Code simplification
This should be self explanatory. I want this function to convert 4 bytes into a single long.
Say I call the function as:
void send_data(250, 10, 134, 156, 98);
Noiw the actual function:
void send_data(byte address, byte byte1, byte byte2, byte byte3, byte byte4)
  byte mybyte[4] = 0;
  mybyte[0] = byte1;
  mybyte[1] = byte2;
  mybyte[2] = byte3;
  mybyte[3] = byte4;
  // Encode the variables into a 32 bit variable
  for ( int i = 0; i < 4; ++i )
    (reinterpret_cast<char*>(&transmitterdata))[i] = mybyte[i];
  ... now, do whatever with the processed variable...
I'm sure this can be simplified. Would it be possible to call the function as:
void send_data(address, myarray[4]);
Thanks
Should the number end up as: 2,501,013,415,698? Your example has 5 bytes, not 4.
Maybe use a union.
union LONGBYTES
  byte bytes[4];
  long longvalue;
LONGBYTES data;
data.bytes[0]=3;
data.bytes[1]=2;
data.bytes[2]=1;
data.bytes[3]=0;
Serial.println(data.longvalue);
Not tested.
The code already converts the 4 bytes to a long, but I would like to pass an array to the function rather than 4 individual bytes. Is this possible?
casemod:
hint: the name of the array is a pointer to the first element of the array
something like this:
byte myByte[4] = {10, 134, 156, 98};
  send_data(250, myByte);  // myByte degrades to a pointer to myByte[0]
void send_data(byte address, byte* value)
  for ( int i = 0; i < 4; i++ )
    Serial.println(value[i]);
    //(reinterpret_cast<char*>(&transmitterdata))[i] = value[i];
