code stops a few seconds after starting
I was writing this code to decode a signal which comes in a cable of 18bits, but when executing it it suddenly stops after 14-18 seconds of starting, what am i doing wrong?
Sorry for my bad english
const int pin_de_entrada = 2; //el 2 o el 3
const int margen = 20;
unsigned long ahora;
unsigned long ult_01;
unsigned long duracion;
bool siguiente_bit = 0;
bool paquete[18];
int indice;
  pinMode(pin_de_entrada, INPUT);
  pinMode(7, INPUT);
  attachInterrupt(digitalPinToInterrupt(pin_de_entrada), cambio, CHANGE);
  //if (digitalRead(7) == LOW) {
  for (int x = 0; x < 18; x++) {
    if (paquete[x] == 1) {
      Serial.print("1");
      Serial.print("0");
  //delay(200);
  Serial.println(ahora);
void cambio() {
  ahora = micros();
  bool entrada = digitalRead(pin_de_entrada);
  if (entrada == HIGH) {
    ult_01 = ahora;
    if (siguiente_bit == 0) {
      siguiente_bit = 1;
      siguiente_bit = 0;
  duracion = ahora - ult_01;
  if (duracion <= 28) {
    paquete[indice] = 0;
    indice++;
  if (duracion > 60 && duracion < 120) {
    paquete[indice] = 1;
    indice++;
  if (indice == 19) {
    indice = 0;
initialize indice to 0 or your first call to cambio is unpredictable.
You assume that indice will become exactly equal to 19 at some point,
if (indice == 19) { indice = 0; } but what if it starts out at 32? you will increment it until you get to integer overflow.
Also, indice should only take on values 0 through 17. paquete[18] is array overflow!!!!
test limit with
if(indice == 17) indice = 0;
otherwise, you will attempt to access paquete[18] one time
Global variables are initialized. While the first part of the statement is good advice, the second part is not true.
