I am new to the forum but am familiar with coding. I am working on a project to store a devices usage qty in eeprom. the idea is once a button is held for a certain amount of time (10seonds) the stored qty in the eeprom will be converted to a number of blinks. For example: if the number 525 is in eeprom I would like the LED to blink 5 times pause 2 times pause then 5 times pause . I was trying to avoid doing this with a bunch of loops that compared the number to eventually get it down to its ones, tens and hundreds place. Any input or reference to a library or other code snippet that does this already would be helpful.
Thanks,
You first need to break the number to be displayed into digits. Example:
int number = 25;
int digits = number%10; //get the 5
Example to blink an LED n times:
for (byte i = 0; i<n; i++) {
digitalWrite(LED, HIGH);
delay(100);
digitalWrite(LED,LOW);
delay(100);
@arduken
Your post was MOVED to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
I'm not sure what this has to do with Covid 19.
Thanks for the reply.
appreciate your help with this. Will give this a try.
