Hello all,
I tried to use the "hello world" example from Tensor Flow Lite examples
for a CNN tensorflow lite inference.
I use the "Arduino nano 33 ble" card.
I have converted the .tflite model to .cc model .
The network should get an array input of 6 IMU signals over 150 time stamps (150*6 array, uint8).
The output of the CNN should be true\false (detect if human is active or not).
Finally, I need to implement this code on M4 processor with just 256KB of memory, so I just want
to understand how to compute the actual footprint of the sketch.
I tried to define 150*6 array of zeros just to try and compile the sketch with Arduino IDE but I got the attached error..
Someone can help me ? I am new to Arduino and don't have alot of experience with C coding.
Summary :
- need help with compilation errors.
- need to understand actual footprint of sketch on M4 processor without overheads.
Here is the code from main sketch:
#include <TensorFlowLite.h>
#include "constants.h"
#include "main_functions.h"
#include "model.h"
#include "output_handler.h"
#include "tensorflow/lite/micro/all_ops_resolver.h"
#include "tensorflow/lite/micro/micro_interpreter.h"
#include "tensorflow/lite/micro/micro_log.h"
#include "tensorflow/lite/micro/system_setup.h"
#include "tensorflow/lite/schema/schema_generated.h"
// Globals, used for compatibility with Arduino-style sketches.
namespace {
const tflite::Model* model = nullptr;
tflite::MicroInterpreter* interpreter = nullptr;
//TfLiteTensor* input = nullptr;
TfLiteTensor* output = nullptr;
int inference_count = 0;
// Sharon change memory allocation 6X150X8 = 7200 bytes ()
// constexpr int kTensorArenaSize = 2000;
constexpr int kTensorArenaSize = 8192;
// Keep aligned to 16 bytes for CMSIS
alignas(16) uint8_t tensor_arena[kTensorArenaSize];
} // namespace
// The name of this function is important for Arduino compatibility.
tflite::InitializeTarget();
// Map the model into a usable data structure. This doesn't involve any
// copying or parsing, it's a very lightweight operation.
model = tflite::GetModel(g_model);
if (model->version() != TFLITE_SCHEMA_VERSION) {
MicroPrintf(
"Model provided is schema version %d not equal "
"to supported version %d.",
model->version(), TFLITE_SCHEMA_VERSION);
return;
// This pulls in all the operation implementations we need.
// NOLINTNEXTLINE(runtime-global-variables)
static tflite::AllOpsResolver resolver;
// Build an interpreter to run the model with.
static tflite::MicroInterpreter static_interpreter(
model, resolver, tensor_arena, kTensorArenaSize);
interpreter = &static_interpreter;
// Allocate memory from the tensor_arena for the model's tensors.
TfLiteStatus allocate_status = interpreter->AllocateTensors();
if (allocate_status != kTfLiteOk) {
MicroPrintf("AllocateTensors() failed");
return;
// define input float array of 3Xgyro + 3Acc signals with all zeros - sharon
uint8_array_t Inarray[150][6] = {0};
// Obtain pointers to the model's input and output tensors.
//input = interpreter->input(0);
input = Inarray;
output = interpreter->output(0);
// Keep track of how many inferences we have performed.
// Calculate an x value to feed into the model. We compare the current
// inference_count to the number of inferences per cycle to determine
// our position within the range of possible x values the model was
// trained on, and use this to calculate a value.
float position = static_cast(inference_count) /
static_cast(kInferencesPerCycle);
float x = position * kXrange;
// Quantize the input from floating-point to integer
int8_t x_quantized = x / input->params.scale + input->params.zero_point;
// Place the quantized input in the model's input tensor
input->data.int8[0] = x_quantized;
// Run inference, and report any error
TfLiteStatus invoke_status = interpreter->Invoke();
if (invoke_status != kTfLiteOk) {
MicroPrintf("Invoke failed on x: %f\n", static_cast(x));
return;
// Obtain the quantized output from model's output tensor
int8_t y_quantized = output->data.int8[0];
// Dequantize the output from integer to floating-point
float y = (y_quantized - output->params.zero_point) * output->params.scale;
// Output the results. A custom HandleOutput function can be implemented
// for each supported hardware target.
HandleOutput(x, y);
// Increment the inference_counter, and reset it if we have reached
// the total number per cycle
inference_count += 1;
if (inference_count >= kInferencesPerCycle) inference_count = 0;
Sharon
