Hi everyone,
I'm using the u-blox EVK-F9T (ZED-F9T) with an Adafruit Feather RP2040. Communicating using SPI (1) with the following wiring:
MISO pin is 8
MOSI pin is 11
SCK pin is 10
CS pin is 9
The end goal is to read the UBX messages and save them to an SD card using the SparkFun_u-blox_GNSS_v3 library. If I configure the GNSS device using U-center to output UBX to SPI and enable certain message types, all works as desired: code running on the RP2040 successfully logs the data and the data file can be opened in u-center.
Rather than configure through U-center, I'm trying to configure through code using the SFE_UBLOX_GNSS_SPI class. The steps I'm following to configure are:
myGNSS.newCfgValset(VAL_LAYER_RAM);
myGNSS.addCfgValset(UBLOX_CFG_SPIOUTPROT_UBX, 1);
myGNSS.addCfgValset(UBLOX_CFG_MSGOUT_UBX_NAV_PVT_SPI, 1);
myGNSS.addCfgValset(UBLOX_CFG_MSGOUT_UBX_NAV_CLOCK_SPI, 1);
myGNSS.sendCfgValset();
I left off here for brevity, but the code checks the returns of all methods and all return success.
That isn't working. I'm unable to receive any UBX messages. Using U-center to query the config shows the values for those items don't change.
Before creating a more complete post, I first wanted to ask:
- Is that set of commands sufficient, or am I missing something?
- After configuring through code (when I get it working), I should see the values reflected after a U-center query, correct?
Thanks.
