Hi, i use a GSM module (SIM900A) and an GPS module (NEO6MV2) , I put the code on Arduino UNO and when I send the sms with the key word i dont receive any answear from the device. Can someoane tell me why ? Thanks
#include <SoftwareSerial.h>
#include <string.h>
#include <TinyGPS.h>
SoftwareSerial Sim900Serial(2, 3);
byte buffer[128]; // buffer array for data recieve over serial port
int count = 0; // counter for buffer array
SoftwareSerial GPS(4, 5);
TinyGPS gps;
unsigned long fix_age;
long lat, lon;
float LAT, LON;
void gpsdump(TinyGPS &gps);
bool feedgps();
void getGPS();
void SIM900power() // software equivalent of pressing the GSM shield "power" button
digitalWrite(9, HIGH);
Sim900_Inti();
Sim900Serial.begin(19200); // the SIM900 baud rate
GPS.begin(9600); // GPS module baud rate
Serial.begin(19200); // the Serial port of Arduino baud rate.
Serial.println("GPS Start");
Sim900_Inti();
Sim900Serial.listen();
if (Sim900Serial.available()) // If date is comming from from GSM shield)
while (Sim900Serial.available()) // reading data into char array
buffer[count++] = Sim900Serial.read(); // writing data into array
if (count == 64)break;
Serial.write(buffer, count); // if no data transmission ends, write buffer to hardware serial port
Cmd_Read_Act(); //Read the 'COMMAND' sent to SIM900 through SMS
clearBufferArray(); // call clearBufferArray function to clear the storaged data from the array
count = 0; // set counter of while loop to zero
if (Serial.available()) // if data is available on hardwareserial port ==> data is comming from PC or notebook
Sim900Serial.println(Serial.read()); // write it to the GPRS shield
void clearBufferArray() // function to clear buffer array
for (int i = 0; i < count; i++)
buffer[i] = 0; // clear all index of array with command NULL
void Sim900_Inti(void)
Sim900Serial.println("AT+CMGF=1"); // Set GSM shield to sms mode
Sim900Serial.println("AT+CNMI=2,2");
Serial.println("AT CMGF=1");
void Cmd_Read_Act(void) //Function reads the SMS sent to SIM900 shield.
char buffer2[64];
buffer2[i] = char(buffer[i]);
if (strstr(buffer2, "TRACK")) //Comparing password entered with password stored in program
Serial.println("Password Authenticated.");
Serial.println("Sending reply SMS. ");
SendTextMessage();
void SendTextMessage()
Sim900Serial.print("AT+CMGF=1\r"); //Sending the SMS in text mode
delay(100);
Sim900Serial.println("AT + CMGS = \"+407*****476\"");//The predefined phone number
//Sim900Serial.print("AT+CMGS=");
//Sim900Serial.println("+60174432599");
delay(100);
Sim900Serial.println("Please wait while Module calculates position");//the content of the message
delay(100);
Sim900Serial.println((char)26);//the ASCII code of the ctrl z is 26
delay(100);
Sim900Serial.println();
delay(5000);
int counter = 0;
GPS.listen();
for (;;)
long lat, lon;
unsigned long fix_age, time, date, speed, course;
unsigned long chars;
unsigned short sentences, failed_checksum;
long Latitude, Longitude;
// retrieves /- lat/long in 100000ths of a degree
gps.get_position(&lat, &lon, &fix_age);
getGPS();
Serial.print("Latitude : ");
Serial.print(LAT / 1000000, 7);
Serial.print(" :: Longitude : ");
Serial.println(LON / 1000000, 7);
/*if (LAT == 0 && LON == 0)
continue;
counter ;
if (counter<30)
continue;
delay(100);
Sim900Serial.println("AT + CMGS = \"+407*******76\"");//The predefined phone number
delay(100);
Sim900Serial.print("Latitude : ");
Sim900Serial.print(LAT / 1000000, 7);
Sim900Serial.print(" :: Longitude : ");
Sim900Serial.println(LON / 1000000, 7); //the content of the message
delay(100);
delay(5000);
counter = 0;
void getGPS()
bool newdata = false;
unsigned long start = millis();
while (millis() - start < 1000)
if (feedgps ())
newdata = true;
if (newdata)
gpsdump(gps);
bool feedgps()
while (GPS.available())
if (gps.encode(GPS.read()))
return true;
} return 0;
gps.get_position(&lat, &lon);
LAT = lat;
LON = lon;
feedgps();
