code related uploading problem..
Hi All
i have a problem with up loading a sketch to my Mega2560…
this code uploads…
// include the library code:
#include <LiquidCrystal.h>
const int ledPin = 13; // the pin that the LED is attached to
int incomingByte;      // a variable to read incoming serial data into
 // initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  lcd.begin(20, 4);
  // initialize serial communication:
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
// display something..
  lcd.setCursor(0, 0);
 lcd.print("Hello");
 delay(1500);
 lcd.clear();
  // see if there's incoming serial data:
  if (Serial.available() > 0) {
    // read the oldest byte in the serial buffer:
    incomingByte = Serial.read();
    // if it's a capital H (ASCII 72), turn on the LED:
    if (incomingByte == 'H') {
      digitalWrite(ledPin, HIGH);
       // Display LED state
      //SetDisp();
      //lcd.print("Led is ON!!!"); // commented uploads ok, un-commented doesn't upload
    // if it's an L (ASCII 76) turn off the LED:
    if (incomingByte == 'L') {
      digitalWrite(ledPin, LOW);
      //SetDisp();
      //lcd.print("Led is OFF!!!"); // commented uploads ok, un-commented doesn't upload
// separate sub as a test
/*void SetDisp(){
  if (digitalRead(ledPin == LOW)){
    lcd.setCursor(0,0);
    lcd.print("Led is OFF!!");
else{
if i un-comment either of the lcd.print statements or try to use the separate sub SetDisp the upload starts and then eventually times out i am uploading over the inbuilt usb.
i have tried it on 2 different computers and both versions of current Arduino software…
i am sure i must be doing something stupid but cannot see it…
thanks in advance
Don't use !!! it is a code captured by the boot loader or some other intermediate process.
Try printing !! then a separate ! to avoid the problem.
pYro_65 Many many thanks.... it works... so a question is there a list of bootloader capture codes (or have i not read the manual properly)?
thanks again...
Not that I know of, search the forums though. This particular issue has arisen many times, the answer is probably in one of the threads.
Or you could have a scan through the bootloader code.
pYro_65 thanks i will do that.
Hi mellis i assume the next post was related to my post? i did check the uploading section of the troubleshooting guide and saw nothing that was related to whether one variation of a sketch uploads and another doesn't, maybe i didn't look hard enough.
