Im using Arduino Uno with RTC ds1307 and esp8266 (Blynk)
my code just stops at the setup function precisely on the Blynk.begin function.
I have discovered that If I just get rid of all related to RTClib.h or SimpleTimer it works just file alone.
Similar problem id described and solved here but is that exaple is used NodeMCU, not Arduino
As you see Im using more than those libraries in my code and the code is kind of long itself, it could be a memory shortage on Arduino side.
This is my full code:
#define BLYNK_PRINT Serial
#include <ESP8266_Lib.h>
#include <BlynkSimpleShieldEsp8266.h>
#include <WidgetRTC.h>
char auth[] = "";//private
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = ""; //private
char pass[] = "";//private
#include <SoftwareSerial.h>
SoftwareSerial EspSerial(5,6); // RX, TX
BlynkTimer timer;
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
#include <ShiftRegister74HC595.h>
#include <math.h>
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 rtc;
ShiftRegister74HC595<3> sr (2,3,4);
byte zero=0;
const int minusButton=8;
const int plusButton=9;
static int secPins [2][4]={{0,1,2,3},{4,5,6,7}};// first units then dec
static int minPins [2][4]={{8,9,10,11},{12,13,14,15}};
static int hourPins [2][4]={{16,17,18,19},{20,21,22,23}};
DateTime last;
byte decToBcd(byte val) {
return ((val/10*16) + (val%10));
byte bcdToDec(byte val) {
return ((val/16*10) + (val%16));
void setDateToRTC(byte seconde, byte minutee, byte houre, byte weekDaye, byte monthDaye, byte monthe){
Wire.beginTransmission(DS1307_ADDRESS);
Wire.write(zero); //stop Oscillator
Wire.write(decToBcd(seconde));
Wire.write(decToBcd(minutee));
Wire.write(decToBcd(houre));
Wire.write(decToBcd(weekDaye));
Wire.write(decToBcd(monthDaye));
Wire.write(decToBcd(monthe));
Wire.write(decToBcd(byte(2021)));
Wire.write(zero); //start
Wire.endTransmission();
void ClockHourWrite(){// get time and prints on the clocks digits
DateTime now = rtc.now();
Serial.println(String(now.second())+":"+now.minute()+":"+now.hour());
Serial.println(now.second());
nixieWrite(secPins[0],now.second()%10);//sec unit
if(floor(last.second()/10)!=floor(now.second()/10)){nixieWrite(secPins[1],floor(now.second()/10));}//sec dec
if(last.minute()%10!=now.minute()%10){nixieWrite(minPins[0],now.minute()%10);}
if(floor(last.minute()/10)!=floor(now.minute()/10)){nixieWrite(minPins[1],floor(now.minute()/10));}
if(last.hour()%10!=now.hour()%10){nixieWrite(hourPins[0],now.hour()%10);}
if(floor(last.hour()/10)!=floor(now.hour()/10)){nixieWrite(hourPins[1],floor(now.hour()/10));}
last=now;
void ClockDateWrite(){// get time and prints on the clocks digits
Serial.println(String(now.day())+":"+now.month()+":"+now.year()%2000);
if(last.day()!=now.day()){
nixieWrite(secPins[0],(now.year()%2000)%10);
nixieWrite(secPins[1],floor((now.year()%2000)/10));
nixieWrite(minPins[0],now.month()%10);
nixieWrite(minPins[1],floor(now.month()/10));
nixieWrite(hourPins[0],now.day()%10);
nixieWrite(hourPins[1],floor(now.day()/10));
last=now;
void ClockCustomWrite(){
//This will be custom number to display
void nixieWrite(int pins[],uint8_t value){// gets set of pins for nixie digit and number, and sends it to
sr.set(pins[3],(value & 0x08) >> 3);
sr.set(pins[2],(value & 0x04) >> 2);
sr.set(pins[1],(value & 0x02) >> 1);
sr.set(pins[0],value & 0x01);
BLYNK_CONNECTED() {
// Synchronize time on connection
Wrtc.begin();
int mode=1;
void clockLoop(){
Serial.println("clockLoop");
if(mode==1){
ClockHourWrite();
}else if(mode==2){
ClockDateWrite();}
else{
ClockCustomWrite();}
// Debug console
// Set ESP8266 baud rate
EspSerial.begin(ESP8266_BAUD);
delay(10);
Blynk.begin(auth, wifi, ssid, pass);
Serial.println("connected up!");
timer.setInterval(1000L, clockLoop);//every second call clockloop function
//rtc thing:
if (! rtc.begin()) {
Serial.println("rtcNotRunning");
//if (! rtc.isrunning()) {
//setDateToRTC(second(),minute(),hour(),weekday(),day(),month());
Serial.println(String(now.second())+":"+now.minute()+":"+now.hour()+" "+now.year());
last = now;
BLYNK_WRITE(V10) // V10 is the number of Virtual Pin
if(param.asInt()==mode){return;}
switch(param.asInt()){//change DisplayMode
case 1:
mode=1;
Serial.println("hour");
case 2:
mode=2;
Serial.println("date");
case 3:
mode=3;
Serial.println("Custom");
BLYNK_WRITE(V9)// set time to RTC from Blynk server
if(param.asInt()==1){
Blynk.run();
timer.run();
