Code to detect and choose which speaker is free.
I am working on making an electric piano that can play two notes at once.
I am using this tone library GitHub - bhagman/Tone: A Wiring Library to produce square wave tones on arbitrary pins. because it is designed to allow the playing of more than one tone at a time by a single arduino board, on separate speakers. I have already figured out how to get two tones playing on separate speakers at the same time, but my difficulty is in making this responsive to buttons (keys).
Right now I am trying to code two buttons, where when a button is pressed, it plays a tone on the first speaker that is free. For example, button 1 is pressed and both speakers are free, so a note is played on speaker 1, then button 2 is pressed with button 1 still held down, so button 2 plays a note on speaker 2.
Or vice versa; button 2 is pressed while both speakers are free, so it plays a note on speaker 1, and then button 1 is pressed while button 2 is still held down, so it plays a note on speaker 2. (Sorry if this is confusing!)
I attached my code for this.
From troubleshooting I have learned that:
  • Right now when either button is individually pressed after the code is compiled, it simply plays its note on both speakers, and then both speakers continue playing that note.
    -Having the sound start & stop with the pressing of the button does work when only using 1 tone on 1 speaker with 1 button.
  • My logic for checking when a button is pressed vs not pressed is working correctly; the if statements correctly execute according to the state of the button
  • The code to check the state of each speaker is working correctly as well; when tested in isolation the tone.isPlaying() is correct
My question:
  • If the state of the button and the state of the speaker are correct, could this issue be caused by something related to a race condition in the code? Or any other ideas?
Also, if anyone has ideas for a better way to implement this functionality I am open to them! Thank you so much for reading this & for your help!
Piano_Buttons.ino (2.49 KB)
Compiles, untested. Any luck with it? If it works, does it give you any ideas?
#include <Tone.h>
Tone tone1;
Tone tone2;
const int button1Pin = 2;
const int button2Pin = 6;
int button2State = 0;
int button1State = 0;
const uint16_t
    grNotes[] =
        NOTE_A3,        //corresponds to button 1
        NOTE_CS4        //and this is button 2
uint8_t
    spkrMask;
typedef struct structButtonInfo
    uint8_t     pin;            //pin button
    uint8_t     usedMask;       //mask used to re-set speaker bit
    Tone        *pTone;         //pointer to the tone output that will play this button's note
    uint8_t     lastRead;       //last read value
    uint32_t    timeRead;       //used for timing uS between reads
}sButtonInfo_t;
sButtonInfo_t
    ButtonInfo[2] =
            //button 1
            .pin = button1Pin,
            .usedMask = 0,
            .pTone = NULL,
            .lastRead = LOW,
            .timeRead = 0ul
            //button 2
            .pin = button2Pin,
            .usedMask = 0,
            .pTone = NULL,
            .lastRead = LOW,
            .timeRead = 0ul
void setup( void )
    // tone1 plays sound on the speaker connected to Pin 13,
    // tone 2 for the speaker on pin 11.
    tone1.begin(13);
    tone2.begin(11);
    // Using INPUT_PULLUP to make configuring the buttons work- this makes their default state
    // HIGH, so to "press" them they are connected to ground, and switch to LOW
    pinMode(button1Pin, INPUT_PULLUP);
    pinMode(button2Pin, INPUT_PULLUP);
    //in spkrMask, bits 0 and 1 are used to indicate speaker status
    //if bit 0 == 1, spkr 1 is free; if bit 0 == 0, spkr 1 is in use
    //if bit 1 == 1, spkr 2 is free; if bit 1 == 0, spkr 2 is in use
    //init to 0x03 to indicate both speakers free
    spkrMask = 0x03;
    //establish the "last" value of the buttons with this initial read
    for( uint8_t i=0; i<2; i++ )
        ButtonInfo[i].lastRead = digitalRead( ButtonInfo[i].pin );
}//setup
void loop( void )
    PlayNotes();
}//loop
void PlayNotes( void )
    static uint8_t
        index = 0;
    uint32_t
        timeNow = micros();
    //read switches every 2mS (2000uS)
    if( (timeNow - ButtonInfo[index].timeRead) >= 2000ul )
        //time for a read; save the micros count now for next read
        ButtonInfo[index].timeRead = timeNow;
        //read the switch
        uint8_t nowRead = digitalRead( ButtonInfo[index].pin );
        //if not the same as last time...
        if( nowRead != ButtonInfo[index].lastRead )
            //save new value as last
            ButtonInfo[index].lastRead = nowRead;
            //if low, button has been pressed
            if( nowRead == LOW )
                //see switch speaker is available
                switch( spkrMask )
                    //if speaker mask is 0b11 or 0x01, then both or only #1 is available
                    //in either case, use speaker 1
                    case    0x03:
                    case    0x01:
                        //show that speaker 1 is now occupied by clearing bit 0 in the mask
                        spkrMask &= 0b00000010;
                        //and assign tone1 to this button
                        ButtonInfo[index].pTone = &tone1;
                        //this is the mask we use to reinstate the bit when the note is finished
                        //here we'll re-set bit 0
                        ButtonInfo[index].usedMask = 0b00000001;
                    case    0x02:
                        //spkr 1 in use; select spkr 2
                        //same logic as case 3/1 but now spkr 2 is the one we use
                        spkrMask &= 0b00000001; //clear bit 1
                        ButtonInfo[index].pTone = &tone2;   //assign tone2
                        ButtonInfo[index].usedMask = 0b00000010;    //re-set mask is for bit 1
                    default:
                        //invalid or no spkr available
                        //no tone is given and no bits are set when button released
                        ButtonInfo[index].pTone = NULL;
                        ButtonInfo[index].usedMask = 0b00000000;
                }//switch
                //if a tone pin was assigned...
                if( ButtonInfo[index].pTone )
                    //play the note for this button at the tone output assigned above
                    ButtonInfo[index].pTone->play( grNotes[index] );
            }//if
                //here is key was just released
                //if we're playing a note...
                    //stop it now
                    ButtonInfo[index].pTone->stop();
                //re-set the speaker mask bit (if used; if none was available, 0x00 is ORd in and nothing changes)
                spkrMask |= ButtonInfo[index].usedMask;
                //clear the re-set mask for this button
                ButtonInfo[index].usedMask = 0;
            }//else
        }//if
    }//if
    //each pass we look at one button.
    //bump button index each pass
    index++;
    if( index == 2 )
        index = 0;
}//PlayNotes
This code worked exactly right on the first try. There are truly not enough people in the world like you. Thank you so much!
