Code tags - good news/bad news
First the good news.
Text in code tags can now be selected with one click.
Now the bad news
Text in code tags has no scroll bars. It just goes on, and on, and on ........
UKHeliBob:
Now the bad news
I found a little tag at the bottom right hand corner which allows you to reduce the size of the code tag window and then scroll bars appear. I presume there is something that @mrdanny can set which give the window a default max size.
...R
Thanks Robin, I will take a look.
Next problem - why does using the quote button cause the font commands to show ?
it appears that copying from code or quote you get all the markup tags with it :frowning:
has been reported to the core team
I can see the little tag at the bottom/right corner of the code but nothing happens if I hover the cursor over it or click on it,
UKHeliBob:
Hold your mouse button down and slide upwards ? ? ?
...R
Nothing happens.....
Does your cursor change when you hover over the little triangle in the corner ?
UKHeliBob:
Yes. Here is some experimental code
line a
yabba
dabba
doo
magic roundabout
showing
my
age
Yep, it works with this. The cursor changes to a 2-headed up-down arrow when I hover on the corner marker and I can make the box shorter or longer. I'm using Firefox on Ubuntu.
...R
Chrome on Windows 7 here and no change in the cursor or ability to drag up.
I have just tried IE. No corner marker showing on the code box.
Nothing from Safari on OS X 10.9.5 either
