Code that used to work, doesn't work anymore: DS3234 related
I'm not sure why, but I'm getting the following error:
Arduino: 1.6.0 (Mac OS X), Board: "Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
rtc_ds3234.ino: In function 'void parse_cmd(char*, int)':
rtc_ds3234.ino:113:68: error: cannot convert 'boolean* {aka bool*}' to 'const uint8_t* {aka const unsigned char*}' for argument '6' to 'void DS3234_set_a1(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, const uint8_t*)'
rtc_ds3234.ino:123:59: error: cannot convert 'boolean* {aka bool*}' to 'const uint8_t* {aka const unsigned char*}' for argument '5' to 'void DS3234_set_a2(uint8_t, uint8_t, uint8_t, uint8_t, const uint8_t*)'
Error compiling.
I'm trying to use the RTC DS3234, and using the library from GitHub - rodan/ds3234: arduino library for DS3234 RTC
I've redownloaded the Arduino IDE, and also this library, but when I try to run any of the examples found in it, (or any code I have from my projects that use the DS3234) it gives me this error.
PS. I've added an example code from the DS3234 library
// during an alarm the INT pin of the RTC is pulled low
// this is handy for minimizing power consumption for sensor-like devices,
// since they can be started up by this pin on given time intervals.
#include <SPI.h>
#include "ds3234.h"
#define BUFF_MAX 256
const int cs = 10;              // chip select pin
// time when to wake up
uint8_t wake_HOUR = 15;
uint8_t wake_MINUTE = 46;
uint8_t wake_SECOND = 9;
// how often to refresh the info on stdout (ms)
unsigned long prev = 5000, interval = 5000;
void set_alarm(void)
    // flags define what calendar component to be checked against the current time in order
    // to trigger the alarm - see datasheet
    // A1M1 (seconds) (0 to enable, 1 to disable)
    // A1M2 (minutes) (0 to enable, 1 to disable)
    // A1M3 (hour)    (0 to enable, 1 to disable)
    // A1M4 (day)     (0 to enable, 1 to disable)
    // DY/DT          (dayofweek == 1/dayofmonth == 0)
    boolean flags[5] = { 0, 0, 0, 1, 1 };
    // set Alarm1
    DS3234_set_a1(cs, wake_SECOND, wake_MINUTE, wake_HOUR, 0, flags);
    // activate Alarm1
    DS3234_set_creg(cs, DS3234_INTCN | DS3234_A1IE);
    DS3234_init(cs, DS3234_INTCN);
    DS3234_clear_a1f(cs);
    set_alarm();
    char buff[BUFF_MAX];
    unsigned long now = millis();
    struct ts t;
    // once a while show what is going on
    if ((now - prev > interval) && (Serial.available() <= 0)) {
        DS3234_get(cs, &t);
        // display current time
        snprintf(buff, BUFF_MAX, "%d.%02d.%02d %02d:%02d:%02d", t.year,
             t.mon, t.mday, t.hour, t.min, t.sec);
        Serial.println(buff);
        // display a1 debug info
        DS3234_get_a1(cs, &buff[0], 59);
        if (DS3234_triggered_a1(cs)) {
            // INT has been pulled low
            Serial.println(" -> alarm1 has been triggered");
            // clear a1 alarm flag and let INT go into hi-z
        prev = now;
Try changing     boolean flags[5] = { 0, 0, 0, 1, 1 };
to     byte flags[5] = { 0, 0, 0, 1, 1 };
Thanks SO much!
Thanks, worked for me to.
