Code runs on Duemilanove but not on UNO
When I run this on an UNO it seem to get hung up in the armed loop works completely fine on a Duemilanove
Can anyone tell me why?
Or what i can do to fix?
This is the code:
const int led = 13;
String inputString = "";         // a string to hold incoming data
boolean stringComplete = false;  // whether the string is complete
boolean start = false;
boolean print1 = true;
String PW = "test";
  pinMode(led, OUTPUT);
  Serial.begin(9600);                                 // initialize serial:
  if (print1 == true)
    Serial.println("Disarmed. Enter password to Arm");  //print "Armed"
    print1 = false;                                      // make sure only print message once
  readkeyboard();                                     //call the function
  if (stringComplete == true)                         // print the string when a newline arrives:
    inputString = "";                                 // clear the string:
    stringComplete = false;                           // clear the flag
  while (start == true)                              // while start is true run the armed function
    Armed();                                          //call the function
void Armed()                                          //armed function
  if (print1 == false)                                 // make sure only print message once
    Serial.println("Armed! Enter password to disarm"); //print "Armed"
    print1 = true;                                      // make sure only print message once
  if (start == false)
    digitalWrite(led, LOW);
    return;
  digitalWrite(led, HIGH);                         //turn on led or insert other code in here eg blink without delay + buttons
void readkeyboard()
  while (Serial.available()) {
    char inChar = (char)Serial.read();// get the new byte:
    inputString += inChar; // add it to the inputString:
    if (inChar == '\r') // if the incoming character is a cr, set a flag
      stringComplete = true; // so the main loop can do something about it:
      delay(10);
    if (inputString == PW)
      start = !start;    // toggle
The examples in Serial Input Basics don' rely on a delay() when receiving data and may solve the problem.
Are you sure that a '\r' chraracter is sent in both cases?
...R
Thanks, I have removed the delay. Still the same result. Runs perfect on Duemilanove. On the UNO I can get into the armed loop but will not exit out.
"I'm confused"
Did you try my examples?
I would be interested to hear if they don't work.
I presume you mean one of these old boards
...R
Not sure what was going on but appears to working now on both boards. Thanks for the help.
