Code sequencing issue
I am using an elseif code to run a motor on a robot, however I am having problems with a small section of my code.
The problem is that when the light is above a certain value (600) I want to run a 3rd motor forward, then move the robot and finally reverse the 3rd motor. The code I have looks ike this:
else if (lightright and lightleft > 600)
stop(5, 0); // stop the robot
motor3forward (100); // 3rd motor forward for 100ms
motor3stop(); // stop the 3rd motor
turn_left (100, 75); // turn the robot left
motor3reverse (100); // 3rd motor revered for 100ms
delay (5000);
but what happens when I run the robot is the 3rd motor will run forward and immediately reverse then the robot will turn left, I thought it should run through all the steps one after another but it seems to run all at the same time.
I have also tried putting a delay between all the action but this just makes each section run for the time it is set to PLUS the time of the delay!
I have a final year university crit on Wednesday and need this finished! Thanks in advance
else if (lightright > 600 and lightleft > 600 ?
aimes32:
This compiles? It should be:
else if (lightright && lightleft > 600)
I suspect your code is not compiling and your uploading an earlier version.
delay (5000);
If motor3forward(100) is only supposed to run the motor for 100 ms, why do you need to follow it with a motor3stop() ???
If correcting the issue already pointed out does not help, we'll need to see the code for motor3forward().
Yes, why not?
It doesn't do what the OP wants, but it compiles.
It tests to see if lightright is non-zero and that lightleft is greater than 600, not that both are greater than 600.
skyjumper:
aimes32:
Check out:
I have now updated it to "else if (lightright && lightleft > 600)".
"and" is perfectly acceptable, however see my comments about what this expression does, and whether or not that is what you want?
Thans for the 'and/&&' tip off, I have now changed this. I have also taken out the motor3stop() after each action as I only added this in hope of it forcing the code to run in the order I want but I doesn't make a difference. My code now reads:
stop(5, 0);
delay (500);
I think what is happening is that motor3forward runs at the same time as turn_left, then motor3reverse runs for 100 plus the delay 500, no delay is hapening between the actions.
My setup looks like:
void motor3reverse(int dist) {
digitalWrite (motorPin1, HIGH);
digitalWrite (motorPin2, LOW);
delay (dist);
void motor3forward(int dist) {
digitalWrite (motorPin1, LOW);
digitalWrite (motorPin2, HIGH);
delay (dist);
void motor3stop() {
Are you agree that :
means 'if (lightright!=0) AND (lightleft > 600))' ....
and does not means : if (lightright>600) AND (lightleft>600))
Agree?
I've been saying it since reply #1.
If you want your forward and stop function to run only for the specified delay and then stop, then the functions themselves should issue a stop after the delay, something like:
      delay (dist);
      motor3stop();
without the stop after the delay, the motor is going to keep on doing what it was last told to do.
I would be interested in seeing your stop and turn functions as well, and why you are passing two params into each.
And finally, please post your code in code tags, as I've done above. Makes it easier to read.
I've changed that now so motor3stop is included in the setup but still no change in the outcome. My stop and turn functions look like:
void turn_left (int angle, int vel) {      // turn left: left-hand motor stopped, right-hand motor forward
              digitalWrite (dirA, fwdA);
              digitalWrite (dirB, revB);
              analogWrite (speedA, vel);
              digitalWrite (speedB, LOW);       // left-hand motor speed set to zero
              delay (angle);                          // wait for a while (angle in mSeconds)
void stop(int dist, int vel) {                              // stop: force both motor speeds to 0 (low)
              digitalWrite (speedA, LOW);
I am not sure what you mean by passing two params into each, I've not been using arduino long and have only grasped the basics.
Apologies for the lack of structure to my posts too, I also haven't used forums before!
Can you please post all you code as it is now?
// define the pins used by the Robot Shield
int lock = 5;            // lock is disable input - program will not run if lock is in place
                         // NOTE: DO NOT use pins 0 or 1 for the lock as this will stop
                         // you being able to program your robot!
