Code "Skipping" sections? Arduino Uno and MEGA RF 433MHz
Hey everyone,
So the problem is my code doesn't seem to be executing properly? I'm a bit confused. I initally had an IR breakbeam ckt on an UNO and it was tx'ing to a MEGA. All was well so I decided to try and implement the IR ckt onto the MEGA itself. It wont work at all now?
What have I done wrong? is it my code placement? Should I have it in an Interrput? I'm at a loss.
//Libraries Included in sketch
#include <VirtualWire.h>
#include<Wire.h>
#include <LCD.h>
#include <Keypad.h>
//LCD Display Declarations
const int rows = 4;
const int cols= 20;
//test LED
int ledR = 13;
int sensor_IR = 10;
int sensorValue;
//Keypad Declarations
const byte keyRows = 4;
const byte keyCols= 3;
//Define i2c address
#define I2C_ADD 0x27
#define B_light 3
//Display Variables
#define d4  4
#define d5  5
#define d6  6
#define d7  7
#define EN  2
#define RW  1
#define RS  0
//Initlize LCD
LiquidCrystal_I2C  lcd(I2C_ADD, EN, RW, RS, d4, d5, d6, d7);
//Array for keypad
char keys[keyRows][keyCols] =
  {{'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'*','0','#'},};
//Battery variable Declarations
int voltDiv = A0;
int divider;
int vRef=10;
int valNew = 0;
int percentVolt=0;
float voltage;
//LCD battery display
byte battery[8] =
0b00100,
0b01110,
0b01110,
0b01110,
0b01110,
0b01110,
0b01110,
0b01110
//Arduino pins keypad is connected to
byte rowPins[keyRows] = {5,6,7,8};
byte colPins[keyCols] = {2,3,4};
Keypad keypad = Keypad(makeKeymap(keys),rowPins,colPins,keyRows,keyCols);
int count = 0;
char keyNew[3];
int amount;
  pinMode(sensor_IR, INPUT_PULLUP);
  pinMode(ledR, OUTPUT);
  //LCD settings
  lcd.setBacklightPin(B_light,POSITIVE);
  lcd.setBacklight(HIGH);
  lcd.begin(20,4);
  lcd.setCursor(5,1);
  lcd.print("FOOTFALL COUNTER");
  delay(2000);
  lcd.clear();
  //RX setup
 vw_set_ptt_inverted(true);
 vw_set_rx_pin(12);
 vw_setup(4000);
 vw_rx_start();
   sensorValue = digitalRead(sensor_IR);
  if(sensorValue == LOW)
    digitalWrite(ledR, HIGH);
    digitalWrite(ledR,LOW);
 //Battery Function call
 batteryDisplay();
 //Setup Display code
  lcd.setCursor(0,1);
  lcd.print("Plese Enter");
  lcd.setCursor(0,2);
  lcd.print("Expected customers:");
  amount = GetCusto();
  lcd.print(amount);
int GetCusto()
  char key=keypad.getKey();
  int n;
  int count = 0;
  for(n=0;n<3;n++)
    keyNew[n] = keypad.waitForKey();
    lcd.print(keyNew[n]);
    count++;
  while(count==3)
    char key= keypad.getKey();
    if (key == '#')
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print("********************");
      lcd.setCursor(0,1);
      lcd.print("****** Stored ******");
      lcd.setCursor(0,2);
      lcd.setCursor(0,3);
      delay(2000);
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print("Customers left:");
      lcd.setCursor(10,1);
      lcd.print(keyNew);
    int r;
    r = atoi(keyNew);
    lcd.clear();
      lcd.setCursor(0,0);
      lcd.print(r);
void batteryDisplay(void)
  lcd.createChar(0, battery);
  lcd.setCursor(15, 0);
  lcd.write((uint8_t)0);
  divider = analogRead(voltDiv);
  voltage = (divider*vRef)/1023;
  percentVolt = voltage/5*100;
  lcd.setCursor(16,0);
  lcd.print(percentVolt);
  lcd.print("%");
I have tried putting the code into the keypad function, I've tried a function call, Ive tried moving to different locations of the loop. Also should note that the reason for the keypad is a footfall counter. When a person walks by it will be deducted from a set value inputted at the start of the day.
It would help to know exactly what you mean by "It wont work at all now". That's not much Information to go on. What exactly is NOT going how you expect and what exactly did you expect? What is your indication something is going wrong (for example, should do this after that but instead it just beeps).
On the UNO I had the IR breakbeam detecting when an object broke the IR beam, light up an LED, and decrement from a set value, i.e: Start off at 200, break the beam with my finger, LED goes off and count goes to 199 and so on for each consecutive break.
Moved the code and the circuit over to a MEGA, which has a keypad and display. The user enters the value and same as before, each time a person passes through the beam, an LED should light up and the count should go down. When I tried this, nothing happend, no count decrement, no LED light. Removed the count decrement code to test with an LED light, and still nothing.
