerSensor); //delay(1000); //Serial.println("a1");
Serial.println(outerSensor);
If outer sensor d
etects something, wait for 20 positives
before setting flag
if (outerSensor > 300) { countOut++;
if (countOut > 20) { outSense=1;
} else { countOut=0;
// Same again for the inside sensor, but with different sensitivity
if (innerSensor >300) {
countIn++;
if (countIn > 20) { inSense=1;
} else { countIn=0;
if (timeout > 0) { timeout--;}
If the sensor is triggered for the first time, open the door
if ((outSense == 1) && (timeout == 0))
entering=1;
openDoor();
} else if
((inSense == 1) && (timeout == 0)) { exiting=1;
openDoor();
This one is for entering from outside to inside
wait
until the inner sensor is triggered before closing...
if (entering > 0) {
entering++;
if (inSense == 1) { closeDoor(); ti
meout=200; entering=0;
exiting=0;
// Or until the timeout is reached if (entering > 1000) {
entering=0;
exiting=0;
closeDoor();
timeout=200;
// Same again but the other way around...
if (exiting > 0) { exiting++;
if (outSense == 1) { clo
seDoor(); timeout=200; exiting=0;
entering=0;
if (exiting > 1000) { exiting=0; entering=0; closeDoor();
timeout=200;
inSense=0;
outSense=0;
// The open and close door routines
these trigger a relay which
in turn supplies 24V to the pn
eumatic solenoids...timings are
slightly different and tuned to the door characteristics
void openDoor() {
digitalWrite(3, HIGH); delay(1100); digitalWrite(3, LOW);
void closeDoor()
digitalWrite(2, HIGH); delay(750); digitalWrite(2, LOW);
assistance please
d}
What's that?
seDoor();
And that?
It's mainly just line breaks. How did you get your code in such a state?
code is a project of the web ::slight_smile:
AWOL:
d}
What's that?
seDoor();
And that?
I'm very new and do not know much about programming
Where did you get this code from?
ardujet:
It looks like you need to spend a bit of time studying.
Look at the Arduino Reference section so you can see what functions are available. That should help you to see that, for example igitalWrite(4,HIGH); should be
digitalWrite(4,HIGH);
And from that you might see the pattern that clo and seDoor(); are not meant to be on different lines.
You could also try a more effective way of getting code from the web without errors.
...R
thanks for the help, the code is this website, but not if I have to keep creating the code, if not complete or incomplete.
what I want is to close and open a sliding door for the cat. :wink:
I'm sorry, I don't understand what you mean by that.
AWOL:
I get error on line
AWOL:
This is the web.
Have you tried contacting Ashis Mohapatra and Aman Anand?
Put that code aside and try working through some of the examples provided in the IDE.
ardujet:
Search this Forum (using Google) - there are lots of Threads about doors or flaps for pets/dogs/cats.
...R
OK I've taken out the silly line break issues. But you should start learning about how this code works (if indeed it even does.
int opened=0;
int outerSensor=0; int innerSensor=0; int countIn=0;
int delayLoop=0;
void setup(void)
//If outer sensor detects something, wait for 20 positives before setting flag
   countOut++;
   if (countOut > 20)
       outSense=1;
   countOut=0;
  countIn++;
  if (countIn > 20)
     inSense=1;
   countIn=0;
if (timeout > 0)
   timeout--;
//If the sensor is triggered for the first time, open the door
  entering=1;
  openDoor();
else if ((inSense == 1) && (timeout == 0))
  exiting=1;
  openDoor();
//This one is for entering from outside to inside-wait until the inner sensor is triggered before closing...
if (entering > 0)
  entering++;
  if (inSense == 1)
    { closeDoor();
      timeout=200;
      entering=0;
      exiting=0;
  entering=0;
  exiting=0;
  closeDoor();
  timeout=200;
if (exiting > 0)
  exiting++;
  if (outSense == 1)
    { closeDoor();
    timeout=200;
    exiting=0;
    entering=0;
if (exiting > 1000)
   exiting=0;
   entering=0;
   closeDoor();
   timeout=200;
inSense=0;
outSense=0;
// The open and close door routines-these trigger a relay which in turn supplies 24V to the pn
//eumatic solenoids...timings are
//slightly different and tuned to the door characteristics
void openDoor()
delay(1100);
void closeDoor()
delay(750);
KenF!!! thank you very much for the help and put the code in order.
really appreciate the time you took to look at this code. You must understand that I have started on this recently and I'm still very green.
try to learn by watching people work. Thank you !!!! :wink:
Thank you all for help!!