int speedA = 6;          // pin 6 sets the speed of motor A (this is a PWM output)
int speedB = 9;          // pin 9 sets the speed of motor B (this is a PWM output)
int dirA = 8;            // pin 8 sets the direction of motor A
int dirB = 7;            // pin 7 sets the direction of motor B
int lightleft;
int lightright;
int photoresistorleft = 5;  // define the pin for left photoresistor
int photoresistorright = 4;  //define the pin for right photoresistor
int IRpinLeft = 2;           // analog pin for reading the IR sensor
int IRpinRight = 3;           // analog pin for reading the IR sensor
int motorPin1 = 3;          // pin 2 on L293D
int motorPin2 = 5;          // pin 7 on L293D
int enablePin = 1;          // pin 1 on L293D
// define the direction of motor rotation - this allows you change the  direction without effecting the hardware
int fwdA  =  LOW;         // this sketch assumes that motor A is the right-hand motor of your robot (looking from the back of your robot)
int revA  =  HIGH;        // (note this should ALWAYS be opposite the fwdA)
int fwdB  =  LOW;         //
int revB  =  HIGH;        // (note this should ALWAYS be opposite the fwdB)
// define variables used
int dist;
int angle;
int vel;
void setup() {                             // sets up the pinModes for the pins we are using
              pinMode (dirA, OUTPUT);
              pinMode (dirB, OUTPUT);
              pinMode (speedA, OUTPUT);
              pinMode (speedB, OUTPUT);
              pinMode(motorPin1, OUTPUT);
              pinMode(motorPin2, OUTPUT);
              pinMode(enablePin, OUTPUT);
              digitalWrite(enablePin, HIGH);
void forward(int dist, int vel) {          // forward: both motors set to forward direction
              digitalWrite (dirB, fwdB);
              analogWrite (speedA, vel);   // both motors set to same speed
              analogWrite (speedB, vel);
              delay (dist);                // wait for a while (dist in mSeconds)
void reverse(int dist, int vel) {          // reverse: both motors set to reverse direction
              digitalWrite (dirA, revA);
void rot_cw (int angle, int vel) {         // rotate clock-wise: right-hand motor reversed, left-hand motor forward
void rot_ccw (int angle, int vel) {        // rotate counter-clock-wise: right-hand motor forward, left-hand motor reversed
void turn_right (int angle, int vel) {     // turn right: right-hand motor stopped, left-hand motor forward
              digitalWrite (speedA, LOW);  // right-hand motor speed set to zero
    delay (dist);
    motor3stop();
      delay (dist);
      motor3stop();
void motor3stop() {
              lightleft = analogRead(photoresistorleft);
              lightright = analogRead(photoresistorright);
              float voltsLeft = analogRead(IRpinLeft)*0.0048828125;   // value from sensor * (5/1024) - if running 3.3.volts then change 5 to 3.3
              float distanceLeft = 65*pow(voltsLeft, -1.10);          // worked out from graph 65 = theretical distance / (1/Volts)S - luckylarry.co.uk
              float voltsRight = analogRead(IRpinRight)*0.0048828125;   // value from sensor * (5/1024) - if running 3.3.volts then change 5 to 3.3
              float distanceRight = 65*pow(voltsRight, -1.10);
              motor3stop();
              if (lightleft - lightright > 30)
                rot_ccw (500, 75);      // rotate clock-wise for 500 mS at speed 75
              else if (lightright - lightleft > 30)
                 rot_cw (500, 75);      // rotate clock-wise for 500 mS at speed 75
                stop(5, 0);
                delay(200);
                turn_left (300, 75);
                delay(200);
                delay (500);
              else if (distanceLeft < 35)
                  reverse(500, 75);        // reverse for 500 at 75
                  rot_cw (500,75);          // rotate clockwise for 500 at 75
              else if (distanceRight < 35)
                 reverse (500,75);        // reverse for 500 at 75
                 rot_ccw (500,75);        // rotate countercloackwise for 500 at 75
              else if (distanceLeft < 35 and distanceRight < 35)
                reverse (500, 75);      // reverse for one second at speed 75
                forward (200, 75);     // move forward for half a second (2000 ms) at speed 75 (75/255ths of full speed)
I'm going to ask again.
Is this:
really what you want to do?
I think so, I want it to be when both reading are larger than 600 then run the program. However this is not the problem I really need solving!
Have you read replies 1, 7 and 8?
Definitions like these:
int dirB = 7;
should really be qualified with "const".
I believe your problem isn't that your functions are running out of order (well, I knew that wasn't the problem from the start), but your functions are not doing what you think they are doing.
In other words, motor3forward() and motor3backwards aren't necessarily going to drive your vehicle forwards and backwards. Why? because you aren't explicitly setting your motor direction pins in those functions, so how do you know what direction the motors are set to run in?
I'm not sure your turn routines are driving the motors correctly either, but would need to know what "robot shield" you are using and how your motors are wired up to give advice.
What I would recommend is starting with a simple sketch that allows you to test each drive routine individually. Verify that your forward routine actually drives your robot forward (and then stops when it is complete), regardless the state of the IO points prior to calling the routine. Then do the same for each routine. I think you'll find all of them have some undesirable behavior on their own.
I have built up this sketch over time checking each stage, the driving of the robot was my first step and works as I believe it should ( the sketch was taken directly from what I was given along with the motor shield I bought, which is a Robot Bits Robot Sheild). I then added the sensors to determine which directon the robot moves, this again works as I want it to. The final stage that I have added is a 3rd motor using a L239D driver, not to drive the robot but to move a pen up and down to draw with.
Awol, I have read 1, 7 and 8, and on reflection else if (lightright > 600 and lightleft > 600) is what I am trying to do, but I have tried both that and else if (lightright && lightleft>600) and it makes no difference to how my third motor works.
Well, just don't do the latter.
Wow!
http://www.cppreference.com/wiki/keywords/and
Okay, I guess I learned something new (to me) about C++!
