My programming skills are limited to simple stuff but now I need to monitor a line for when it is steady.
I am using a Nano.
I am using a pre programmed pic chip which gives three frequency's out, which frequency it is outputting is indicated by another line pulsing or not and is either a 6hz pulse, a 1.5hz pulse or a steady high output ( pulses are 50% markspace ratio ).
I can change which mode it is in by pulsing a change line low.
Problem is how do I check if the line is steady and therefore needs no mode change and if not then I need to pulse the mode line 500m/s low then check if steady, if not pulse it again until it is steady so indicating I am at the required mode. (doing the pulsing bit I am OK with)
The mode is cyclic so after pulsing the three modes it starts again.
I need the rest of the program to make sure it always starts with this pic chip in the steady mode.
Any idea's guy's?
I forgot to say I am using the two int lines of the Nano for other things
regards John
