I am writing code for my quadcopter and have been able to download it before, but for some reason it refuses to compile. It just sits there with the compile bar at 20%. I have left it for about 30 min with it still stuck at 20%.
MainProgram
#include "Control_Functions.h"
// Connect both Ground AND Signal wires to ESC input
int Chan1 = 3; //Channel: 1 -- Aileron
int Chan2 = 9; //Channel: 2 -- Elevator
int Chan3 = 10; //Channel: 3 -- Throttle
int Chan4 = 11; //Channel: 4 -- Rudder
int arm = 1000; // pulse width in microseconds for arming
int speedvalue = 1000; // pulse width in microseconds for operation // TESTED (5/19/15) Equal to 1000 is idol || Greater than (possibly lower) 1150 is motor movement
int time = 0;
pinMode(Chan1, OUTPUT);
pinMode(Chan2, OUTPUT);
pinMode(Chan3, OUTPUT);
pinMode(Chan4, OUTPUT);
//VVVV----------USE ONLY WITH JUST ESC----------VVVV
/* It appears that the ESC will accept a range of values for the arming
sequence. This provides 10 pulses with a pulse width of 1000 us with
with a 20 ms delay between pulses. */
// delay(8000); //Allow for battery to be pluged in
// for (int count = 0; count < 10; count++){
// digitalWrite(Chan1, HIGH);
// delayMicroseconds(arm);
// digitalWrite(Chan1, LOW);
// delay(20);
// digitalWrite(Chan2, HIGH);
// digitalWrite(Chan2, LOW);
// delay(20);
// digitalWrite(Chan3, HIGH);
// digitalWrite(Chan3, LOW);
// delay(20);
// digitalWrite(Chan4, HIGH);
// digitalWrite(Chan4, LOW);
// delay(20);
//^^^^----------USE ONLY WITH JUST ESC----------^^^^
//FourMotor(Chan1, Chan2, Chan3, Chan4, 1000, 1000, 1000, 1000, 2500); //"Prime" esc's
delay(8000);
BoardArm(Chan3, Chan4);
delay(1500);
SingleMotor(Chan3, 1140, 4000);
//SingleMotor(Chan3, 1000, 4000);
.h file
void SingleMotor(int escPin, int speed, int millisec)
int stoptime = 0;
time = millis();
stoptime = time + millisec;
while(true) //Needs to be in loop to provide complete wave forms
digitalWrite(escPin, HIGH);
delayMicroseconds(speed);
digitalWrite(escPin, LOW);
delay(20);
time = millis();
if(time > stoptime)
void FourMotor(int esc1, int esc2, int esc3, int esc4, int speed1, int speed2, int speed3, int speed4, int millisec)
int stoptime = 0;
time = millis();
digitalWrite(esc1, HIGH);
delayMicroseconds(speed1);
digitalWrite(esc1, LOW);
digitalWrite(esc2, HIGH);
delayMicroseconds(speed2);
digitalWrite(esc2, LOW);
digitalWrite(esc3, HIGH);
delayMicroseconds(speed3);
digitalWrite(esc3, LOW);
digitalWrite(esc4, HIGH);
delayMicroseconds(speed4);
digitalWrite(esc4, LOW);
time = millis();
if(time > stoptime)
void BoardArm(int esc1, int esc2)
int millisec = 1500;
int stoptime = 0;
time = millis();
delayMicroseconds(1086);
delayMicroseconds(1875);
time = millis();
if(time > stoptime)
Any help?
