Code size difference
These 2 bits of code toggles an output, but code 1 is 68 bytes smaller than code 2 when compiled.
Why is there so much difference ?
Kim
Code 1 (smaller): //***************************************** void HeartBeat(void) { static byte state; // private variable declared if (state>0) { digitalWrite(Heartbeat,HIGH); state= 0; delay(100); } else { digitalWrite(Heartbeat,LOW); state= 1; delay(100); } return; } //********************************************
Code 2 (bigger): //****************************************** void HeartBeat(void) { static boolean state; // private variable declared here
digitalWrite(Heartbeat,state); state=!state; //toggle output state delay(100);
return; }
Okay, I guess I should look at the assembly listing as well.
Spoke to soon. When I press shift and click compile, all it does is compile normally. I cannot see any assembly code
Any suggestions ?
Using Arduino V1 on Ubuntu
Prior to 1.0, holding the shift key triggered verbose output. Now, it is a setting on the preferences panel.
Okay, changed the setting in preferences to show verbose output during compilation. But I can only see object files, which I cannot read with my editor
Hmm, any suggestions ?
Kim
Avr-objdump
Thanks Didn't know that Linux came with a built in disassembler :-) Command line only, tho. More stuff to remember.
